I’m trying to turn on the humidifier in the greenhouse when the humidity is < 80%. I also want the humidifier off between 23:30 and 8:30 as it is noisy.
The problem is that in the morning the humidity is usually < 80% and therefore the threshold isn’t crossed and the automation doesn’t get triggered.
How can I create an automation trigger that works in this condition?
I have attached a screenshot of my current automation
Create a template trigger with an entity id: sensor.time (so it triggers every minute)
List your time conditions, humidity conditions then use a service template to turn your switch on or off
