Trigger on Washing Machine finish
It work some times and mostly not.
The above code was for test only so I set short times to check settings. Here is my final configuration.
I want to get google home device announce that wash is done. For this I have set following as my understanding.
  1. When machine starts, it takes 2- 5 watts while you set timer etc.
  2. When machine start washing it takes around 190-230 watts until completed.
  3. in between, it takes 6-5 watts again for water drain and refill.
So I have set that if machine take power more than 1 watt for atleast 10 minutes or more. It should trigger and added condition that power must be less than .3 for 30 seconds to run actions.
Because when machine is started, it takes more than 1 watt. and when it complete it takes 0 watts.
Now its not running and I don’t know why. Is there any way to troubleshoot? So I am making any mistake in my configuration?
Please advice.
- id: '1622563811541'
  alias: 'Washing Machine automation '
  description: ''
  - platform: numeric_state
    entity_id: sensor.sonoff_1000000_power
    attribute: power
    for: 00:10:00
    above: '1'
  condition: []
  - wait_for_trigger:
      below: '.3'
      for: 00:00:30
      attribute: power
    continue_on_timeout: false
  - service: media_player.volume_set
      entity_id:
      - media_player.kitchen_speaker
      - media_player.bedroom_speaker
      - media_player.office_speaker
      volume_level: 1
  - wait_template: 00:00:15
  - service: tts.google_translate_say
      message: washing done
      entity_id: media_player.bedroom_speaker
      entity_id: media_player.kitchen_speaker
  - service: notify.mobile_app_iphone
      title: Washing is done
      message: Take of the cloths from machine
  - service: switch.turn_off
      entity_id: switch.sonoff_1000000
  mode: restart
It’s hard to tell.
Note that “above 1 for 10mn” means that the power must not drop under 1W for the whole 10mn to trigger.
Same for “below .3 for 30s”. So if there is only 1 instance of a 1.1W after 9:59, then it won’t trigger.
I’ve not chosen to go this way, but used a larger value (30W) no delay to detect beginning.
And then an higher value (3W) for a longer time (5mn) to detect end of cycle.
Hi, I like your code. But don’t know what is this, another helper?
“service: timer.start
entity_id: timer.wasmachine”
In your write up not find it.
I have a plug with tasmota firmware, which values I have to change to integrate the switch.blitzwolf_shp6?
What “values” are you referring to?
Hey @charliesoap4,
I am a big fan of starting with a state machine, then build actual automations on top of that. A lot cleaner and feasible to maintain and extend over time.
input_select:
  waschmaschine_opstate:
    icon: mdi:washing-machine
    options:
      - "Off"
      - "Standby"
      - "Scheduled"
      - "Active"
      - "Finished"
    initial: "Off"
automation:
  - id: "1609362853001"
    alias: Regel Waschmaschine verbraucht 0.04W (Off)
        entity_id: sensor.waschmachine_strommessgeraet_power
        below: 0.1
        for: "00:03:00"
    condition:
      condition: not
      conditions:
        - condition: state
          entity_id: input_select.waschmaschine_opstate
          state: "Off"
      - service: input_select.select_option
          option: "Off"
  - id: "1609362853002"
    alias: Regel Waschmaschine verbraucht 0.4W (Standby)
        above: 0.3
        below: 0.5
        for: "00:01:00"
    condition:
      condition: state
      state:
        - "Off"
        - "Scheduled"
          option: "Standby"
  - id: "1609362853003"
    alias: Regel Waschmaschine verbraucht 0.4W (Finished)
        above: 0.3
        below: 0.5
        for: "00:01:00"
    condition:
      condition: state
      state: "Active"
          option: "Finished"
  - id: "1609362853004"
    alias: Regel Waschmaschine verbraucht >3W (Active)
        above: 3.0
        for: "00:01:00"
    condition:
      condition: not
      conditions:
        - condition: state
          state: "Active"
          option: "Active"
  - id: "1609362853005"
    alias: Regel Waschmaschine verbraucht 2.9W (Scheduled)
        above: 2.8
        below: 3.0
        for: "00:05:00"
    condition:
      condition: not
      conditions:
        - condition: state
          state: "Scheduled"
          option: "Scheduled"
  - id: "1609362853006"
    alias: Regel Waschmaschine fertig Benachrichtigung
      - platform: state
        to: "Finished"
      - service: notify.mobile_app_thopn
          message: Die Waschmaschine ist fertig
            tag: waschmaschine
How to link my switch.blitzwolf_shp6 to your sensor and automation
Try changing this line in the Template Sensor:
        {% set p = states('sensor.washer_power') %}
to this:
        {% set p = states('sensor.blitzwolf_shp6_energy_power') %}
It’s based on the assumption that your switch.blitzwolf_shp6 has an associated entity called sensor.blitzwolf_shp6_energy_power. If it’s called something else then use that name.
This wouldn’t work for us, because we have different choices for the cycles.
I’d use something a lot simpler, like a pause for 5 minutes after a lot of power usage.
I’m quite sure we all do.
Why would what Taras posted not work?
I would say it should work on any type of washing program.
