so I used this {{ states.sensor.manutd.state == states.sensor.time.state }} but I get the following error :
2017-10-20 15:24:20 ERROR (Thread-2) [homeassistant.util.yaml] while scanning for the next token
found character '\t' that cannot start any token
in "/home/homeassistant/.homeassistant/configuration.yaml", line 68, column 1
2017-10-20 15:24:20 ERROR (MainThread) [homeassistant.bootstrap] Error loading /home/homeassistant/.homeassistant/configuration.yaml: while scanning for the next token
Line 68 is {{ states.sensor.manutd.state == states.sensor.time.state }}
I know some of us sound like a broken record, but why is the timing so critical that 8 seconds is a problem? What specifically are you trying to do?
This is an important question, because some user might have a good way to accomplish what you want, but without the struggles and complications youâre having now.
Sorry for my novelty but do I expect to see the binary sensor on the front end? I have tried looking for it as a senor in the states page but cannot see it. I have done a test run when the sensor.manutd is equal to sensor.time.
Hey @Dolores, @RobDYI has just explained what I am trying to achieve.
If anyone of you could please try to use the time component the way I have used it, you might actually see what I am trying to explain all this time (and the lag).
The lag is important because the time component is not in sync in general with HA and it defeats the purpose really of having a âtimeâ component.
The trouble is, Home Assistant isnât a real time platform and doesnât pretend to be one. Thereâs always going to be delays, even when everything is purely internal to the system youâre running it on. Using a template like that slows things down again, and may well be the primary source of the delay.
The best youâre likely to achieve is to identify the typical range, and instead set it to trigger one minute earlier, then have a delay of (say) 52 seconds. Thatâs horribly, horribly, inefficient, but it may achieve what youâre after.
My purely time based automations generally fire within 2 minutes of the designated time (so, if due to trigger at 06:00 theyâll trigger between 06:00 and 06:01 inclusive).
