Does anyone know what the problem is? I run HA on Docker.
When I set it up 2 months ago directly with Hassbian at least the Power button worked for shut down. I don’t remember whether Volume worked though.
Log after reboot
17-04-09 11:12:46 WARNING (Thread-7) [homeassistant.components.emulated_hue] When targetting Google Home, listening port has to be port 80
17-04-09 11:12:50 ERROR (Thread-11) [braviarc.braviarc] [W] Exception: ('Connection aborted.', OSError(113, 'No route to host'))
17-04-09 11:12:52 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=157 from 2017-04-09 08:45:52.576769)
17-04-09 11:12:53 WARNING (MainThread) [homeassistant.setup] Setup of remote is taking over 10 seconds.
17-04-09 11:12:55 WARNING (MainThread) [homeassistant.setup] Setup of media_player is taking over 10 seconds.
17-04-09 11:12:55 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform pioneer is taking over 10 seconds.
17-04-09 11:12:56 WARNING (MainThread) [homeassistant.components.remote] Setup of platform harmony is taking over 10 seconds.
I’ve found that the VSX920 (and other older models) require a couple of carriage returns to be sent before sending commands. I’ve now got a working update as a custom component, and will look at making a pull request to update the main component.
@snowboardy I’m having similar issues with a VSX-827 so I’m as well interested in your custom component, or at least in getting more details of where such carriage returns should are expected.
Hi I build a custom component for the Pioneer VSX 529. Should be also compatible for VSX 824. Maybe it is also working for you or is a good starting point.
thanks for doing the work, i am a complete newbie i took the files placed them in the custom components folder but get a message when i check my config
Component error: pioneervsx - Integration ‘pioneervsx’ not found.
any chance that you punt me in the right direction
Hi, you mention that the VSX-529 does not support “set volume”, but it does if you use the dlna component. The problem is that dlna does not support “volume state” or whatever it is called. Maybe we can combine both components to get fully working volume control for the VSX-529.
edit: i just added your component and it works paralell with the dlna component. Now it just needs some automation.
Thank you for this hint! DLNA is also a good idea to set the volume. In the published code I solved the problem with a loop, which in/decrease the volume untill it reaches the “set volume”. This works quite nice for me.
