I found that if I take out the 7-day reading it does work ??
I dropped it down to just current and lifetime but still no good.
Is the storage values new?
I have SMA for my batteries, they are painful to get info from, wish I had gone Victron instead.
Mine looks like this;
# Enphase production readout
- platform: enphase_envoy
ip_address: x.x.x.x
monitored_conditions:
- production
- daily_production
- lifetime_production
Got mine working again.
I moved ip from secret back to configuration.yaml
Hello all, thanks for the neato home-assistant tools, and thanks @DavidDeSloovere, @exxamalte and probably others for doing the envoy setup.
Iâm new so my configuration may be the issue, or it may be I have an older Envoy, production only, oval white with small LCD. ( Current s/w R3.7.26 (7888b3), s/w Build Date Mon Aug 25, 2014 01:56 PM PDT )
I have hassbian on a pi, and 0.93.1 home assistant. It seems to work but my only device / sensor is a DTE energy bridge which is now working through mosquitto. This is all great fun, gives me something to do in between replacing the m190s on the roof!
# Solar production
ip_address: 192.168.15.18
- production
With the envoy, I get an error coming from envoy_reader.py where itâs determining the envoy model.
enphase_envoy: Error on device update!
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 261, in _async_add_entity
await entity.async_device_update(warning=False)
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 377, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/lib/python3.7/concurrent/futures/thread.py", line 57, in run
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/enphase_envoy/sensor.py", line 83, in update
self._state = getattr(EnvoyReader(self._ip_address), self._type)()
File "/srv/homeassistant/lib/python3.7/site-packages/envoy_reader/envoy_reader.py", line 53, in production
raw_json = EnvoyReader.call_api(self)
File "/srv/homeassistant/lib/python3.7/site-packages/envoy_reader/envoy_reader.py", line 39, in call_api
EnvoyReader.detect_model(self)
File "/srv/homeassistant/lib/python3.7/site-packages/envoy_reader/envoy_reader.py", line 34, in detect_model
"Check that the device is up at 'http://" + self.host + "'.")
RuntimeError: Could not connect or determine Envoy model. Check that the device is up at 'http://192.168.15.18'.
For the newer envoy-S with consumption monitoring, the code expects http://{}/production.json to exist, which also does not exist from my envoy, as expected. (it gives an emu picture and âpage not foundâ)
The code then expects the page http://{}/api/v1/production to exist for a production only model envoy, but that page also doesnât work from my envoy. It says:
"status": 404,
"error": "",
"info": "Resource /api/v1/production not found",
"moreInfo": ""
My envoy does have this page: http://{}/production it returns text in boxes (Currently = dark outsideâŚ).
System has been live since
Thu May 12, 2011 04:44 PM EDT
Currently 0 W
Today 19.5 kWh
Past Week 128 kWh
Since Installation 45.0 MWh
I played with the /srv/homeassistant/lib/python3.7/site-packages/envoy_reader.py file. I changed to look for the /production page mine has, and it gets past the original error detecting the envoy model. It populates the sensor value for production, but the state shows âUnable to connect to Envoy. Check that the device is up at âhttp://192.168.x.xâ.â
I changed the envoy_reader.py code to look for âCurrentlyâ instead of âwattsNowâ.
def production(self):
try:
if self.endpoint_type == "PC":
production = raw_json["production"][1]["wNow"]
else:
#production = raw_json["wattsNow"]
#production = raw_json["Currently"] tried this
production = raw_json["Currently"][1]["W"] then this, still no go...
return int(production)
It still gives the same error for the state, âUnable to connect to Envoy. Check that the device is up at âhttp://192.168.x.xâ.â
SoâŚ, could I have a configuration issue, or is my envoy s/w different and I need to adjust the .py code? Is it SimpleJSON vs. Python JSON, I havenât installed any python special beyond whatever is in hassbian. In any case, Iâm hardly dangerous with python, but Iâd love to fix & test it.
Thanks!!
Since youâre already looking into the envoy_reader library code, you would have noticed that the first thing it does is trying to detect the API end-point in the detect_model
method. And this will still fail because as you pointed out yourself, your Envoy does neither have the /production.json
nor /api/v1/production
end-point available.
Also, the response you posted is not valid JSON so the parsing code wonât work.
If you have a bit of time at your hands and are willing to do some Python programming, can I suggest you implement a proper extension for the envoy_reader library, i.e. add another check for your Envoyâs text end-point into detect_model
, then amend all the *production
methods to take care of parsing the text (not JSON) your Envoy returns, possibly converting the values into a standard W/Wh unit, etc., and then ask the maintainer of the library to include your extension.
Maybe there are some more people with that Envoy model who would benefit from this extension.
Thanks @exxamalte thatâs what I would like to do.
Where could I find an example of scraping data from an http web page on a device?
Iâm not familiar with json, am I sure yet that my device does not have a page like that? Iâm poking at it from a browser, maybe I need to do from python to be sure what the EnvoyReader.call_api() result is.
You can have a look at the code of one of my custom components where I am retrieving an HTML page from a cable modem and then use a regular expression to find the data I am looking for. To find regular expressions that match the values you are getting from your Envoy device might be a bit tricky, so Iâd recommend using a helper like pythex.
I think youâre right, thatâll be the first tricky part. I played with pythex, plugging in the relevant html returned by my Envoy:
Does this look like it would work? It gets the desired zero, but, Again, itâs nighttime, Iâll test with data from when itâs producing, the extra digits might matter depending on how it formats it I suppose.
<td>Currently</td> <td>(......)W</td>
Here is the html the envoy returns from the production page:
<!-- START MAIN PAGE CONTENT -->
<h1>System Energy Production</h1>
<div style="margin-right: auto; margin-left: auto;"><table>
<tr><td colspan="3">System has been live since
<div class=good>Thu May 12, 2011 04:44 PM EDT</div></td></tr>
<tr><td>Currently</td> <td> 0 W</td></tr><tr><td>Today</td> <td> 30.0 kWh</td></tr><tr><td>Past Week</td> <td> 132 kWh</td></tr><tr><td>Since Installation</td> <td> 45.0 MWh</td></tr>
</table><br></div>
<!-- END MAIN PAGE CONTENT -->
Iâm afraid that this regex would not be generic enough. Your six dots only match if there exactly six characters including whitespace. As soon as you produce 10W it wouldnât match anymore.
You probably need to look at using character classes and quantifiers. The following for example matches any number, with or without digits.
<td>Currently</td> <td>\s*(\d+|\d+\.\d+)\s*W</td>
And as mentioned before you would also need to take care of parsing the units as I assume that they change. The following matches âWâ or âkWâ in a second group:
<td>Currently</td> <td>\s*(\d+|\d+\.\d+)\s*(W|kW)</td>
I have the envoy_reader working now for my older Envoy C which has only html pages, if anyone else comes along with an Enphase system circa 2010/2011.
This still has to get rolled in after checking on another issue, but this worked for me on 0.93.1 ha for about a month, and on 0.94.4 ha today after putting in github and mostly integrating with the latest envoy_reader version. https://github.com/dalklein/envoy_reader
It should still work for the newer Envoys with .json data, including the recently added data by inverter serial number. But test it, please let me know if not
Thanks for the help and pointers! (@exxamalte )
@daklein Iâm able to use the latest envoy_reader but with two minor changes. It seems after the update to envoy_reader about a week ago, it broke the gathering of pages to Envoy-C because an async call would fail, as well the Envoy-C does not have an info.xml page and that call would fail as well.
I have opened a PR to make two small minor changes so that it will pull only the HTML pages. In addition to the changes made on the envoy_reader side, HA was updated but not yet pushed to the released build as far as I can see from this PR. Iâm running my private build of the envoy_reader.py along with the sensor.py from the previously mentioned HA PR with HA 0.94.3 against an Envoy running R3.11.30, without any problems.
Take a look and see if changing the envoy_reader.py to my private build along with the updated sensor.py in the PR, fixes your problem.
Greg
thanks Greg @gregtd I think I have done that, taken your fixes to envoy_reader.py and the async related changes that will be in enphase_envoy/sensor.py component. I tried again by cloning jesserizzo/ha and using the sensoy.py from there.
Now I get this error, one for each of the 4 items itâs reading. It may be due to my changes. I can try your envoy_reader also, but it wonât do the older envoy non .json.
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 375, in async_device_update
await self.async_update()
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/enphase_envoy/sensor.py", line 89, in async_update
_state = await getattr(EnvoyReader(self._ip_address), self._type)()
File "/srv/homeassistant/lib/python3.7/site-packages/envoy_reader/envoy_reader.py", line 248, in seven_days_production
return int(seven_days_production)
UnboundLocalError: local variable 'seven_days_production' referenced before assignment
@daklein From the trace it appears you are running your envoy_reader.py from https://github.com/dalklein/envoy_reader/blob/ef2633b0887ccaa09fb219255afbe09a3e4d3195/envoy_reader/envoy_reader.py?
Iâm still looking through the code, but from what I can see all of the 4 production methods have the same if else logic.
Your Envoy does not respond to http://IP_ADDR/api/v1/production
, but responds to http://IP_ADDR/production
, correct? So the code should be setting the model (endpoint_type) to P0?
Greg
Thanks for looking !
yes, the P0 section is what I added. somehow now it is failing in this set of if / else logic I think? not getting a value assigned. I tried initializing it to zero, which prevents the use before assign error, but then it stays stuck at zero.
Iâm not sure how itâs failing now. maybe itâs the re.search looking for text, but text still awaiting?
@daklein Your envoy_reader.py also fails on my Envoy running R3.11.30. I found 4 places where an await
needs to be added. Check out Lines 109, 162, 219, and 274. After I added the await
to those lines I was able to retrieve production data from my Envoy.
Line 109 await EnvoyReader.detect_model(self)
Line 162 await self.detect_model()
Line 219 await self.detect_model()
Line 274 await self.detect_model()
Greg
Thanks Greg @gregtd, much appreciated.
Tested and works now for me. With Envoy C s/w R3.7, ha 0.94.4 with requests_async installed to the ha venv, enphase_envoy component updated from this HA PR (thanks jesserizzo), and my changes to envoy_reader for the older Envoy C with only html pages.
Should show up in a future ha release. But in any case, itâs fun to have it working now for my setup.
Hi all,
My daily production always starts at approx 30Kw and counts up from there.
The number isnât the same each day.
does anyone else have this issue or a fix?
with thanks
Working fine for me.
Have you checked on the gateway directly? You can browse to some pages on the gateway.
Find the IP of the gateway and try some of the URLs that can be found here: https://github.com/jesserizzo/envoy_reader
#This works for me with RPI on python3.9
import time
import serial
import os
import glob
import time
import datetime
import urllib.request,json
from time import gmtime, strftime
from datetime import timedelta
import mysql.connector
#import Adafruit_BMP.BMP085 as BMP085
import sys
#HAAL NIEUWE CELLEN WEST) OP***
url = âhttp://192.168.178.185/api/v1/productionâ
#frequency = 180
response = urllib.request.urlopen(url)
data = json.loads(response.read())
E_tot = data[âwattHoursLifetimeâ]
E_today = data[âwattHoursTodayâ]
P_nu = data[âwattsNowâ]
#print(data)
print(âTotaal opgewekt : %6d Whrâ %E_tot)
print(âVandaag opgewekt : %6d Whrâ%E_today)
print(âMomenteel vermogen: %6d Wâ%P_nu)
