Troubles trying to get ZHA working
Don’t get me wrong, just trying to help you figure out the problem but you have posted some conflicting information:
:roll_eyes:
Back to the current issue. Anything in the log? Did you try this
Using the path rather than ID lets me connect/setup ZHA (suggesting that HA can see the Conbee2) but then when going into the integration, the Conbee2 and two paired devices show up but are all ‘unavailable’, which is no different from when I add ZHA by ID. So they both give the same non working result :expressionless:
Did you remove modemmanager?
So far this appears to have fixed it, thank you! I’ll try a few restarts / reboots and make sure it keeps working, if so I’ll come back and mark this as solved.
