Solution
I need help troubleshooting a ZHA light bulb group issue. Perhaps someone more knowledgeable can interpret the logs below better than I.
Some of my light fixtures have multiple Hue bulbs. Ever since I have switched to ZHA those groups often turn themselves back on. This become more clear when moved a 9 Hue bulbs group over to ZHA. I am currently using a Home Assistant group
to control the bulbs, but I have tried a Home Assistant light
group and a ZHA light
group with similar results.
group.dining_room_light
turned off (via Lovelace toggle).
2020-08-21 08:35:57 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x4544:11:0x0006]: executed 'off' command with args: '()' kwargs: '{}' result: [0, <Status.SUCCESS: 0>]
2020-08-21 08:35:57 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining9: turned off: [0, <Status.SUCCESS: 0>]
2020-08-21 08:35:57 DEBUG (MainThread) [zigpy.zcl] [0x0367:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=123 command_id=Command.Default_Response>
2020-08-21 08:35:57 DEBUG (MainThread) [zigpy.zcl] [0x84ef:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=121 command_id=Command.Default_Response>
2020-08-21 08:35:57 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x84ef:11:0x0006]: executed 'off' command with args: '()' kwargs: '{}' result: [0, <Status.SUCCESS: 0>]
2020-08-21 08:35:57 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining7: turned off: [0, <Status.SUCCESS: 0>]
2020-08-21 08:35:57 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x0367:11:0x0006]: executed 'off' command with args: '()' kwargs: '{}' result: [0, <Status.SUCCESS: 0>]
2020-08-21 08:35:57 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining6: turned off: [0, <Status.SUCCESS: 0>]
2020-08-21 08:35:57 DEBUG (MainThread) [zigpy.zcl] [0x0c4f:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=127 command_id=Command.Default_Response>
2020-08-21 08:35:57 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x0c4f:11:0x0006]: executed 'off' command with args: '()' kwargs: '{}' result: [0, <Status.SUCCESS: 0>]
2020-08-21 08:35:57 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining5: turned off: [0, <Status.SUCCESS: 0>]
2020-08-21 08:35:57 DEBUG (MainThread) [zigpy.zcl] [0x515f:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=125 command_id=Command.Default_Response>
2020-08-21 08:35:57 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x515f:11:0x0006]: executed 'off' command with args: '()' kwargs: '{}' result: [0, <Status.SUCCESS: 0>]
2020-08-21 08:35:57 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining3: turned off: [0, <Status.SUCCESS: 0>]
2020-08-21 08:35:57 DEBUG (MainThread) [zigpy.zcl] [0x341b:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=129 command_id=Command.Default_Response>
2020-08-21 08:35:57 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x341b:11:0x0006]: executed 'off' command with args: '()' kwargs: '{}' result: [0, <Status.SUCCESS: 0>]
2020-08-21 08:35:57 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining4: turned off: [0, <Status.SUCCESS: 0>]
2020-08-21 08:35:57 DEBUG (MainThread) [zigpy.zcl] [0xd76b:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=119 command_id=Command.Default_Response>
2020-08-21 08:35:57 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xd76b:11:0x0006]: executed 'off' command with args: '()' kwargs: '{}' result: [0, <Status.SUCCESS: 0>]
2020-08-21 08:35:57 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining1: turned off: [0, <Status.SUCCESS: 0>]
2020-08-21 08:36:02 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xfebb:11:0x0006]: command failed: off exception:
2020-08-21 08:36:02 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining8: turned off:
2020-08-21 08:36:02 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x1c38:11:0x0006]: command failed: off exception:
2020-08-21 08:36:02 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining2: turned off:
2020-08-21 08:36:04 DEBUG (MainThread) [zigpy.zcl] [0x9fcf:1:0x0406] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=False disable_default_response=True> manufacturer=None tsn=167 command_id=Command.Report_Attributes>
2020-08-21 08:36:04 DEBUG (MainThread) [zigpy.zcl] [0x9fcf:1:0x0406] ZCL request 0x000a: [[<Attribute attrid=0 value=<TypeValue type=bitmap8, value=bitmap8.1>>]]
2020-08-21 08:36:04 DEBUG (MainThread) [zigpy.zcl] [0x9fcf:1:0x0406] Attribute report received: occupancy=1
2020-08-21 08:36:05 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x9fcf:1:0x0500]: Updated alarm state: 1
2020-08-21 08:36:05 DEBUG (MainThread) [zigpy.zcl] [0x15dd:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=133 command_id=Command.Default_Response>
2020-08-21 08:36:05 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x15dd:11:0x0006]: executed 'on' command with args: '()' kwargs: '{}' result: [1, <Status.SUCCESS: 0>]
2020-08-21 08:36:05 DEBUG (MainThread) [homeassistant.components.zha.entity] light.kitchen_cabinet: turned on: {'on_off': [1, <Status.SUCCESS: 0>]}
2020-08-21 08:36:22 DEBUG (MainThread) [zigpy.zcl] [0x813f:1:0x0406] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=False disable_default_response=True> manufacturer=None tsn=195 command_id=Command.Report_Attributes>
2020-08-21 08:36:22 DEBUG (MainThread) [zigpy.zcl] [0x813f:1:0x0406] ZCL request 0x000a: [[<Attribute attrid=0 value=<TypeValue type=bitmap8, value=bitmap8.1>>]]
2020-08-21 08:36:22 DEBUG (MainThread) [zigpy.zcl] [0x813f:1:0x0406] Attribute report received: occupancy=1
2020-08-21 08:36:22 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x813f:1:0x0500]: Updated alarm state: 1
2020-08-21 08:36:29 DEBUG (MainThread) [zigpy.zdo] [0xf5f4:zdo] ZDO request ZDOCmd.Match_Desc_req: [0xfffd, 49246, [25], []]
2020-08-21 08:36:32 DEBUG (MainThread) [zigpy.zcl] [0xaeb7:1:0x0400] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=False disable_default_response=True> manufacturer=None tsn=179 command_id=Command.Report_Attributes>
2020-08-21 08:36:32 DEBUG (MainThread) [zigpy.zcl] [0xaeb7:1:0x0400] ZCL request 0x000a: [[<Attribute attrid=0 value=<TypeValue type=uint16_t, value=219>>]]
2020-08-21 08:36:32 DEBUG (MainThread) [zigpy.zcl] [0xaeb7:1:0x0400] Attribute report received: measured_value=219
2020-08-21 08:36:32 DEBUG (MainThread) [zigpy.zcl] [0xaeb7:1:0x0406] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=False disable_default_response=True> manufacturer=None tsn=180 command_id=Command.Report_Attributes>
2020-08-21 08:36:32 DEBUG (MainThread) [zigpy.zcl] [0xaeb7:1:0x0406] ZCL request 0x000a: [[<Attribute attrid=0 value=<TypeValue type=bitmap8, value=bitmap8.1>>]]
2020-08-21 08:36:32 DEBUG (MainThread) [zigpy.zcl] [0xaeb7:1:0x0406] Attribute report received: occupancy=1
2020-08-21 08:36:32 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xaeb7:1:0x0500]: Updated alarm state: 1
2020-08-21 08:36:50 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining7: polling current state - from cache: False
2020-08-21 08:36:50 DEBUG (MainThread) [zigpy.zcl] [0x84ef:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=136 command_id=Command.Read_Attributes_rsp>
2020-08-21 08:36:50 DEBUG (MainThread) [zigpy.zcl] [0x84ef:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=138 command_id=Command.Read_Attributes_rsp>
2020-08-21 08:36:50 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x84ef:11:0x0008]: received attribute: 0 update with value: 254
2020-08-21 08:36:50 DEBUG (MainThread) [zigpy.zcl] [0x84ef:11:0x0300] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=140 command_id=Command.Read_Attributes_rsp>
2020-08-21 08:36:53 DEBUG (MainThread) [homeassistant.components.zha.entity] light.family_room_floor_lamp1: polling current state - from cache: False
2020-08-21 08:36:53 DEBUG (MainThread) [zigpy.zcl] [0xae4b:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=142 command_id=Command.Read_Attributes_rsp>
2020-08-21 08:36:53 DEBUG (MainThread) [zigpy.zcl] [0xae4b:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=144 command_id=Command.Read_Attributes_rsp>
turned back on without user intervention starting around here!
2020-08-21 08:36:53 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xae4b:11:0x0008]: received attribute: 0 update with value: 254
2020-08-21 08:37:06 DEBUG (MainThread) [zigpy.zcl] [0x84ef:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=146 command_id=Command.Default_Response>
2020-08-21 08:37:06 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x84ef:11:0x0008]: executed 'move_to_level_with_on_off' command with args: '(254, 600.0)' kwargs: '{}' result: [4, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0xd76b:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=154 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xd76b:11:0x0008]: executed 'move_to_level_with_on_off' command with args: '(254, 600.0)' kwargs: '{}' result: [4, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0x341b:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=152 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x341b:11:0x0008]: executed 'move_to_level_with_on_off' command with args: '(254, 600.0)' kwargs: '{}' result: [4, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0x1c38:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=158 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x1c38:11:0x0008]: executed 'move_to_level_with_on_off' command with args: '(254, 600.0)' kwargs: '{}' result: [4, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0x4544:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=160 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x4544:11:0x0008]: executed 'move_to_level_with_on_off' command with args: '(254, 600.0)' kwargs: '{}' result: [4, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0xfebb:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=162 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xfebb:11:0x0008]: executed 'move_to_level_with_on_off' command with args: '(254, 600.0)' kwargs: '{}' result: [4, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0x84ef:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=164 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0x0367:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=150 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x0367:11:0x0008]: executed 'move_to_level_with_on_off' command with args: '(254, 600.0)' kwargs: '{}' result: [4, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0xd76b:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=166 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xd76b:11:0x0006]: executed 'on' command with args: '()' kwargs: '{}' result: [1, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0x341b:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=168 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x341b:11:0x0006]: executed 'on' command with args: '()' kwargs: '{}' result: [1, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0x1c38:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=170 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x1c38:11:0x0006]: executed 'on' command with args: '()' kwargs: '{}' result: [1, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0x4544:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=172 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x4544:11:0x0006]: executed 'on' command with args: '()' kwargs: '{}' result: [1, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0xfebb:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=174 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xfebb:11:0x0006]: executed 'on' command with args: '()' kwargs: '{}' result: [1, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0x0c4f:11:0x0008] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=156 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x0c4f:11:0x0008]: executed 'move_to_level_with_on_off' command with args: '(254, 600.0)' kwargs: '{}' result: [4, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0xd76b:11:0x0300] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=178 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xd76b:11:0x0300]: executed 'move_to_color_temp' command with args: '(234, 600.0)' kwargs: '{}' result: [10, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining1: turned on: {'move_to_level_with_on_off': [4, <Status.SUCCESS: 0>], 'on_off': [1, <Status.SUCCESS: 0>], 'move_to_color_temp': [10, <Status.SUCCESS: 0>]}
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0x341b:11:0x0300] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=180 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x341b:11:0x0300]: executed 'move_to_color_temp' command with args: '(234, 600.0)' kwargs: '{}' result: [10, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining4: turned on: {'move_to_level_with_on_off': [4, <Status.SUCCESS: 0>], 'on_off': [1, <Status.SUCCESS: 0>], 'move_to_color_temp': [10, <Status.SUCCESS: 0>]}
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0x1c38:11:0x0300] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=182 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x1c38:11:0x0300]: executed 'move_to_color_temp' command with args: '(234, 600.0)' kwargs: '{}' result: [10, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining2: turned on: {'move_to_level_with_on_off': [4, <Status.SUCCESS: 0>], 'on_off': [1, <Status.SUCCESS: 0>], 'move_to_color_temp': [10, <Status.SUCCESS: 0>]}
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0x4544:11:0x0300] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=184 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x4544:11:0x0300]: executed 'move_to_color_temp' command with args: '(234, 600.0)' kwargs: '{}' result: [10, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining9: turned on: {'move_to_level_with_on_off': [4, <Status.SUCCESS: 0>], 'on_off': [1, <Status.SUCCESS: 0>], 'move_to_color_temp': [10, <Status.SUCCESS: 0>]}
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x84ef:11:0x0006]: executed 'on' command with args: '()' kwargs: '{}' result: [1, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0x0c4f:11:0x0006] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=188 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x0c4f:11:0x0006]: executed 'on' command with args: '()' kwargs: '{}' result: [1, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0x84ef:11:0x0300] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=190 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x84ef:11:0x0300]: executed 'move_to_color_temp' command with args: '(234, 600.0)' kwargs: '{}' result: [10, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining7: turned on: {'move_to_level_with_on_off': [4, <Status.SUCCESS: 0>], 'on_off': [1, <Status.SUCCESS: 0>], 'move_to_color_temp': [10, <Status.SUCCESS: 0>]}
2020-08-21 08:37:07 DEBUG (MainThread) [zigpy.zcl] [0x0c4f:11:0x0300] ZCL deserialize: <ZCLHeader frame_control=<FrameControl frame_type=GLOBAL_COMMAND manufacturer_specific=False is_reply=True disable_default_response=True> manufacturer=None tsn=192 command_id=Command.Default_Response>
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x0c4f:11:0x0300]: executed 'move_to_color_temp' command with args: '(234, 600.0)' kwargs: '{}' result: [10, <Status.SUCCESS: 0>]
2020-08-21 08:37:07 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining5: turned on: {'move_to_level_with_on_off': [4, <Status.SUCCESS: 0>], 'on_off': [1, <Status.SUCCESS: 0>], 'move_to_color_temp': [10, <Status.SUCCESS: 0>]}
2020-08-21 08:37:11 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x515f:11:0x0008]: command failed: move_to_level_with_on_off exception:
2020-08-21 08:37:11 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining3: turned on: {'move_to_level_with_on_off': TimeoutError()}
2020-08-21 08:37:12 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0x0367:11:0x0006]: command failed: on exception:
2020-08-21 08:37:12 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining6: turned on: {'move_to_level_with_on_off': [4, <Status.SUCCESS: 0>], 'on_off': TimeoutError()}
2020-08-21 08:37:12 DEBUG (MainThread) [homeassistant.components.zha.core.channels.base] [0xfebb:11:0x0300]: command failed: move_to_color_temp exception:
2020-08-21 08:37:12 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining8: turned on: {'move_to_level_with_on_off': [4, <Status.SUCCESS: 0>], 'on_off': [1, <Status.SUCCESS: 0>], 'move_to_color_temp': TimeoutError()}
2020-08-21 08:37:13 DEBUG (MainThread) [homeassistant.components.zha.entity] light.dining6: polling current state - from cache: False
