Try to get started programming but steep learning
I used to program in the past and want to be able to witte my own programs/scripts.
I try to get started with something simple.
I creates a simple switch called thuis
I can show the status in the markup card
Using snarky’s VAR integration I could create a variable X by adding this to the configuration.yaml
What I want is every time I set the switch on is to increase X with 1 and dispaly that in de marup card
I have no clue where to start with this.
I guess I need to wriste a script for that and I tried:
alias: test varx
description: “”
  • platform: state
    entity_id:
    • input_boolean.afwezig
      to: “on”
      condition: []
  • service: notify.persistent_notification
    message: weggegaan
    X=X+1
    But I see nothing happening and when I reload the YAML code that X=X+1 is removed
For starters, please use proper formatting by using this button:image
if not, it’s going to be difficult to see what you’re trying to do, as yaml is very strict in indentation :wink:
Also this is not a community guide (please read the category descriptions). Moved.
I thought this would be a poprer place I created a new topic in community guides with I hope proper formatting
tried to poste the code with copy /paste and added ‘’’ chars before and afters sorry that I do not understand all the buttons I am new here
type or paste code here
Just hit the button, and replace ‘type or paste code here’ with your own code.
Anyway, instead of using a custom integration, it would be easier to use a number helper, and increase that value :wink:
This is being discussed in this other topic:
https://community.home-assistant.io/t/try-to-get-started-programming-but-steep-learning-cruve/526252
I hope I have the proper topic and formatting now after posting in a wrong topic. If it is moved by a moderator please inform me where it goes?
I used to do some programming in the past in Pascal and *051 assembler and I want to be able to witte my own programs/scripts.
I created a simple switch called thuis
I can already show the statusof that switch in the markup card
Using snarky’s VAR integration I could create a variable X by adding this to the configuration.yaml And I also can see the value of X in markup
What I want is every time I set the switch from of to on, to increase X with 1 and dispaly that in de marup card
I guess I need to write a script for that, and I tried this code
alias: test varx
description: ""
  - platform: state
    entity_id:
      - input_boolean.afwezig
    to: "on"
condition: []
  - service: notify.persistent_notification
      message: weggegaan
    X=X+1
I don’t have experience with that integration you used to create a variable, but anyways, I would suggest using the native counter helper instead.
I’m other to do that, go to Settings > Devices and Services, select the tab Helpers and add a helper, selecting Counter as the type you want and following the required steps over there.
After creating the counter, use the counter.increment service in your automation.
Something like this:
alias: test varx
description: ""
  - platform: state
    entity_id:
    to: "on"
condition: []
  - service: counter.increment
    data: {}
      entity_id: counter.your_new_counter
      message: "Counter = {{ states('counter.your_new_counter')}}"
But if you still want to use that integration, then it will be probably something like this (based on their docs, I’ve never used that as I mentioned:
alias: test varx
description: ""
  - platform: state
    entity_id:
    to: "on"
condition: []
  - service: var.set
    data_template:
      entity_id: var.x
      value: "{{ states('var.x') | float(0) + 1.0}}"
      message: "Counter = {{ states('var.x')}}"
Hi Thanks for your feedback.
This counter was just a simple example for testing that I canchage a vatiable after a trigger.
But this enlightens me a lot.
A thing that is simple in programming languages is quite different if you use YAML
At least I now know how much one must type to do such a simple thing like changing a variable a a trigger;)
Just used to a more ‘procedure’‘or function’ call system like I used to build old time state/event engines
BTW the code works;)
As your goal is to learn, there’s another way to solve this which I probably will choose as it concentrates all the settings in a single entity and will probably be easier to maintain, which is using a template sensor.
template:
  - trigger:
      - platform: state
        entity_id:
        to: "on"
      - name: Variable X
        unique_id: any_unique_id_for_variable_x
        state: "{{ states('sensor.variable_x') | float(0) + 1.0 }}"
Merged into this topic. Thanks for the heads up.
Another option for this is to use a History Stats sensor (though this isn’t strictly limited to state changes from ‘off’ to ‘on’):
  - platform: history_stats
    name: Afwezig On Count
    entity_id: input_boolean.afwezig
    state: "on"
    type: count
    start: "{{ 0 }}"
    end: "{{ now() }}"
Yaml (Yet another markup language) is not a programming language at all, but a way of ordering, grouping and storing configuration lines (markup).
The use of templates comes closer and uses Jinja, but it still ain’t a programming language.
HA itself is written in Python, and by the sound of it, you want to have more of a ‘programming’ environment.
For that i think AppDeamon, or Pyscript, come closer, or when you are more in to Java, try NodeRed. Node Ref also takes a while to get used to, but it does enable you to use plain java when needed.
The is also a c# version around somewhere, but can’t find the link right now :yum:
Just a quick FYI. You should probably use this.state in the template instead of getting the value via the states function.
Thnaks all for the info. This sure helps me further.
For programming I think I will take the Java or python way.:slight_smile:
I will look which one I like most, but think the more formal Java might win but I will try some pythong to.
I found a nice turorial on python on W3
