Trying to install Frigate but get, "Failed to Connect"
Just here to reply thank you! This was my solution as well.
That was great thanks
Worked for me also, thank you so much.
Thank you so much. Glad I found your post!!
Hi folks, I have the same issue but all the above didn’t help (or I was unable to find the necessary).
I cannot set up the integration (failure to connect to http://ccab4aaf-frigate-fa:5000/, protocol says “bad gateway”.
I don’t see any stream in the addon. Protocol says: “unable to read frames from ffmpeg process”. It also says that no hardware acceleration can be detected although I habe Coral TPU installed and plugged in.
There are many more messages:
2025-01-17 16:29:03.532163720 [2025-01-17 17:29:03] frigate.app INFO : Starting Frigate (0.14.1-f4f3cfa)
2025-01-17 16:29:03.533700004 [2025-01-17 17:29:03] frigate.app INFO : Creating directory: /tmp/cache
2025-01-17 16:29:03.534518234 [2025-01-17 17:29:03] frigate.util.config INFO : Checking if frigate config needs migration…
2025-01-17 16:29:03.602678974 [2025-01-17 17:29:03] frigate.util.config INFO : frigate config does not need migration…
2025-01-17 16:29:04.456872134 [2025-01-17 17:29:04] frigate.util.services WARNING : Did not detect hwaccel, using a GPU for accelerated video decoding is highly recommended
2025-01-17 16:29:04.797910659 [h264 @ 0x20938240] non-existing PPS 0 referenced
2025-01-17 16:29:04.799379114 [h264 @ 0x20938240] non-existing PPS 0 referenced
2025-01-17 16:29:04.800341538 [h264 @ 0x20938240] decode_slice_header error
2025-01-17 16:29:04.800532223 [h264 @ 0x20938240] no frame!
2025-01-17 16:29:12.021314953 [h264 @ 0x209381c0] non-existing PPS 0 referenced
2025-01-17 16:29:12.022272804 [h264 @ 0x209381c0] non-existing PPS 0 referenced
2025-01-17 16:29:12.022277083 [h264 @ 0x209381c0] decode_slice_header error
2025-01-17 16:29:12.022278819 [h264 @ 0x209381c0] no frame!
2025-01-17 16:29:12.030160215 [h264 @ 0x209381c0] non-existing PPS 0 referenced
2025-01-17 16:29:12.030166560 [h264 @ 0x209381c0] non-existing PPS 0 referenced
2025-01-17 16:29:12.030169037 [h264 @ 0x209381c0] decode_slice_header error
2025-01-17 16:29:12.030171253 [h264 @ 0x209381c0] no frame!
2025-01-17 16:29:12.030177601 [h264 @ 0x209381c0] non-existing PPS 0 referenced
2025-01-17 16:29:12.030180187 [h264 @ 0x209381c0] non-existing PPS 0 referenced
2025-01-17 16:29:12.030255773 [h264 @ 0x209381c0] decode_slice_header error
2025-01-17 16:29:12.030258656 [h264 @ 0x209381c0] no frame!
2025-01-17 16:29:12.032838318 [h264 @ 0x209381c0] non-existing PPS 0 referenced
2025-01-17 16:29:12.033014092 [h264 @ 0x209381c0] non-existing PPS 0 referenced
2025-01-17 16:29:12.033101325 [h264 @ 0x209381c0] decode_slice_header error
2025-01-17 16:29:12.033103878 [h264 @ 0x209381c0] no frame!
2025-01-17 16:29:12.033313907 [h264 @ 0x209381c0] non-existing PPS 0 referenced
2025-01-17 16:29:12.033423510 [h264 @ 0x209381c0] non-existing PPS 0 referenced
2025-01-17 16:29:12.033426779 [h264 @ 0x209381c0] decode_slice_header error
2025-01-17 16:29:12.033428266 [h264 @ 0x209381c0] no frame!
2025-01-17 16:29:14.472311676 [2025-01-17 17:29:14] peewee_migrate.logs INFO : Starting migrations
2025-01-17 16:29:14.476287998 [2025-01-17 17:29:14] peewee_migrate.logs INFO : There is nothing to migrate
2025-01-17 16:29:14.545701664 [2025-01-17 17:29:14] frigate.app INFO : Recording process started: 330
2025-01-17 16:29:14.582357138 [2025-01-17 17:29:14] frigate.app INFO : Recording process started: 335
2025-01-17 16:29:14.645264551 [2025-01-17 17:29:14] frigate.app INFO : go2rtc process pid: 99
2025-01-17 16:29:14.830045527 [2025-01-17 17:29:14] detector.coral INFO : Starting detection process: 360
2025-01-17 16:29:14.935822239 [2025-01-17 17:29:14] frigate.detectors.plugins.edgetpu_tfl INFO : Attempting to load TPU as usb
2025-01-17 16:29:14.936521064 [2025-01-17 17:29:14] frigate.app INFO : Output process started: 362
2025-01-17 16:29:14.942722272 [2025-01-17 17:29:14] frigate.detectors.plugins.edgetpu_tfl ERROR : No EdgeTPU was detected. If you do not have a Coral device yet, you must configure CPU detectors.
2025-01-17 16:29:14.943370908 Process detector:coral:
2025-01-17 16:29:14.991149872 Traceback (most recent call last):
2025-01-17 16:29:14.994064384 File “/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py”, line 160, in load_delegate
2025-01-17 16:29:14.994069873 delegate = Delegate(library, options)
2025-01-17 16:29:14.994204727 File “/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py”, line 119, in init
2025-01-17 16:29:14.994207529 raise ValueError(capture.message)
2025-01-17 16:29:14.994279843 ValueError
2025-01-17 17:29:21.051304 2025-01-17 16:29:14.994331043
2025-01-17 16:29:14.994333394 During handling of the above exception, another exception occurred:
2025-01-17 17:29:21.051359 2025-01-17 16:29:14.994334834
2025-01-17 16:29:14.994369950 Traceback (most recent call last):
2025-01-17 16:29:14.996094477 File “/usr/lib/python3.9/multiprocessing/process.py”, line 315, in _bootstrap
2025-01-17 16:29:14.996099255 self.run()
2025-01-17 16:29:14.996900405 File “/usr/lib/python3.9/multiprocessing/process.py”, line 108, in run
2025-01-17 16:29:14.996905531 self._target(*self._args, **self._kwargs)
2025-01-17 16:29:14.997066082 File “/opt/frigate/frigate/object_detection.py”, line 102, in run_detector
2025-01-17 16:29:14.997070247 object_detector = LocalObjectDetector(detector_config=detector_config)
2025-01-17 16:29:15.005318045 File “/opt/frigate/frigate/object_detection.py”, line 53, in init
2025-01-17 16:29:15.005324639 self.detect_api = create_detector(detector_config)
2025-01-17 16:29:15.005327291 File “/opt/frigate/frigate/detectors/init.py”, line 18, in create_detector
2025-01-17 16:29:15.005329309 return api(detector_config)
2025-01-17 16:29:15.005331655 File “/opt/frigate/frigate/detectors/plugins/edgetpu_tfl.py”, line 41, in init
2025-01-17 16:29:15.005333948 edge_tpu_delegate = load_delegate(“libedgetpu.so.1.0”, device_config)
2025-01-17 16:29:15.005336911 File “/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py”, line 162, in load_delegate
2025-01-17 16:29:15.005343904 raise ValueError(‘Failed to load delegate from {}\n{}’.format(
2025-01-17 16:29:15.005346704 ValueError: Failed to load delegate from libedgetpu.so.1.0
2025-01-17 17:29:21.051593 2025-01-17 16:29:15.005348330
2025-01-17 16:29:15.084490302 [2025-01-17 17:29:15] frigate.app INFO : Camera processor started for nord: 393
2025-01-17 16:29:15.245355267 [2025-01-17 17:29:15] frigate.app INFO : Camera processor started for ost: 397
2025-01-17 16:29:15.245364102 [2025-01-17 17:29:15] frigate.app INFO : Camera processor started for sued: 400
2025-01-17 16:29:15.245367029 [2025-01-17 17:29:15] frigate.app INFO : Capture process started for nord: 403
2025-01-17 16:29:15.276095137 [2025-01-17 17:29:15] frigate.app INFO : Capture process started for ost: 419
2025-01-17 16:29:15.287852170 [2025-01-17 17:29:15] frigate.app INFO : Capture process started for sued: 431
2025-01-17 16:29:16.005116113 [2025-01-17 17:29:16] frigate.video ERROR : sued: Unable to read frames from ffmpeg process.
2025-01-17 16:29:16.008117263 [2025-01-17 17:29:16] frigate.video ERROR : sued: ffmpeg process is not running. exiting capture thread…
2025-01-17 16:29:18.132211979 [2025-01-17 17:29:18] frigate.util.services ERROR : Unable to poll vainfo: b"error: XDG_RUNTIME_DIR is invalid or not set in the environment.\nerror: can’t connect to X server!\nlibva info: VA-API version 1.17.0\nlibva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/simpledrm_drv_video.so\nlibva info: va_openDriver() returns -1\nvaInitialize failed with error code -1 (unknown libva error),exit\n"
2025-01-17 16:29:18.159160161 [2025-01-17 17:29:18] frigate.util.services ERROR : Unable to poll intel GPU stats: No device filter specified and no discrete/integrated i915 devices found
2025-01-17 17:29:21.051628 2025-01-17 16:29:18.159165195
2025-01-17 16:29:18.772059731 [2025-01-17 17:29:18] frigate.video ERROR : nord: Unable to read frames from ffmpeg process.
2025-01-17 16:29:18.778141291 [2025-01-17 17:29:18] frigate.video ERROR : nord: ffmpeg process is not running. exiting capture thread…
2025-01-17 16:29:18.972588236 [2025-01-17 17:29:18] frigate.video ERROR : ost: Unable to read frames from ffmpeg process.
2025-01-17 16:29:18.974148469 [2025-01-17 17:29:18] frigate.video ERROR : ost: ffmpeg process is not running. exiting capture thread…
Here’s my frigate.yml:
mqtt:
  enabled: true
  host: core-mosquitto
  port: 1883
  topic_prefix: frigate
  client_id: frigate
  user: *User*
  password: *Password*
  stats_interval: 30
database:
  path: /config/frigate.db
detectors:
  coral:
    type: edgetpu
    device: usb
birdseye:
  enabled: true
  restream: true
  mode: continuous
objects:
  track:
    - person
  filters:
    person:
      min_score: 0.6
      min_area: 20000
cameras:
  nord:
    ffmpeg:
      hwaccel_args: preset-vaapi
      inputs:
        - path: rtsp://*user:password*@192.168.2.64:88/videoMain
          roles:
            - record
        - path: rtsp://*user:password*@192.168.2.64:88/videoSub
          roles:
            - detect
    record:
      enabled: True
    detect:
      enabled: False
    birdseye:
      order: 0
  ost:
    ffmpeg:
      inputs:
        - path: rtsp://*user:password*@192.168.2.62:88/videoMain
          roles:
            - record
        - path: rtsp://*user:password*@192.168.2.62:88/videoSub
          roles:
            - detect
    record:
      enabled: True
    detect:
      enabled: False
    birdseye:
      order: 1
  sued:
    ffmpeg:
      inputs:
        - path: rtsp://*user:password*@192.168.2.60:554/videoMain
          roles:
            - record
        - path: rtsp://*user:password*@192.168.2.60:554/videoSub
          roles:
            - detect
    record:
      enabled: True
    detect:
      enabled: False
    birdseye:
      order: 2
ui:
  timezone: Europe/Berlin
  time_format: 24hour
  strftime_fmt: '%d.%m.%Y- %H:%M'
version: 0.14
Please, I’m very grateful for support.
First thing for me is where did your frigate url come from? That looks odd to me. Have you tried just the ip address:5000? Also what platform are you running frigate on? You mentioned a coral tpu, but it would be helpful to know how you installed frigate and on what.
I run Home Assistant with the Virtual Box on a Mac mini and want to use the Frigate addon as well as the integration.
The URL is given in the documentation for the frigate integration and is the hostname that appears in the addon when running. I already tried IP:5000 as you suggested. It also fails.
Addendum: issue solved, just a little typing error…
Thank you! Your solution finally helped me after 2 hours of soulbreaking attempts
Could you please someone check my logs?
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service go2rtc-healthcheck: stopping
s6-rc: info: service certsync: stopping
2025-03-30 16:22:31.580344806  [INFO] The go2rtc-healthcheck service exited with code 256 (by signal 15)
2025-03-30 16:22:31.581048080  [INFO] Service CERTSYNC exited with code 256 (by signal 15)
s6-rc: info: service go2rtc-healthcheck successfully stopped
s6-rc: info: service certsync successfully stopped
s6-rc: info: service nginx: stopping
s6-rc: info: service certsync-log: stopping
s6-rc: info: service certsync-log successfully stopped
2025-03-30 16:22:31.605195063  [INFO] Service NGINX exited with code 0 (by signal 0)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service nginx-log: stopping
s6-rc: info: service frigate: stopping
s6-rc: info: service nginx-log successfully stopped
2025-03-30 16:22:31.753282098  [2025-03-30 18:22:31] frigate.app                    INFO    : Stopping...
2025-03-30 16:22:31.754816789  [2025-03-30 18:22:31] frigate.events.cleanup         INFO    : Exiting event cleanup...
2025-03-30 16:22:31.755139675  [2025-03-30 18:22:31] frigate.ptz.autotrack          INFO    : Exiting autotracker...
2025-03-30 16:22:31.755371934  [2025-03-30 18:22:31] frigate.stats.emitter          INFO    : Exiting stats emitter...
2025-03-30 16:22:31.756228728  [2025-03-30 18:22:31] frigate.watchdog               INFO    : Exiting watchdog...
2025-03-30 16:22:31.756495964  [2025-03-30 18:22:31] frigate.storage                INFO    : Exiting storage maintainer...
2025-03-30 16:22:31.756746354  [2025-03-30 18:22:31] frigate.record.cleanup         INFO    : Exiting recording cleanup...
2025-03-30 16:22:31.758321551  [2025-03-30 18:22:31] frigate.app                    INFO    : Waiting for capture process for name_of_your_camera to stop
2025-03-30 16:22:31.761006546  [2025-03-30 18:22:31] watchdog.name_of_your_camera   INFO    : Terminating the existing ffmpeg process...
2025-03-30 16:22:31.761010644  [2025-03-30 18:22:31] watchdog.name_of_your_camera   INFO    : Waiting for ffmpeg to exit gracefully...
2025-03-30 16:22:31.995660664  [2025-03-30 18:22:31] frigate.object_processing      INFO    : Exiting object processor...
2025-03-30 16:22:32.038533024  [2025-03-30 18:22:32] frigate.app                    INFO    : Waiting for process for name_of_your_camera to stop
2025-03-30 16:22:32.580258943  [2025-03-30 18:22:32] frigate.events.maintainer      INFO    : Exiting event processor...
2025-03-30 16:22:33.020721353  [2025-03-30 18:22:33] frigate.video                  INFO    : name_of_your_camera: emptying frame queue
2025-03-30 16:22:33.021362240  [2025-03-30 18:22:33] frigate.video                  INFO    : name_of_your_camera: exiting subprocess
2025-03-30 16:22:33.027211137  [2025-03-30 18:22:33] frigate.app                    INFO    : Closing frame queue for name_of_your_camera
2025-03-30 16:22:34.029527181  [2025-03-30 18:22:34] frigate.app                    INFO    : Detection queue closed
2025-03-30 16:22:34.530680146  [2025-03-30 18:22:34] frigate.app                    INFO    : Detected frames queue closed
2025-03-30 16:22:35.031867637  [2025-03-30 18:22:35] frigate.app                    INFO    : Timeline queue closed
2025-03-30 16:22:36.377876780  [2025-03-30 18:22:36] frigate.output.output          INFO    : exiting output process...
2025-03-30 16:22:43.246763277  [INFO] Service Frigate exited with code 0 (by signal 0)
s6-rc: info: service frigate successfully stopped
s6-rc: info: service go2rtc: stopping
s6-rc: info: service frigate-log: stopping
2025-03-30 16:22:43.249620466  exit with signal: terminated
s6-rc: info: service frigate-log successfully stopped
2025-03-30 16:22:43.255948430  [INFO] The go2rtc service exited with code 0 (by signal 0)
s6-rc: info: service go2rtc successfully stopped
s6-rc: info: service go2rtc-log: stopping
s6-rc: info: service go2rtc-log successfully stopped
s6-rc: info: service log-prepare: stopping
s6-rc: info: service s6rc-fdholder: stopping
s6-rc: info: service log-prepare successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service s6rc-fdholder successfully stopped
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-fdholder: starting
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service s6rc-fdholder successfully started
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service log-prepare: starting
s6-rc: info: service log-prepare successfully started
s6-rc: info: service nginx-log: starting
s6-rc: info: service go2rtc-log: starting
s6-rc: info: service frigate-log: starting
s6-rc: info: service certsync-log: starting
s6-rc: info: service go2rtc-log successfully started
s6-rc: info: service go2rtc: starting
s6-rc: info: service nginx-log successfully started
s6-rc: info: service frigate-log successfully started
s6-rc: info: service certsync-log successfully started
s6-rc: info: service go2rtc successfully started
s6-rc: info: service go2rtc-healthcheck: starting
s6-rc: info: service frigate: starting
s6-rc: info: service go2rtc-healthcheck successfully started
2025-03-30 16:22:47.846541044  [INFO] Preparing new go2rtc config...
s6-rc: info: service frigate successfully started
s6-rc: info: service nginx: starting
2025-03-30 16:22:47.858973436  [INFO] Preparing Frigate...
2025-03-30 16:22:47.885191293  [INFO] Starting NGINX...
2025-03-30 16:22:47.936628170  [INFO] No TLS certificate found. Generating a self signed certificate...
2025-03-30 16:22:47.985911719  [INFO] Got IP address from supervisor: 192.168.137.226
2025-03-30 16:22:48.075628276  [INFO] Got WebRTC port from supervisor: 8555
2025-03-30 16:22:48.137445142  [INFO] Starting Frigate...
2025-03-30 16:22:49.232629183  [INFO] Starting go2rtc...
2025-03-30 16:22:49.530683446  18:22:49.529 INF go2rtc platform=linux/amd64 revision=b2399f3 version=1.9.2
2025-03-30 16:22:49.530688444  18:22:49.529 INF config path=/dev/shm/go2rtc.yaml
2025-03-30 16:22:49.530690186  18:22:49.530 INF [rtsp] listen addr=:8554
2025-03-30 16:22:49.530691772  18:22:49.530 INF [webrtc] listen addr=:8555/tcp
2025-03-30 16:22:49.536925821  18:22:49.536 INF [api] listen addr=:1984
s6-rc: info: service nginx successfully started
s6-rc: info: service certsync: starting
s6-rc: info: service certsync successfully started
s6-rc: info: service legacy-services: starting
2025-03-30 16:22:50.983760468  [INFO] Starting certsync...
s6-rc: info: service legacy-services successfully started
2025-03-30 16:22:51.156631231  127.0.0.1 - - [30/Mar/2025:18:22:51 +0200] "" 400 0 "-" "-" "-"
2025-03-30 16:22:52.066825102  [2025-03-30 18:22:52] frigate.util.config            INFO    : Checking if frigate config needs migration...
2025-03-30 16:22:52.075331617  [2025-03-30 18:22:52] frigate.util.config            INFO    : frigate config does not need migration...
2025-03-30 16:22:52.125277812  [2025-03-30 18:22:52] frigate.util.services          WARNING : Did not detect hwaccel, using a GPU for accelerated video decoding is highly recommended
2025-03-30 16:22:52.773828504  2025/03/30 18:22:52 [error] 171#171: *2 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "127.0.0.1:5000"
2025-03-30 16:22:52.774229476  2025/03/30 18:22:52 [error] 171#171: *2 auth request unexpected status: 502 while sending to client, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", host: "127.0.0.1:5000"
2025-03-30 16:22:53.637577177  [2025-03-30 18:22:53] frigate.app                    INFO    : Starting Frigate (0.15.0-cea210d)
2025-03-30 16:22:53.639400632  [2025-03-30 18:22:53] frigate.app                    INFO    : Creating directory: /tmp/cache
2025-03-30 16:22:53.644924582  [2025-03-30 18:22:53] peewee_migrate.logs            INFO    : Starting migrations
2025-03-30 16:22:53.646116077  [2025-03-30 18:22:53] peewee_migrate.logs            INFO    : There is nothing to migrate
2025-03-30 16:22:53.666294125  [2025-03-30 18:22:53] frigate.app                    INFO    : Recording process started: 254
2025-03-30 16:22:53.666298395  [2025-03-30 18:22:53] frigate.app                    INFO    : Review process started: 258
2025-03-30 16:22:53.674952156  [2025-03-30 18:22:53] frigate.app                    INFO    : go2rtc process pid: 98
2025-03-30 16:22:53.699559014  [2025-03-30 18:22:53] detector.coral                 INFO    : Starting detection process: 270
2025-03-30 16:22:53.702919424  [2025-03-30 18:22:53] frigate.detectors.plugins.edgetpu_tfl INFO    : Attempting to load TPU as usb
2025-03-30 16:22:53.723467112  Process detector:coral:
2025-03-30 16:22:53.723470971  Traceback (most recent call last):
2025-03-30 16:22:53.723472128    File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 160, in load_delegate
2025-03-30 16:22:53.723473060      delegate = Delegate(library, options)
2025-03-30 16:22:53.723477391    File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 119, in __init__
2025-03-30 16:22:53.723495443      raise ValueError(capture.message)
2025-03-30 16:22:53.723496381  ValueError
2025-03-30 16:22:53.723497068
2025-03-30 16:22:53.723498362  During handling of the above exception, another exception occurred:
2025-03-30 16:22:53.723499068
2025-03-30 16:22:53.723499790  Traceback (most recent call last):
2025-03-30 16:22:53.723500675    File "/usr/lib/python3.9/multiprocessing/process.py", line 315, in _bootstrap
2025-03-30 16:22:53.723528578      self.run()
2025-03-30 16:22:53.723529688    File "/opt/frigate/frigate/util/process.py", line 41, in run_wrapper
2025-03-30 16:22:53.723530587      return run(*args, **kwargs)
2025-03-30 16:22:53.723531469    File "/usr/lib/python3.9/multiprocessing/process.py", line 108, in run
2025-03-30 16:22:53.723549276      self._target(*self._args, **self._kwargs)
2025-03-30 16:22:53.723550365    File "/opt/frigate/frigate/object_detection.py", line 121, in run_detector
2025-03-30 16:22:53.723551362      object_detector = LocalObjectDetector(detector_config=detector_config)
2025-03-30 16:22:53.723552193    File "/opt/frigate/frigate/object_detection.py", line 68, in __init__
2025-03-30 16:22:53.723552998      self.detect_api = create_detector(detector_config)
2025-03-30 16:22:53.723553841    File "/opt/frigate/frigate/detectors/__init__.py", line 18, in create_detector
2025-03-30 16:22:53.723554537      return api(detector_config)
2025-03-30 16:22:53.723567667    File "/opt/frigate/frigate/detectors/plugins/edgetpu_tfl.py", line 41, in __init__
2025-03-30 16:22:53.723568708      edge_tpu_delegate = load_delegate("libedgetpu.so.1.0", device_config)
2025-03-30 16:22:53.723569646    File "/usr/lib/python3/dist-packages/tflite_runtime/interpreter.py", line 162, in load_delegate
2025-03-30 16:22:53.723570578      raise ValueError('Failed to load delegate from {}\n{}'.format(
2025-03-30 16:22:53.723571371  ValueError: Failed to load delegate from libedgetpu.so.1.0
yaml file:
mqtt:
  enabled: True
  host: 192.168.137.226
  port: 1883
  client_id: frigate
  user: mqtt-user
  password: xxxx
  stats_interval: 60
detectors:
    coral:
        type: edgetpu
        device: usb
cameras:
  name_of_your_camera: # <------ Name the camera
    enabled: true
    ffmpeg:
      inputs:
        - path: rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0 # <----- The stream you want to use for detection
          roles:
            - detect
    detect:
      enabled: false # <---- disable detection until you have a working camera feed
version: 0.15-1
go2rtc:
  streams:
    back:
      - rtsp://admin:[email protected]:554/cam/realmonitor?channel=1&subtype=0
I can start addon, and I see video from my camera but only for like 1 min, after that it loses the connection. I cannot make integration as well because there is nothing under http://ccab4aaf-frigate-fa:5000/
are you using “Full Access” version? if so, try http://ccab4aaf-frigate-fa:5000/
omg thanks, solved that for me, the integration popup is pretty confusing as it explicitly tell you do use the non-fa
Couple years old, but adding the -fa fixed it for me today. Thanks!
