Hey everyone, I’m pretty new to all this automation stuff. I have a specific plug that I want to turn on for X amount of hours but turn off for 10 minutes every 5 hours. Is this at all possible with Home Assistant automations?
There are a few ways to do this here is one method: Automation Device on x minutes off y minutes - #2 by Didgeridrew
Thank you for this. This is the current automation I’m using for my switch.
alias: Switch Timer
description: ""
- platform: state
entity_id:
- switch.living_room_tv
to: "on"
for:
hours: "{{ states.input_number.break_in_switch_time.state | int }}"
minutes: 0
seconds: 0
condition: []
- service: switch.turn_off
data: {}
I’d like to integrate your script with this one. Currently the way I set my timer is a slider card, I’d like to keep this part the same. Basically I just want the switch to turn off every 5 hours for 10 minutes if it’s on. This switch is controlling a machine that runs for different durations.
Basically, say I want the switch to be on for 34 hours but every 5 hours I want it to shut off so it doesn’t over heat. Is there a way to script it so that when it turns back on the timer wont restart.
Can you clarify what you mean?
So say I want it to run for 36 hours. I want it to turn off for 10 minutes every 5 hours but I want the 36 hour timer to resume from wherever it left off before that 5 hour mark. Hopefully that makes sense.
36 > 5 hour mark 10 minute off state then back on > 31 hours remaining.
How will you be triggering the long cycle?
What happens at the end of the long cycle?
Triggering it with a toggle entity card and after the long cycle it just shuts off until I manually start it again.
