Ttlock support
@kind3r your integration works beautifully, thank you! Is there any way to trigger automations when the lock is opened? I could not find any related entities or events. Much appreciated!
hey guys is this still working before i attempt it?
thanks!
i got it to work a few weeks ago !!!
Thanks man I’ll give it a try, I know it’s going to go wrong I can’t wait haha
Could someone please make a easy guide?
Definite need to expose TTLOCKs on my Lovelace Dashboard. But I’m a novice and I’m lost at step #1. Anyone working on a custom integration?
Hiya, I have a quick question about this, a novice one. I purchased simpled smartlock which is based on TTLOCK. it’s bluetooth based and they sell a gateway that will then allow this to be link to my network. However, I’m just wondering if it’s possible to use bluetooth proxy (ESP32) to connect to this? Thanks
I spent the weekend starting on implementing this via a custom integration to try and simplify this whole setup.
Got the basics working as start, my next plan is to integrate the webhooks for realtime notifications for lock/unlock events.
If you try it out, I’d love to hear from you!
Hi Sthope,
it still using cloud?
I am a new TTLock user.
My lock had issues, the shaft doesn’t match the key lock chamber, so my handyman grind the shaft size down to fit in.
Now the lock doesn’t open/close at all.
just wondering if the lock got damaged or not?
I have one more new lock in hand with the same issue, shaft doesn’t fit. Who and where is the support I should contact with/to?
Thanks for any of your help in advance!
