thanks
Alexa doesn’t support notifications yet. Hopefully this will come soon!
Hope too! !
Are HASS and VLC on the same machine (IP) are you are serving trying to serve TTS to VLC on a another machine?
I forgot to mention that after changing the VLC volume, tts works flawesly!
How do you install VLC and how do you change the volume?
% sudo apt-get update % sudo apt-get install vlc browser-plugin-vlc
And I was using the ubuntu gui to change the volume
Thanks. I do this on Raspberry Pi 3.
sudo apt-get install vlc-nox
Do I need to change the volume?
I tried the nox version but it did not worked for me at all.
i see. in that case do i need to uninstall vlc-nox? why do i need to install browser-plugin-vlc? I am installing this on a headless server.
You should check beforehand on Google how to change VLC volume in cmd.
I didn’t had the time to mess around if I need the browser plugin or not so I just installed the whole package.
how do you make it works? From my understanding, in order to make HA “speak” thru a speaker attached to the Raspberry Pi, I need to install VLC media player using sudo apt-get install vlc-nox and add this to the configuration.yaml
media_player:
- platform: vlc
tts:
- platform: google
After that, I have to call the TTS service in my automation. For example…
- alias: 'Forecast Alert'
platform: state
entity_id: sensor.owm_forecast
- service: tts.google_say
entity_id: media_player.vlc
data_template:
message: "The weather forecast is now {{ trigger.to_state.state }}."
However, it was not working. Am I wrong somewhere?
I think you have the same problem that i had…
VLC works ? Can you test to play file on it in command line ?
Erm… how to do that? I can see there is an MP3 generated in the log. When I went directly to the URL (https://192.168.1.111:8123/api/tts_proxy/e66331a59a8c091a7723736291267e6741d21ac4_google.mp3) in my browser, it plays nicely.
So you need to go to terminal where your mp3 is
And execute vlc name.mp3
I only have the URL. Where do you think is the path to the mp3 file?
Anyway, I manage to play another MP3 file using the suggested command and it was successful.
the process hass runs with which username ?
the path of mp3 is configured in your config
`tts:
- platform: google
cache: true
cache_dir: /tmp/tts
time_memory: 300`
