thats a sticky situation. You could change your automation to just look at the to_state instead of from:off to:on
Create a binary sensor around the motion sensor with âdelay_offâ set to 10 seconds. Will delay the reported âoffâ by 10 seconds. If the state of the motion goes back to true during that 10 seconds it will not turn off.
Then you automation doesnât change except for the binary_sensor that is the trigger.
Related example; but with delay_on but delay_off works the same way:
garage_door_stuck:
friendly_name: Garage Door Stuck
device_class: garage_door
value_template: "{{ is_state('binary_sensor.garage_door_detected', 'on') }}"
delay_on:
minutes: 10
You donât have a timer extend function? In openHAB we know the timer exists and is it null, and in subsequent actions can say reschedule the timer for another 5 mins.
But thatâs an edge case somewhat.
I did once try this
- wait_template: "{{as_timestamp(now()) - as_timestamp(states.binary_sensor.centralite_3326l_0e33c46e_1_1280.last_changed) > 10 }}"
But I could not get that to work, lights came on, but of never turned off.
So, based on your feedback, This look good?
binary_sensors.yaml (called from my configuration.yaml)
sensors:
motion_delay_kitchen:
friendly_name: Kitchen Lighting motion delay
value_template: "{{ is_state('binary_sensor.centralite_3326l_0e33c46e_1_1280', 'on') }}"
delay_off:
seconds: 15
Then automation.yaml
- alias: Motion Lighting in the Kitchen
- platform: state
entity_id: binary_sensor.centralite_3326l_0e33c46e_1_1280
to: 'on'
condition:
- condition: state
entity_id: group.kitchen_zwave_lights
state: 'off'
- condition: state
entity_id: sun.sun
state: 'below_horizon'
- service: homeassistant.turn_on
- wait_template: "{{ is_state('binary_sensor.motion_delay_kitchen', 'off') }}"
- condition: state
state: 'on'
- service: homeassistant.turn_off
Nice trick, thanks everyone for the ideas.
Edit: I did go back and make one change. Iâm going to keep the trigger as the motion sensor, but the wait to the new binary sensor. I figure that will be slgihtly faster triggering the lights to on. One less thing to monitor
@petro I have an other need
When I open a door Iâd like to turn on a light.
When I close the door⌠Turn the light off.
Iâm sorry to disturb you again for simple stuff but with my actual knowledge I need to create 2 " - alias : " automation
Creating 2 de-activable items in front panelâŚ
Thanks again
Finaly I got it
- alias: 'Grenier'
- platform: state
entity_id: binary_sensor.nano_grenier_4_3
to: 'on'
- service: switch.turn_on
entity_id: switch.nano_grenier_4_2
- wait_template: "{{ is_state('binary_sensor.nano_grenier_4_3', 'off') }}"
- service: switch.turn_off
Looks good. I think itâs a matter of style and opinion on keeping the trigger and wait as you have them.
In my opinion Iâd base them both off motion_delay_kitchen as that way if something got buggered in a future release you would be more likely to notice the entire automation not working; versus partially. As you have it you could end up with a split-brain situation.
But I also respect your âneed for speedâ
Yep, you got it. Thatâs the purpose of wait templates. Good use of it!
Thanks again for the help. The binary sensor template idea was great. Worked perfect last night. Tonight, Iâll swap it to use the binary sensor as the trigger too, and see if I can tell any difference in speed.
Even on a rPI1 you will not notice
would there be any difference in placing the delay? in your configuration you place it at the binary_sensor , others have put it at the wait_template calling the binary_sensor.
secondly, since I cant find any reference in this thread, what s the difference with the for:
statement?
example:
- id: Switch Bedside table off when room left
alias: "Switch Bedside table off when room left"
initial_state: 'on'
platform: state
entity_id: sensor.master_bedroom_motion_sensor
to: 'off'
for:
minutes: 10
condition:
condition: state
entity_id: binary_sensor.activity_opstaan
state: 'on'
- service: light.turn_off
entity_id: light.bedside_table
- condition: state
entity_id: input_boolean.notify_notify
state: 'on'
- service: notify.notify
data_template:
message: '{{as_timestamp(now()) | timestamp_custom("%X") }}: Bedside table is turned down.'
havent tested it yet since it hasnât happened , but i was hoping this would take care of motion occurring during the time the triggering sensor is off, turning it on again?..
not yet a formal binary_sensor, but a sensor with only states On and OffâŚ
Is this a good and sure way (even after restart HA) to turn on and off an entity after X hours?
## Turn on Hall Light when leaving for work
- alias: Turn On Bathroom Heater
platform: time
at: '05:45:00'
condition:
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
entity_id: switch.sonoffs20_1
- alias: 'Turn Off Bathroom Heater'
platform: state
to: "on"
for: '02:00:00'
