I can play TTS without issues but if I play an mp3 file from my home assistant media, it only stutters.
Any solution to this issue? I can see that it was working prior to February of this 2023, and an update might have broken the capability to play mp3 files.
It plays from HTTP but not HTTPS, also pay attention to file name, should be simple latin without spacing, use underline. Also it does not play high bitrate music. Did you manage to get stereo mode working? Im using two MAX98357A boards, however they work in mono mode.
is that the MQTT setup? Any link to find info about the setup?
I am trying to play a 5 second audio located in the “Media” folder of my HA. I have set up my to Stereo mode and my TTL works fine. It also works in Mono mode.
Just been wondering how long a nest mini takes to go to sleep.
I have a group of them that I only use for notification /announcements. (have a second set to use for voice commands etc)
I’ve been wondering how often you’d need to send just a “ping” of some sort (like a 1 second silent MP3 file) just to keep them “awake” so you don’t get the wake up chime…
Only issue with this is if you send a command to do a notification and then the “ping” happens to get sent right after it would kill the notification…
Yea, was wondering about my speaker as well. It goes to sleep after 5 minutes of inactivity. I was thinking of sending a silent mp3 file every so often, but my setup has quit working for quite sometimes and there are a handful users on the same boat.
Doesn’t look like it will be fix. I also been searching for a way to revert back to an older version with my esphome setup. Found one way, but not been tested.
Another option is to create a script for anything sent to that device (using variables sent from the Automation) and then set the script run mode to ‘queued’.
I do this for my Google Home in my kitchen so that various messages that may be triggered to send to it when there is motion in the kitchen all get queued one after the other. You could queue your messages with the ‘ping’ audio clip in the one script.
I found this thread still open on a tab on my old server. I just wanted to say, I’m going on over two years of running these notifiers in my home. I have five of them, and I still love them.
I was curious if there has been any updates on this project. If I remember correctly, I’m running the Schmurz fork/flavor on mine. He had implemented some more features and whatnot from the original Mr DIY project code.
If anyone has the ability, I would like to add a feature request. When these boot up it plays a guitar sound. Maybe some sort of time check and if it’s later/after hours they don’t fire off that guitar sound in the event the Wifi reconnects. My biggest issue is having these in a bedroom and getting woken up in the night to that sound firing off…
Also, is there extra/enough storage space that we could put one more sound on it? I would like a doorbell please I tried streaming a doorbell sound from a local server a few different ways and it’s choppy and terrible.
i got a box with the same fork i think, put it together for fun to see if it was in fact possible to do with a 8266 and it was, but since there is so many better options today i never really used it. consider the new esp32s3 if you plan to play with voice assistant, or esp32 wrover for music player, both of these have psram which is used for audio encode/decode, the wrover is a bit older but is supported by the esp project “squeezelite” that gives you all a sonos speaker would, including multiroom.
if anyone was to update this project i think they should do it for the esp32c3 (the new 8266) and/or esp32s3 (the new esp32) - both of these are available in “supermini” versions which are really tiny
