Pretty good blueprint!
Could you please consider expanding this so that the HVAC will be paused if the door/window sensor(s)group(s) are already opened when the HVAC device is turned on?
Hi!
This blueprint is lovely but seems a bit inconsistent for me. Maybe about half the time, this doesnât turn my HVAC back on. It leaves it in the off position. Iâm noticing it mostly when the door or windows have been open for a while. Is there some sort of a timeout either in Home Assistant or this automation?
Thanks!
Hey glad you like the idea of the automation. There is no timeout in either homeassistant or in the automation. Some possible scenarios that could cause the issue would be if you are restarting either homeassistant or whatever you have homeassistant running on while the HVAC system is in the âpausedâ state. It will not pick up where it left off due to current limitations with the scene creation process in homeassistant.
The other possibility I could see is if your sensors donât have the greatest connection and become unavailable while the HVAC system is in the âpausedâ state. To possibly correct this scenario you could try to edit the code by going to the
- wait_for_trigger:
section towards the bottom and where it says
to: off
try deleting the part that says
If you decide to edit the code donât forget to either reload the automations or just restart homeassistant.
Hope this helps you out.
Is it possible to create 2 automations based on this blueprint for 2 different HVAC at home?
For what I see the scene_id is fixed, so when the second automation is triggered, if the other one is already triggered it tries to create the same scene_id so it doesnât works.
It is possible to setup the scene_id name based on the HVAC entity that is controlling?
Thanks for the reply! Iâm actually experiencing a slightly different issue now (and Iâm not sure when it changed). This blueprint is, indeed, successfully stopping and restarting my HVAC but itâll only return my ecobee to a permanent âholdâ state, and not the comfort setting that it was set to before the automation occurred. Any ideas?
Thanks again! This is definitely one of my favorite automations I have going, even if just to turn the HVAC off.
Hey sorry for the late reply. Iâm not terribly certain on if it is possible but I will definitely look into that. I like the idea.
Hey glad to hear it is working so I had the same issue but I was able to fix it using the âResume Actionâ built into the blueprint. In HA for ecobee there is a button press to âclear holdâ. Using the âResume Actionâ I added in a âwait for triggerâ to look for when the ecobee goes âfrom offâ leaving the âtoâ field blank and then an action after that which triggers the âclear holdâ button. The wait for trigger option is probably not necessary but it catches any issues if there is a slow down on the network. I also made the âcontinue on timeoutâ option in the âwait for triggerâ action 5 seconds just to make sure it triggers. Once the âclear holdâ button is triggered your ecobee will resume the normal schedule.
Your suggestion has been implemented in version 1.5. Thank you for the idea! Let me know if you decide to use it how it works for you!
Thanks so much for the reply! This seems to be exactly what Iâm looking for. However, Iâm not seeing the âfrom offâ field. Only Home, Away, and Sleep. Screenshot attached. Thanks again!
Update: I edited the YAML, so will test to see if that works. Thanks!!
I believe you are currently using the âselectâ entity, you want the âclimateâ entity, which is the ecobee itself, then you should have the âoffâ option.
The device should be âclimate.main_floorâ instead of âselect.main_floor_current_modeâ
Awesome blueprint, and hereâs a request: Add the ability to trigger extra actions immediately when the door opens (flash some lights, notify) and then if it stayed open for the entire delay run the already existing actions. Maybe have two triggers?
Would be nice if the climate entity gets adjusted while itâs still paused to cancel returning it to old state when it gets triggered by sensor being off. hope that makes sense. hereâs an example: my ac was set to cool, then I opened a window and it got paused, while it was paused I have turned it on and set it to âfanâ mode to improve air circulation. but when I close the window it goes back to cool mode, Iâd rather keep it at âfanâ to avoid confusion.
I have it already set to look at the status of the HVAC system to make sure it is off but checking it, the fan status apparently is not taken into account when determining if it is off. I can add in a line to verify the fan is in auto as well.
Sorry I have been away from this all for a while, been busy moving and I am just now getting all my automations restored.
I think the best way to achieve what you are looking for would be to manually edit some code. If you take this section:
- service: scene.create
scene_id: "{{ name_id }}"
snapshot_entities: !input climate_device
- service: climate.set_hvac_mode
entity_id: !input climate_device
hvac_mode: 'off'
- choose:
- conditions: '{{ pause_action is defined }}'
sequence: !input pause_action
And re-order it as this:
- choose:
hvac_mode: 'off'
Your custom pause actions will happen before anything is changed. Doing this you can set up the blueprint pause delay to 0 and then create custom choose
actions for your pause_action
in the blueprint to do exactly as you described.
This is my first Blueprint added to my HA, and this is awesome. I really appreciate the work youâve done with this one. I saw the comment where someone else had asked for a timeout where if the window is not closed after a certain amount of time, it requires manual input to the thermostat to turn it back on. This would be an amazing feature, but doesnât make or break this blueprint.
Thank you for your feedback! Since there are multiple requests Iâll look into adding this as an optional selector.
