I know this is an old post but just to let you know I found your example was exactly what I was looking for. Thanks
Find below my config sample which allow to turn on the light on motion is on and turn it off after 30s:
a) The script
script_entrance_night_light:
alias: Night Light at Entrance
sequence:
- data:
brightness_pct: 5
entity_id: light.yeelight_white_xxxxxx
service: light.turn_on
- delay: '30'
- data:
service: light.turn_off
b) Automation:
- alias: Entrance Night Light On
- entity_id: binary_sensor.motion_sensor_xxxx
platform: state
to: 'on'
condition:
- condition: state
entity_id: sun.sun
state: below_horizon
- condition: state
state: 'off'
- data:
entity_id: script.script_entrance_night_light
service: script.turn_on
What is the question?
Not sure if it helps, but my lights only become motion activated at 9pm. I just wrote an automation to turn my motion automations on at 9 and off at 7am when they become normal lights. Iv hardcoded these times but you could use a input_number to set the time they cone off/on.
I use something similar for my heating:
Let me know if you’d like to see my code
You can control several entities using a comma:
service: homeassistant.turn_on
entity_id: script.timed_lamp, script.second_lamp
Why the script? Can’t you simply use this?:
- alias: Motion Detection - Bathroom Light on
platform: state
entity_id: binary_sensor.motion_sensor_158d00015ab008
to: 'on'
entity_id: light.bathroom
- alias: Motion Detection - Bathroom Light off
platform: state
to: 'off'
for: '00:05:00'
That’s smart and would help.
Yes please i would like to see the code
Can confirm this works perfectly
Could you please share your code.
Thanks.
automation motion on at 10:
alias: Motion - on at 10pm
initial_state: True
hide_entity: False
platform: time
at: '22:00:00'
service: automation.turn_on
entity_id: automation.motion_1_on__lights_on,automation.motion_1_off__lights_off
automation motion off at 11:
alias: Motion - off at 7am
initial_state: True
hide_entity: False
platform: time
at: '07:00:00'
service: automation.turn_off
I followed someone else’s idea to try and the motion sensor tries to keep turning off unless there is motion, I also have built in time as I want the lights to be dimmer at certain periods. Here’s my automation around it:
- alias: Motion Home Hallway
- platform: state
entity_id: binary_sensor.neo_coolcam_battery_powered_pir_sensor_hallway
to: 'on'
condition:
- condition: state
entity_id: light.hallway
state: 'off'
- condition: or
conditions:
- condition: state
entity_id: input_select.chris_status_dropdown
state: 'Home'
- condition: state
entity_id: input_select.val_status_dropdown
state: 'Home'
- condition: or
conditions:
- condition: sun
after: sunset
after_offset: "-1:00:00"
- condition: sun
before: sunrise
before_offset: "1:00:00"
- service: scene.turn_on
data_template:
entity_id: >
{% if now().hour >= 20 or now().hour <= 7 %}
scene.hallway_nightlight
{% else %}
scene.hallway_bright
{% endif %}
- alias: Lights Hallway Off
- platform: state
to: 'off'
for:
minutes: 1
- service: homeassistant.turn_off
This should be sooooo simple, yet Homeassistant makes it so difficult, writing code and code and everyone tells you something different… specially when there are a lot of different plataforms out there that do the same thing in 3 simple steps…
I guess you notice that the thread is 6 years old and last comment 4 years old. In the meanwhile, home assistant evolved and you can now use the GUI to build such easy automation .
BTW - even more complex automations are easy to setup in the GUI
Starting i s never easy, the GUI is great these days, my coding is iffy so I like to use the GUI. That said your automation would be easiest as you make two automation’s, the first with the trigger of motion setting the light on, the second one is switching it off if condition is that there is no movement anymore and after some time.
That is it, easily done in the GUI.
Sure you can add all kind of things like between hours, or if the sun is below a certain inclination or…
Good luck, there are numerous great examples to be found on the forum.
