Hi there. First of all thank you for a great integration.
I had it working fine with the cubetouch II until I updated HASS core yesterday to 2023.6
Since then I always get the following errors and obviously Tuya BLE doesn’t work anymore.
2023-06-01 15:14:22.961 ERROR (MainThread) [homeassistant.loader] Unexpected exception importing platform custom_components.tuya_ble.button
File "/usr/src/homeassistant/homeassistant/loader.py", line 833, in get_platform
cache[full_name] = self._import_platform(platform_name)
File "/usr/src/homeassistant/homeassistant/loader.py", line 850, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File "/usr/local/lib/python3.11/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1206, in _gcd_import
File "<frozen importlib._bootstrap>", line 1178, in _find_and_load
File "<frozen importlib._bootstrap>", line 1149, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 690, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 940, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/config/custom_components/tuya_ble/button.py", line 51, in <module>
@dataclass
File "/usr/local/lib/python3.11/dataclasses.py", line 1223, in dataclass
return wrap(cls)
File "/usr/local/lib/python3.11/dataclasses.py", line 1213, in wrap
return _process_class(cls, init, repr, eq, order, unsafe_hash,
File "/usr/local/lib/python3.11/dataclasses.py", line 958, in _process_class
cls_fields.append(_get_field(cls, name, type, kw_only))
File "/usr/local/lib/python3.11/dataclasses.py", line 815, in _get_field
raise ValueError(f'mutable default {type(f.default)} for field '
ValueError: mutable default <class 'homeassistant.components.button.ButtonEntityDescription'> for field description is not allowed: use default_factory
2023-06-01 15:14:22.963 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform tuya_ble.button: Platform not found (Exception importing custom_components.tuya_ble.button).
2023-06-01 15:14:22.968 ERROR (MainThread) [homeassistant.loader] Unexpected exception importing platform custom_components.tuya_ble.number
File "/config/custom_components/tuya_ble/number.py", line 101, in <module>
@dataclass
return wrap(cls)
ValueError: mutable default <class 'custom_components.tuya_ble.number.TuyaBLEHoldTimeDescription'> for field description is not allowed: use default_factory
2023-06-01 15:14:22.970 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform tuya_ble.number: Platform not found (Exception importing custom_components.tuya_ble.number).
2023-06-01 15:14:22.971 ERROR (MainThread) [homeassistant.loader] Unexpected exception importing platform custom_components.tuya_ble.sensor
File "/config/custom_components/tuya_ble/sensor.py", line 64, in <module>
@dataclass
return wrap(cls)
Has anyone else had this problem after yesterday’s update?
