1. installation
Since this is non listed node, you can not find it under Manage palettes, but you have to add github path into Node-red addon Config under Supervisor in HomeAssistant
/subzero79/node-red-contrib-tuya-local
Then install simple node red testing flow
[{"id":"115ada30.1743c6","type":"tuya-local","z":"8e8fe68f.ac31b8","devName":"socket1","devIp":"[10.10.4.81](https://l.messenger.com/l.php?u=http%3A%2F%2F10.10.4.81%2F&h=AT0X9xm4qucefdoIV38PMf4Fd_aJOtaJlktH7OEzSRctpjoC8g7oPv9inRCidzQgiGYlfM5C_t2M7hzj6Kis67numEh8LYLQ_I0SKRTBv67PY26OXINE2el5nHXhkNyZD1E)","devId":"82180707adcfa6743a","devKey":"d189ad7b927d1dac","protocolVer":"3.3","x":550,"y":400,"wires":[["88349073.f9906"]]},{"id":"f21e12d7.a9512","type":"inject","z":"8e8fe68f.ac31b8","name":"","topic":"","payload":"true","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":350,"y":460,"wires":[["115ada30.1743c6"]]},{"id":"19a51c7b.2203e4","type":"inject","z":"8e8fe68f.ac31b8","name":"","topic":"","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":350,"y":500,"wires":[["115ada30.1743c6"]]},{"id":"88349073.f9906","type":"debug","z":"8e8fe68f.ac31b8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":730,"y":400,"wires":[]},{"id":"797d431a.95651c","type":"inject","z":"8e8fe68f.ac31b8","name":"{\"set\": true, \"dps\" : 1}","topic":"","payload":"{\"set\": true, \"dps\" : 1}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":310,"y":420,"wires":[["115ada30.1743c6"]]},{"id":"90a67db.6f94d8","type":"inject","z":"8e8fe68f.ac31b8","name":"request","topic":"","payload":"request","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":350,"y":340,"wires":[["115ada30.1743c6"]]},{"id":"8d81b2e6.7d0b4","type":"inject","z":"8e8fe68f.ac31b8","name":"disconnect","topic":"disconnect","payload":"disconnect","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":340,"y":300,"wires":[["115ada30.1743c6"]]},{"id":"b1231ec7.fadc6","type":"inject","z":"8e8fe68f.ac31b8","name":"connect ","topic":"","payload":"connect","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":350,"y":260,"wires":[["115ada30.1743c6"]]},{"id":"e23704b.8e613f8","type":"inject","z":"8e8fe68f.ac31b8","name":"{\"set\": false, \"dps\" : 1}","topic":"","payload":"{\"set\": false, \"dps\" : 1}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":300,"y":380,"wires":[["115ada30.1743c6"]]},{"id":"778d17d6.8d4d28","type":"inject","z":"8e8fe68f.ac31b8","name":"","topic":"","payload":"toggle","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":350,"y":540,"wires":[["115ada30.1743c6"]]}]
