<!-- READ THIS FIRST:
- If you need additional help with this template please r…efer to https://www.home-assistant.io/help/reporting_issues/
- Make sure you are running the latest version of Home Assistant before reporting an issue: https://github.com/home-assistant/home-assistant/releases
- Frontend issues should be submitted to the home-assistant-polymer repository: https://github.com/home-assistant/home-assistant-polymer/issues
- iOS issues should be submitted to the home-assistant-iOS repository: https://github.com/home-assistant/home-assistant-iOS/issues
- Do not report issues for integrations if you are using a custom integration: files in <config-dir>/custom_components
- This is for bugs only. Feature and enhancement requests should go in our community forum: https://community.home-assistant.io/c/feature-requests
- Provide as many details as possible. Paste logs, configuration sample and code into the backticks. Do not delete any text from this template!
**Home Assistant release with the issue:**
- Frontend -> Developer tools -> Info
- Or use this command: hass --version
0.98.3
**Last working Home Assistant release (if known):**
unknown
**Operating environment (Hass.io/Docker/Windows/etc.):**
Please provide details about your environment.
Hassbian on RPI3B+
**Component/platform:**
Please add the link to the documentation at https://www.home-assistant.io/components/ of the component/platform in question.
https://www.home-assistant.io/components/websocket_api/
**Description of problem:**
I see a lot of warnings in logs that **socket.send() raised exception** (44 times in last 12h). Baloob said that warnings need to be fixed but I don't see any report for this warning so I'm creating this one. People which have same spam by this exception please add emoji to this post.
socket.send() raised exception.
9:33 AM components/websocket_api/http.py (WARNING) - message first occured at September 4, 2019, 9:35 PM and shows up 44 times
**Problem-relevant `configuration.yaml` entries and (fill out even if it seems unimportant):**
```yaml
**Traceback (if applicable):**
**Additional information:**
I've set logger to debug for websocket_api with the hope that it will help to obtain more information but I'm not sure if it will be usefull (part of log attached below).
```yaml
logger:
default: info
logs:
yeelight: info
homeassistant.components.websocket_api: debug
2019-09-05 09:30:57 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1400554160] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=group.all_switches, old_state=<state group.all_switches=on; entity_id=('switch.zigbee2mqtt_main_join', 'switch.swiatla_led_w_kuchni'), order=4, auto=True, friendly_name=all switches, hidden=True @ 2019-09-05T09:28:15.187475+02:00>, new_state=<state group.all_switches=off; entity_id=('switch.zigbee2mqtt_main_join', 'switch.swiatla_led_w_kuchni'), order=4, auto=True, friendly_name=all switches, hidden=True @ 2019-09-05T09:30:57.170410+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602898928] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time, old_state=<state sensor.time=09:30; friendly_name=Time, icon=mdi:clock @ 2019-09-05T09:30:01.011269+02:00>, new_state=<state sensor.time=09:31; friendly_name=Time, icon=mdi:clock @ 2019-09-05T09:31:01.011579+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602898928] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.date_time, old_state=<state sensor.date_time=2019-09-05, 09:30; friendly_name=Date & Time, icon=mdi:calendar-clock @ 2019-09-05T09:30:01.013840+02:00>, new_state=<state sensor.date_time=2019-09-05, 09:31; friendly_name=Date & Time, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.014155+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602898928] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.date_time_iso, old_state=<state sensor.date_time_iso=2019-09-05T09:30:00; friendly_name=Date & Time ISO, icon=mdi:calendar-clock @ 2019-09-05T09:30:01.016176+02:00>, new_state=<state sensor.date_time_iso=2019-09-05T09:31:00; friendly_name=Date & Time ISO, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.016495+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602898928] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time_date, old_state=<state sensor.time_date=09:30, 2019-09-05; friendly_name=Time & Date, icon=mdi:calendar-clock @ 2019-09-05T09:30:01.018540+02:00>, new_state=<state sensor.time_date=09:31, 2019-09-05; friendly_name=Time & Date, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.018872+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602898928] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time_utc, old_state=<state sensor.time_utc=07:30; friendly_name=Time (UTC), icon=mdi:clock @ 2019-09-05T09:30:01.020836+02:00>, new_state=<state sensor.time_utc=07:31; friendly_name=Time (UTC), icon=mdi:clock @ 2019-09-05T09:31:01.021162+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1393531280] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time, old_state=<state sensor.time=09:30; friendly_name=Time, icon=mdi:clock @ 2019-09-05T09:30:01.011269+02:00>, new_state=<state sensor.time=09:31; friendly_name=Time, icon=mdi:clock @ 2019-09-05T09:31:01.011579+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1393531280] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.date_time, old_state=<state sensor.date_time=2019-09-05, 09:30; friendly_name=Date & Time, icon=mdi:calendar-clock @ 2019-09-05T09:30:01.013840+02:00>, new_state=<state sensor.date_time=2019-09-05, 09:31; friendly_name=Date & Time, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.014155+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1393531280] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.date_time_iso, old_state=<state sensor.date_time_iso=2019-09-05T09:30:00; friendly_name=Date & Time ISO, icon=mdi:calendar-clock @ 2019-09-05T09:30:01.016176+02:00>, new_state=<state sensor.date_time_iso=2019-09-05T09:31:00; friendly_name=Date & Time ISO, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.016495+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1393531280] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time_date, old_state=<state sensor.time_date=09:30, 2019-09-05; friendly_name=Time & Date, icon=mdi:calendar-clock @ 2019-09-05T09:30:01.018540+02:00>, new_state=<state sensor.time_date=09:31, 2019-09-05; friendly_name=Time & Date, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.018872+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1393531280] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time_utc, old_state=<state sensor.time_utc=07:30; friendly_name=Time (UTC), icon=mdi:clock @ 2019-09-05T09:30:01.020836+02:00>, new_state=<state sensor.time_utc=07:31; friendly_name=Time (UTC), icon=mdi:clock @ 2019-09-05T09:31:01.021162+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602740336] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time, old_state=<state sensor.time=09:30; friendly_name=Time, icon=mdi:clock @ 2019-09-05T09:30:01.011269+02:00>, new_state=<state sensor.time=09:31; friendly_name=Time, icon=mdi:clock @ 2019-09-05T09:31:01.011579+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602740336] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.date_time, old_state=<state sensor.date_time=2019-09-05, 09:30; friendly_name=Date & Time, icon=mdi:calendar-clock @ 2019-09-05T09:30:01.013840+02:00>, new_state=<state sensor.date_time=2019-09-05, 09:31; friendly_name=Date & Time, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.014155+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602740336] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.date_time_iso, old_state=<state sensor.date_time_iso=2019-09-05T09:30:00; friendly_name=Date & Time ISO, icon=mdi:calendar-clock @ 2019-09-05T09:30:01.016176+02:00>, new_state=<state sensor.date_time_iso=2019-09-05T09:31:00; friendly_name=Date & Time ISO, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.016495+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602740336] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time_date, old_state=<state sensor.time_date=09:30, 2019-09-05; friendly_name=Time & Date, icon=mdi:calendar-clock @ 2019-09-05T09:30:01.018540+02:00>, new_state=<state sensor.time_date=09:31, 2019-09-05; friendly_name=Time & Date, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.018872+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602740336] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time_utc, old_state=<state sensor.time_utc=07:30; friendly_name=Time (UTC), icon=mdi:clock @ 2019-09-05T09:30:01.020836+02:00>, new_state=<state sensor.time_utc=07:31; friendly_name=Time (UTC), icon=mdi:clock @ 2019-09-05T09:31:01.021162+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1400554160] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time, old_state=<state sensor.time=09:30; friendly_name=Time, icon=mdi:clock @ 2019-09-05T09:30:01.011269+02:00>, new_state=<state sensor.time=09:31; friendly_name=Time, icon=mdi:clock @ 2019-09-05T09:31:01.011579+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1400554160] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.date_time, old_state=<state sensor.date_time=2019-09-05, 09:30; friendly_name=Date & Time, icon=mdi:calendar-clock @ 2019-09-05T09:30:01.013840+02:00>, new_state=<state sensor.date_time=2019-09-05, 09:31; friendly_name=Date & Time, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.014155+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1400554160] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.date_time_iso, old_state=<state sensor.date_time_iso=2019-09-05T09:30:00; friendly_name=Date & Time ISO, icon=mdi:calendar-clock @ 2019-09-05T09:30:01.016176+02:00>, new_state=<state sensor.date_time_iso=2019-09-05T09:31:00; friendly_name=Date & Time ISO, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.016495+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1400554160] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time_date, old_state=<state sensor.time_date=09:30, 2019-09-05; friendly_name=Time & Date, icon=mdi:calendar-clock @ 2019-09-05T09:30:01.018540+02:00>, new_state=<state sensor.time_date=09:31, 2019-09-05; friendly_name=Time & Date, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.018872+02:00>>}
2019-09-05 09:31:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1400554160] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time_utc, old_state=<state sensor.time_utc=07:30; friendly_name=Time (UTC), icon=mdi:clock @ 2019-09-05T09:30:01.020836+02:00>, new_state=<state sensor.time_utc=07:31; friendly_name=Time (UTC), icon=mdi:clock @ 2019-09-05T09:31:01.021162+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602898928] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time, old_state=<state sensor.time=09:31; friendly_name=Time, icon=mdi:clock @ 2019-09-05T09:31:01.011579+02:00>, new_state=<state sensor.time=09:32; friendly_name=Time, icon=mdi:clock @ 2019-09-05T09:32:01.010985+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602898928] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.date_time, old_state=<state sensor.date_time=2019-09-05, 09:31; friendly_name=Date & Time, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.014155+02:00>, new_state=<state sensor.date_time=2019-09-05, 09:32; friendly_name=Date & Time, icon=mdi:calendar-clock @ 2019-09-05T09:32:01.013609+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602898928] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.date_time_iso, old_state=<state sensor.date_time_iso=2019-09-05T09:31:00; friendly_name=Date & Time ISO, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.016495+02:00>, new_state=<state sensor.date_time_iso=2019-09-05T09:32:00; friendly_name=Date & Time ISO, icon=mdi:calendar-clock @ 2019-09-05T09:32:01.018013+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602898928] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time_date, old_state=<state sensor.time_date=09:31, 2019-09-05; friendly_name=Time & Date, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.018872+02:00>, new_state=<state sensor.time_date=09:32, 2019-09-05; friendly_name=Time & Date, icon=mdi:calendar-clock @ 2019-09-05T09:32:01.021407+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602898928] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time_utc, old_state=<state sensor.time_utc=07:31; friendly_name=Time (UTC), icon=mdi:clock @ 2019-09-05T09:31:01.021162+02:00>, new_state=<state sensor.time_utc=07:32; friendly_name=Time (UTC), icon=mdi:clock @ 2019-09-05T09:32:01.023874+02:00>>}
2019-09-05 09:32:01 WARNING (MainThread) [asyncio] socket.send() raised exception.
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1393531280] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time, old_state=<state sensor.time=09:31; friendly_name=Time, icon=mdi:clock @ 2019-09-05T09:31:01.011579+02:00>, new_state=<state sensor.time=09:32; friendly_name=Time, icon=mdi:clock @ 2019-09-05T09:32:01.010985+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1393531280] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.date_time, old_state=<state sensor.date_time=2019-09-05, 09:31; friendly_name=Date & Time, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.014155+02:00>, new_state=<state sensor.date_time=2019-09-05, 09:32; friendly_name=Date & Time, icon=mdi:calendar-clock @ 2019-09-05T09:32:01.013609+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1393531280] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.date_time_iso, old_state=<state sensor.date_time_iso=2019-09-05T09:31:00; friendly_name=Date & Time ISO, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.016495+02:00>, new_state=<state sensor.date_time_iso=2019-09-05T09:32:00; friendly_name=Date & Time ISO, icon=mdi:calendar-clock @ 2019-09-05T09:32:01.018013+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1393531280] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time_date, old_state=<state sensor.time_date=09:31, 2019-09-05; friendly_name=Time & Date, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.018872+02:00>, new_state=<state sensor.time_date=09:32, 2019-09-05; friendly_name=Time & Date, icon=mdi:calendar-clock @ 2019-09-05T09:32:01.021407+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1393531280] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time_utc, old_state=<state sensor.time_utc=07:31; friendly_name=Time (UTC), icon=mdi:clock @ 2019-09-05T09:31:01.021162+02:00>, new_state=<state sensor.time_utc=07:32; friendly_name=Time (UTC), icon=mdi:clock @ 2019-09-05T09:32:01.023874+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602740336] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time, old_state=<state sensor.time=09:31; friendly_name=Time, icon=mdi:clock @ 2019-09-05T09:31:01.011579+02:00>, new_state=<state sensor.time=09:32; friendly_name=Time, icon=mdi:clock @ 2019-09-05T09:32:01.010985+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602740336] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.date_time, old_state=<state sensor.date_time=2019-09-05, 09:31; friendly_name=Date & Time, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.014155+02:00>, new_state=<state sensor.date_time=2019-09-05, 09:32; friendly_name=Date & Time, icon=mdi:calendar-clock @ 2019-09-05T09:32:01.013609+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602740336] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.date_time_iso, old_state=<state sensor.date_time_iso=2019-09-05T09:31:00; friendly_name=Date & Time ISO, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.016495+02:00>, new_state=<state sensor.date_time_iso=2019-09-05T09:32:00; friendly_name=Date & Time ISO, icon=mdi:calendar-clock @ 2019-09-05T09:32:01.018013+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602740336] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time_date, old_state=<state sensor.time_date=09:31, 2019-09-05; friendly_name=Time & Date, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.018872+02:00>, new_state=<state sensor.time_date=09:32, 2019-09-05; friendly_name=Time & Date, icon=mdi:calendar-clock @ 2019-09-05T09:32:01.021407+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602740336] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time_utc, old_state=<state sensor.time_utc=07:31; friendly_name=Time (UTC), icon=mdi:clock @ 2019-09-05T09:31:01.021162+02:00>, new_state=<state sensor.time_utc=07:32; friendly_name=Time (UTC), icon=mdi:clock @ 2019-09-05T09:32:01.023874+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1400554160] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time, old_state=<state sensor.time=09:31; friendly_name=Time, icon=mdi:clock @ 2019-09-05T09:31:01.011579+02:00>, new_state=<state sensor.time=09:32; friendly_name=Time, icon=mdi:clock @ 2019-09-05T09:32:01.010985+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1400554160] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.date_time, old_state=<state sensor.date_time=2019-09-05, 09:31; friendly_name=Date & Time, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.014155+02:00>, new_state=<state sensor.date_time=2019-09-05, 09:32; friendly_name=Date & Time, icon=mdi:calendar-clock @ 2019-09-05T09:32:01.013609+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1400554160] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.date_time_iso, old_state=<state sensor.date_time_iso=2019-09-05T09:31:00; friendly_name=Date & Time ISO, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.016495+02:00>, new_state=<state sensor.date_time_iso=2019-09-05T09:32:00; friendly_name=Date & Time ISO, icon=mdi:calendar-clock @ 2019-09-05T09:32:01.018013+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1400554160] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time_date, old_state=<state sensor.time_date=09:31, 2019-09-05; friendly_name=Time & Date, icon=mdi:calendar-clock @ 2019-09-05T09:31:01.018872+02:00>, new_state=<state sensor.time_date=09:32, 2019-09-05; friendly_name=Time & Date, icon=mdi:calendar-clock @ 2019-09-05T09:32:01.021407+02:00>>}
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1400554160] Sending {'id': 2, 'type': 'event', 'event': <Event state_changed[L]: entity_id=sensor.time_utc, old_state=<state sensor.time_utc=07:31; friendly_name=Time (UTC), icon=mdi:clock @ 2019-09-05T09:31:01.021162+02:00>, new_state=<state sensor.time_utc=07:32; friendly_name=Time (UTC), icon=mdi:clock @ 2019-09-05T09:32:01.023874+02:00>>}
2019-09-05 09:32:01 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.1602740336] Connection closed by client
2019-09-05 09:32:01 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.1400554160] Connection closed by client
2019-09-05 09:32:01 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.1393531280] Connection closed by client
2019-09-05 09:32:01 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.1602898928] Connection closed by client
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602740336] Disconnected
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1400554160] Disconnected
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1393531280] Disconnected
2019-09-05 09:32:01 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602898928] Disconnected
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Connected
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Sending {'type': 'auth_required', 'ha_version': '0.98.3'}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'auth', 'access_token': 'vyG3eXAiOiJKV1QiLCJhbGc3OiJIec15iJ9.eyJpc3MiOiIyNjU3NzdiNjgfsY0ZDFiOTQyNmViYjIzZTM3MWUeZiIsImlhdCI6MeU2NzY2ODdaswiZXhwIjoxNTY3NjY5OTE4fQ.1tg5xleeOJP0yAybu8AUKuGttgUbrm3asPCCq8VaNUg'}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received access_token
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Auth OK
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Sending {'type': 'auth_ok', 'ha_version': '0.98.3'}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'subscribe_events', 'event_type': 'state_changed', 'id': 2}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'subscribe_events', 'event_type': 'component_loaded', 'id': 3}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'subscribe_events', 'event_type': 'core_config_updated', 'id': 4}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'subscribe_events', 'event_type': 'service_registered', 'id': 5}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'subscribe_events', 'event_type': 'service_removed', 'id': 6}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'subscribe_events', 'event_type': 'panels_updated', 'id': 7}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'subscribe_events', 'event_type': 'themes_updated', 'id': 8}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'subscribe_events', 'event_type': 'persistent_notifications_updated', 'id': 9}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'subscribe_events', 'event_type': 'lovelace_updated', 'id': 10}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'get_states', 'id': 11}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'get_config', 'id': 12}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'get_services', 'id': 13}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'get_panels', 'id': 14}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'frontend/get_themes', 'id': 15}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'auth/current_user', 'id': 16}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'lovelace/config', 'force': False, 'id': 17}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'frontend/get_translations', 'language': 'en', 'id': 18}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'persistent_notification/get', 'id': 19}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'frontend/get_user_data', 'key': 'core', 'id': 20}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'frontend/get_user_data', 'key': 'core', 'id': 21}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'frontend/get_user_data', 'key': 'core', 'id': 22}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'frontend/get_user_data', 'key': 'core', 'id': 23}
2019-09-05 09:32:02 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'frontend/get_user_data', 'key': 'core', 'id': 24}
2019-09-05 09:32:03 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'frontend/get_user_data', 'key': 'core', 'id': 25}
2019-09-05 09:32:03 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'frontend/get_user_data', 'key': 'core', 'id': 26}
2019-09-05 09:32:03 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'frontend/get_user_data', 'key': 'core', 'id': 27}
2019-09-05 09:32:03 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'frontend/get_user_data', 'key': 'core', 'id': 28}
2019-09-05 09:32:03 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'frontend/get_user_data', 'key': 'core', 'id': 29}
2019-09-05 09:32:03 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'frontend/get_user_data', 'key': 'core', 'id': 30}
2019-09-05 09:32:03 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'frontend/get_user_data', 'key': 'core', 'id': 31}
2019-09-05 09:32:03 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Received {'type': 'frontend/get_user_data', 'key': 'core', 'id': 32}
2019-09-05 09:32:03 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Sending {'id': 2, 'type': 'result', 'success': True, 'result': None}
2019-09-05 09:32:03 DEBUG (MainThread) [homeassistant.components.websocket_api.http.connection.1602237712] Sending {'id': 3, 'type': 'result', 'success': True, 'result': None}
