Tuya LOCAL with energy monitoring and without tuya-convert
Hi, I can’t make these working in HA. I tried many different configurations, but while I can see the values from my Tuya plug, I can’t see them in the Energy dashboard. My configuration looks like this
localtuya:
  - host: xx
    device_id: xx
    local_key: xx
    friendly_name: my-plug
    protocol_version: "3.3"
    entities:
      - platform: switch
        friendly_name: Plug
      - platform: sensor
        friendly_name: Plug-current
        device_class: current
      - platform: sensor
        friendly_name: Plug-current-consumption
        device_class: energy
      - platform: sensor
        friendly_name: Plug-voltage
        device_class: voltage
    sensors:
        my-plug-consumption:
          friendly_name: "Plug consumption"
          unit_of_measurement: 'kWh'
          value_template: "{{ states(my-plug.sensor.Plug-current-consumption) }}"
I see the three sensors, but the template reports unavailable. I tried also many other value_templates but none seem to work.
I think in the sensor all needs to be lower case?
there is a capital P in:
you also have dashes instead of underlines.
also, the current consumption value is simply W, not kWh
my sensor is
kitchen_current_consumption:
        value_template: "{{ states.switch.kitchen.attributes.current_consumption }}"
        device_class: power
        unit_of_measurement: 'W'
I don’t use the Energy dash, so can’t help you there.
I managed to make it work with this file:
localtuya:
  - host: xx
    device_id: xx
    local_key: xx
    friendly_name: bibe
    entities:
      - platform: switch
        friendly_name: bibe_switch
      - platform: sensor
        friendly_name: bibe_current
      - platform: sensor
        friendly_name: bibe_consumption
      - platform: sensor
        friendly_name: bibe_voltage
    sensors:
        bibe_current_template:
          friendly_name: "Current"
          unit_of_measurement: 'A'
          value_template: '{{ states("sensor.plug_current") | float / 10 }}'
        bibe_consumption_template:
          friendly_name: "Consumption"
          value_template: '{{ states("sensor.plug_consumption") | float / 10 }}'
        bibe_voltage_template:
          friendly_name: "Voltage"
          unit_of_measurement: 'V'
          value_template: '{{ states("sensor.plug_voltage") | float / 10 }}'
however, although I can now see the correct values, I can’t add this device in the Energy tab. Any idea on this?
Moreover, I don’t know if I add another localtuya device how can I reference it, since in the templates I have no bibe reference whatsover, which is my identifier.
I had to add this in my sensor.yaml file for it to appear in the energy tab -
- platform: integration
  source: sensor.gosund2_lt_current_consumption
  unit_prefix: k
  unit: kWh
  round: 2
Guys, how to add a device that has 2 sockets with yaml? i tried adding an entity? but i only see one?
thnx
  - host: !secret tuya_switch_1_ip
    device_id: !secret tuya_switch_1_id
    local_key: !secret tuya_switch_1_key
    friendly_name: Tuya Switch1
    entities:
      - platform: switch
        friendly_name: Tuya Switch1_1
        current: 18
        current_consumption: 19
        voltage: 20
      - platform: switch
        friendly_name: Tuya Switch1_2
        current: 18
        voltage: 20
You probably mean a 2-Gang switch.
I would do the configuration directly through config flow (Settings → Integrations → Add Integration → LocalTuya Integration) rather than fiddling around with configuration.yaml for LocalTuya.
Remember to delete the entries for LocalTuya inside configuration.yaml and restart HA before you go the config flow-way!
i figured it out, just need to change the id for the second one to : 2
still prefer yaml :slight_smile:
Been a while since I played with these, but I just realised that my local tuya setup only works if I have internet, which obviously is not really a local setup.
I set up the plugs using the config flow method, then have a consumption template sensor.
Switching on/off works fine, just can’t get the power data when local.
OFFTOPIC just to let you know the easiest way I’ve seen to get local key is using https://pypi.org/project/tinytuya/
Anyone also get this to work with your Tuya plug? I can’t get them in the drop down list to add, even with this in the sensors
i need some help, whit customize.yaml for →
switch.desk:
sampling_size: ‘15’
cant understand how i must do
Where is the sensor.yaml file?
If you split all your integrations up into packages you would have sensors under their own .yaml file. If you have your sensors combined into the configuration.yaml file you would need to add it in there.
Same problem for me too :slight_smile:
I can’t find either
I don’t understand how to do it
Here is the guide
How do you manage to get the daily/monthly/total consumption, i.e., kWh?
My integration so far:
localtuya:
  - host: 29.9.81.xxx
    device_id: xxxxx
    local_key: xxxxx
    friendly_name: smart_solar_switch
    entities:
      - platform: switch
        friendly_name: solar_switch
      - platform: sensor
        friendly_name: solar_switch_current
        scaling: 0.1
      - platform: sensor
        friendly_name: solar_switch_consumption
        scaling: 0.1
        device_class: power
      - platform: sensor
        friendly_name: solar_switch_voltage
        scaling: 0.1
Thank you
Hey mate, which values did you use for current/voltage/power?
