Further data:
Tried to add a previously unused Tuya WiFi socket to TuyaLocal. Again, all firewall rules to prevent access to Tuya Servers are disabled. I was able to ping the socket (192.168.20.118) before attempting integration. The following error occurred:
File "/config/custom_components/localtuya/config_flow.py", line 279, in async_step_basic_info
self.dps_strings = await validate_input(self.hass, user_input)
File "/config/custom_components/localtuya/config_flow.py", line 185, in validate_input
interface = await pytuya.connect(
File "/config/custom_components/localtuya/pytuya/__init__.py", line 637, in connect
_, protocol = await loop.create_connection(
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1025, in create_connection
raise exceptions[0]
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1010, in create_connection
sock = await self._connect_sock(
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 924, in _connect_sock
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.8/asyncio/selector_events.py", line 496, in sock_connect
return await fut
File "/usr/local/lib/python3.8/asyncio/selector_events.py", line 528, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
OSError: [Errno 113] Connect call failed ('192.168.20.118', 6668)
