The siren in the video is not the same one as listed in the OP.
I have the unit in the video. There are two versions of the one in the video (I have both).
The “With Sensors” version (temp and humidity) is generally sold with the batteries included and is designed to function as a battery only device. It does not act as a router even if plugged into mains power. It is “sleepy” to preserve battery, so may have a delay of several seconds before turning on after sending a command to it. It will function long term (months at least, probably year+ based on mine so far) on battery only.
The “No Sensors” version is designed to be run primarily from mains power. It is sold without batteries included. It does not have the sleepy delay of the “with sensors” version. It will always act as a router regardless of battery/mains status. It will run on battery only, but the batteries are really only good for short term backup. Batteries will fully deplete within a day or two if not plugged into mains power.
Listings are often conflated between the versions. It’s hard to know which one you are ordeing, and some lisings are just plain wrong. Confirm which one you are ordering, but even then you may end up with the wrong one.
