miomia
(Miomia)
21
Check please
version: 4
homeassistant:
enabled: true
advanced:
network_key:
- 79
- 7
- 169
- 182
- 61
- 190
- 212
- 112
- 209
- 247
- 136
- 230
- 246
- 213
- 232
- 71
pan_id: 6540
ext_pan_id:
- 150
- 247
- 164
- 91
- 90
- 229
- 234
- 9
mqtt:
server: mqtt://core-mosquitto:1883
user: addons
password: aS4phah1aebuG1johbei6gaegofohchaeb8VohXee3jei6quahyi6ieva1uC9Jak
serial:
port: tcp://192.168.1.244:6638
frontend:
enabled: true
port: 8099
Remove the mqtt: from the add-on config and move the other lines back so it looks like the serial format.
I’m answering from a phone so can’t type it all out for you
Specify adapter type in the file.
serial:
adapter: zstack
miomia
(Miomia)
24
I changed Here is a photo Nothing changed The error is the same
(upload://ynYGtDeVpo2WEtUs5jUXmPNRhXZ.png)
Did you fix the incorrect mqtt entry in the add-on config?
It won’t work until you do - remove the mqtt:
OK, so it’s saying it can’t talk to your adapter. Is it flashed as a coordinator or a router?
