I really need this
i use Unifi Cameras, they are great with two way audio… But “Push to Talk” function is really missing in HA.
How in the world are we supposed to get Push to talk into Home Assistant for the Unifi G4 Pro doorbell? The entity isn’t detected at all
I finally resolved my problem with 2way audio between home assistant app and android ip webcam app.
Just generated ssl certs for ha and installed is as secure on phone. Now I can use sound recording from microphone via javascript and sending this via websocket to ip webcam app. Script is embedded on ha dashboard via iframe card. Lag is about 1-2s.
Receiving video and sound from ip webcam via frigate and send audio from mic via javascript. All is finally working as expected.
Should be a thing for assistant/voice control too.
Hello, I installed this add-on and I now calls from the doorbell to my Home Assistant tablet, via Asterisk, are working with audio and video. However I don’t see how to do what you mention here - how to make the video available as early media, before I pick up the call on the tablet? I don’t see any RTSP app in the add-on, can you elaborate a bit! Thank you!
Hi , the rtsp app is included, but you don’t need it of you use HA as sipclient, just use the camera integration to display the feed, not from the call itself…
The doorbell is somehow low cost: in the video streaming mode, you only have JPG snapshots, and no audio. RTSP is only available during SIP calls. Also if I display the JPG snapshots next to the SIP card, I will have two windows when I pick up.
Also I don’t see the RSTP app - or is it called something else? I’m using the asterisk add-on:
3e533915-asterisk*CLI> core show applications
-= Registered Asterisk Applications =-
AddQueueMember: Dynamically adds queue members.
AELSub: Launch subroutine built with AEL
AgentLogin: Login an agent.
AgentRequest: Request an agent to connect with the channel.
AGI: Executes an AGI compliant application.
AlarmReceiver: Provide support for receiving alarm reports from a burglar or fire alarm panel.
AMD: Attempt to detect answering machines.
Answer: Answer a channel if ringing.
AttendedTransfer: Attended transfer to the extension provided and TRANSFER_CONTEXT
AudioSocket: Transmit and receive audio between channel and TCP socket
Authenticate: Authenticate a user
BackGround: Play an audio file while waiting for digits of an extension to go to.
BackgroundDetect: Background a file with talk detect.
BlindTransfer: Blind transfer channel(s) to the extension and context provided
Bridge: Bridge two channels.
BridgeAdd: Join a bridge that contains the specified channel.
BridgeWait: Put a call into the holding bridge.
Broadcast: Transmit or receive audio to or from multiple channels simultaneously
Busy: Indicate the Busy condition.
CallCompletionCancel: Cancel call completion service
CallCompletionRequest: Request call completion service for previous call
CELGenUserEvent: Generates a CEL User Defined Event.
ChanIsAvail: Check channel availability
ChannelRedirect: Redirects given channel to a dialplan target
ChanSpy: Listen to a channel, and optionally whisper into it.
ClearHash: Clear the keys from a specified hashname.
ConfBridge: Conference bridge application.
ConfKick: Kicks channel(s) from the requested ConfBridge.
Congestion: Indicate the Congestion condition.
ContinueWhile: Restart a While loop.
ControlPlayback: Play a file with fast forward and rewind.
DAHDIScan: Scan DAHDI channels to monitor calls.
DateTime: Says a specified time in a custom format.
DBdeltree: Delete a family or keytree from the asterisk database.
DeadAGI: Executes AGI on a hungup channel.
Dial: Attempt to connect to another device or endpoint and bridge the call.
Dictate: Virtual Dictation Machine.
Directory: Provide directory of voicemail extensions.
DISA: Direct Inward System Access.
DumpChan: Dump Info About The Calling Channel.
EAGI: Executes an EAGI compliant application.
Echo: Echo media, DTMF back to the calling party
Else: Define an optional else branch.
ElseIf: Start an else if branch.
EndIf: End an if branch.
EndWhile: End a while loop.
Exec: Executes dialplan application.
ExecIf: Executes dialplan application, conditionally.
ExecIfTime: Conditional application execution based on the current time.
ExitIf: End an If branch.
ExitWhile: End a While loop.
ExtenSpy: Listen to a channel, and optionally whisper into it.
ExternalIVR: Interfaces with an external IVR application.
Festival: Say text to the user.
FollowMe: Find-Me/Follow-Me application.
ForkCDR: Forks the current Call Data Record for this channel.
Gosub: Jump to label, saving return address.
GosubIf: Conditionally jump to label, saving return address.
Goto: Jump to a particular priority, extension, or context.
GotoIf: Conditional goto.
GotoIfTime: Conditional Goto based on the current time.
Hangup: Hang up the calling channel.
HangupCauseClear: Clears hangup cause information from the channel that is available through HANGUPCAUSE.
IAX2Provision: Provision a calling IAXy with a given template.
If: Start an if branch.
ImportVar: Import a variable from a channel into a new variable.
Incomplete: Returns AST_PBX_INCOMPLETE value.
Log: Send arbitrary text to a selected log level.
MessageSend: Send a text message.
Milliwatt: Generates a 1004 Hz test tone at 0dbm (mu-law).
MinivmAccMess: Record account specific messages.
MinivmDelete: Delete Mini-Voicemail voicemail messages.
MinivmGreet: Play Mini-Voicemail prompts.
MinivmMWI: Send Message Waiting Notification to subscriber(s) of mailbox.
MinivmNotify: Notify voicemail owner about new messages.
MinivmRecord: Receive Mini-Voicemail and forward via e-mail.
MixMonitor: Record a call and mix the audio during the recording. Use of StopMixMonitor is required to guarantee the audio file is available for processing during dialplan execution.
Morsecode: Plays morse code.
MP3Player: Play an MP3 file or M3U playlist file or stream.
MSet: Set channel variable(s) or function value(s).
MusicOnHold: Play Music On Hold indefinitely.
NoCDR: Tell Asterisk to not maintain a CDR for this channel.
NoOp: Do Nothing (No Operation).
Originate: Originate a call.
Page: Page series of phones
Park: Park yourself.
ParkAndAnnounce: Park and Announce.
ParkedCall: Retrieve a parked call.
PauseQueueMember: Pauses a queue member.
Pickup: Directed extension call pickup.
PickupChan: Pickup a ringing channel.
Playback: Play a file.
PlayTones: Play a tone list.
PrivacyManager: Require phone number to be entered, if no CallerID sent
Proceeding: Indicate proceeding.
Progress: Indicate progress.
Queue: Queue a call for a call queue.
QueueLog: Writes to the queue_log file.
QueueUpdate: Writes to the queue_log file for outbound calls and updates Realtime Data. Is used at h extension to be able to have all the parameters.
RaiseException: Handle an exceptional condition.
Read: Read a variable.
ReadExten: Read an extension into a variable.
ReceiveFAX: Receive a FAX and save as a TIFF/F file.
ReceiveMF: Detects MF digits on a channel and saves them to a variable.
ReceiveSF: Detects SF digits on a channel and saves them to a variable.
ReceiveText: Receive a Text Message on a channel.
Record: Record to a file.
Reload: Reloads an Asterisk module, blocking the channel until the reload has completed.
RemoveQueueMember: Dynamically removes queue members.
ResetCDR: Resets the Call Data Record.
RetryDial: Place a call, retrying on failure allowing an optional exit extension.
Return: Return from gosub routine.
Ringing: Indicate ringing tone.
SayAlpha: Say Alpha.
SayAlphaCase: Say Alpha.
SayDigits: Say Digits.
SayMoney: Say Money.
SayNumber: Say Number.
SayOrdinal: Say Ordinal Number.
SayPhonetic: Say Phonetic.
SayUnixTime: Says a specified time in a custom format.
SendDTMF: Sends arbitrary DTMF digits
SendFAX: Sends a specified TIFF/F file as a FAX.
SendMF: Sends arbitrary MF digits on the current or specified channel.
SendSF: Sends arbitrary SF digits on the current or specified channel.
SendText: Send a Text Message on a channel.
Set: Set channel variable or function value.
SetAMAFlags: Set the AMA Flags.
Signal: Sends a signal to any waiting channels.
SMS: Communicates with SMS service centres and SMS capable analogue phones.
SoftHangup: Hangs up the requested channel.
SpeechActivateGrammar: Activate a grammar.
SpeechBackground: Play a sound file and wait for speech to be recognized.
SpeechCreate: Create a Speech Structure.
SpeechDeactivateGrammar: Deactivate a grammar.
SpeechDestroy: End speech recognition.
SpeechLoadGrammar: Load a grammar.
SpeechProcessingSound: Change background processing sound.
SpeechStart: Start recognizing voice in the audio stream.
SpeechUnloadGrammar: Unload a grammar.
StackPop: Remove one address from gosub stack.
StartMusicOnHold: Play Music On Hold.
Stasis: Invoke an external Stasis application.
StopMixMonitor: Stop recording a call through MixMonitor, and free the recording's file handle.
StopMusicOnHold: Stop playing Music On Hold.
StopPlayTones: Stop playing a tone list.
StoreDTMF: Stores DTMF digits transmitted or received on a channel.
StreamEcho: Echo media, up to 'N' streams of a type, and DTMF back to the calling party
System: Execute a system command.
TestClient: Execute Interface Test Client.
TestServer: Execute Interface Test Server.
ToneScan: Wait for period of time while scanning for call progress tones
Transfer: Transfer caller to remote extension.
TryExec: Executes dialplan application, always returning.
TrySystem: Try executing a system command.
UnpauseQueueMember: Unpauses a queue member.
UserEvent: Send an arbitrary user-defined event to parties interested in a channel (AMI users and relevant res_stasis applications).
Verbose: Send arbitrary text to verbose output.
VMAuthenticate: Authenticate with Voicemail passwords.
VMSayName: Play the name of a voicemail user
VoiceMail: Leave a Voicemail message.
VoiceMailMain: Check Voicemail messages.
VoiceMailPlayMsg: Play a single voice mail msg from a mailbox by msg id.
Wait: Waits for some time.
WaitDigit: Waits for a digit to be entered.
WaitExten: Waits for an extension to be entered.
WaitForCondition: Wait (sleep) until the given condition is true.
WaitForNoise: Waits for a specified amount of noise.
WaitForRing: Wait for Ring Application.
WaitForSignal: Waits for a named signal on a channel.
WaitForSilence: Waits for a specified amount of silence.
WaitForTone: Wait for tone
WaitUntil: Wait (sleep) until the current time is the given epoch.
While: Start a while loop.
Zapateller: Block telemarketers with SIT.
-= 175 Applications Registered =-
From what I see it looks like it’s not included in the Pi builds.
Wow! Is this something you can share?
Did anyone figure this out ?
Yes, this is still needed.
Would love to have this feature for my Ring Video Doorbell!
2025 and still no 2 way audio support for Unifi cameras?
I’ve not yet been able to get 2-way audio working on HikVision cameras. I can hear the audio from the camera but not talk back to the ones that have inbuilt speakers…
I don’t have HikVision, but this may have the same problem my cameras do. In order to get audio towards the camera, one needs to use SIP to setup an audio channel to it.
Is there no plan/timeline yet announced by home assistant to support two way audio?
2026, and it’s kind of possible with WebRTC and advanced camera card but it’s a hassle and not reliable. Only native apps like Unify Protect or Access, or the Eufy/Reolink equivalents, have it working.
I was surprised when I found out this is not supported. We have missed the “WTF year”, but WTF
It would be awesome if I could get rid of the vendors app. HA could even support the caller screen as Reolink does, it would be soooooo coool.
If you would like to see core support for two-way audio you might want to upvote this roadmap issue: Introduce two-way audio support for compatible devices · Issue #201 · OpenHomeFoundation/roadmap · GitHub
