- sensor:
- name: Fensterstatus_Esszimmer_Links
state: |
{% set b1 = states('binary_sensor.esszimmer_fenster_links_gekippt') %}
{% set b2 = states('binary_sensor.esszimmer_fenster_links_offen') %}
{% if b1 == 'off' and b2 == 'off' %} geschlossen
{% elif b1 == 'on' and b2 == 'off' %} gekippt
{% elif b2 == 'on' and b1 == 'on' %} offen
{% elif b1 == 'unavailable' or b2 == 'unavailable' %} nicht verfügbar
{% else %} unbekannt
{% endif %}
icon: |
{% if b1 == 'off' and b2 == 'off' %} mdi:window-closed-variant
{% elif b1 == 'on' and b2 == 'off' %} mdi:angle-acute
{% elif b2 == 'on' and b1 == 'on' %} mdi:window-open-variant
{% elif b1 == 'unavailable' or b2 == 'unavailable' %} mdi:exclamation
{% else %} mdi:exclamation
{% endif %}
What I did was delete the first line (template:) and two spaces at the beginning of every row, so the indentation fits. And you already have template: in your config.
Not important, just use the corrected version above. After saving you have to reload the config. Go to Developer tools > YAML and first check your config by pressing the button in the first paragraph. If you get an ok, than reload template entites with the button a little downwards. In german this is under Entwicklerwerkzeuge > YAML > Konfiguration prüfen and the secomnd one is called Template Entitäten.
Please report back, if everything works as expected.
Sorry to bother, but may I ask for some guidance about this piece of code?
At the moment it’s driving me insane, that it’s not working as expected.
I added the
template: !include template.yaml
into the configuration.yaml, created a template.yaml and added the following code
- sensor:
- name: Esszimmer Balkontuer
state: |
{% set b1 = states('binary_sensor.esszimmer_balkontuer_oben_contact') %}
{% set b2 = states('binary_sensor.esszimmer_balkontuer_unten_contact') %}
{% if b1 == 'true' and b2 == 'true' %} geschlossen
{% elif b1 == 'false' and b2 == 'true' %} gekippt
{% elif b2 == 'false' and b1 == 'false' %} offen
{% endif %}
icon: |
{% if b1 == 'true' and b2 == 'true' %} mdi:door-closed-variant
{% elif b1 == 'false' and b2 == 'true' %} mdi:angle-acute
{% elif b2 == 'false' and b1 == 'false' %} mdi:door-open-variant
{% endif %}
So, I’m using Aqara Window/Door Sensors, attached to Zigbee2mqtt, which expose “contact” as state true or false. But, no matter if I use true/false in the code above or on/off, every time it creates the entity “sensor.esszimmer_balkontuer” with the state “unbekannt”.
Any advice from your side what I’m doing wrong? Much appreciated.
Thanks in advance.
Regards
Sven
EDIT: Issue solved. It should be on/off and it seems I switched the state (off is closed and on is open) so it was an undefined state.
