tydom2MQTT addon :D - Delta Dore Tydom to MQTT Broker
Looked through the logs, nothing out of the ordinary when the cpu goes crazy though, but sure I can raise an issue.
As tu la solution à mon problème pour avoir un sensor sur l’addon tydom2mqtt ?
merci bien
Hi all,
I have a question about round-trip updates. Everything is set-up and working (Mqtt, tydom add-on…) and I’m starting to put some cards in the dashboard.
However, I see the following behaviour using the “Light” card: If I turn on the light in HA, it’s fine, Tydom app is updated (1-2 seconds). But, if I turn off the light in Tydom app, the card is not updated.
So, basically, is there any way to update the card whenever there is a change in Tydom app? I have checked the logs (Add-on), and the Add-on is notified about the changes in the app, so, it’s just from the Add-on to the card, I suppose.
Am I missing some configuration? Any hint?
Thanks!
Jordi
Hello @fmartinou, j’ai actuellement ce problème :
2023-04-05 16:00:17,088 - main - WARNING - Unable to handle message: no close frame received or sent
Quand je le met en mode error j’ai ceci :slight_smile:
2023-04-05 21:16:13,349 - The configuration is valid
2023-04-05 21:16:16,253 - sensors.Switch - ERROR - ‘level’
Aurais tu quelques choses pour voir les caméras (tycam 2000 & 2100) ?
Hello everyone. Let me make a warning:
Be very careful with this integration, it really doesn’t work well and completely crashed my Tydom2 box.
j’ai ça aussi régulièrement, si on relance c’est OK.
il faudrait peut-être mettre en place une reconnexion automatique
@fmartinou j’ai fait une PR pour récupérer le mot de passe du tydom chez deltadore
The feature developed by @CyrilP (getting the tydom password using the Delta dore cloud) is available in the latest version (3.1.2) :+1:
Hi everyone !
I installed Tydom2MQTT and it finaly made it work started after some tries :slight_smile:
Unfortunatelly it does not seam to recognise my “Rothelec heaters” that are linked to my Tydom.
Any clue on how to solve this problem ?
Thanks in advance :rescue_worker_helmet:
My Tydom2MQTT Log :
--- Logging error ---
  File "/usr/local/lib/python3.11/logging/__init__.py", line 1110, in emit
    msg = self.format(record)
  File "/usr/local/lib/python3.11/logging/__init__.py", line 953, in format
    return fmt.format(record)
  File "/usr/local/lib/python3.11/logging/__init__.py", line 687, in format
    record.message = record.getMessage()
  File "/usr/local/lib/python3.11/logging/__init__.py", line 377, in getMessage
    msg = msg % self.args
TypeError: not all arguments converted during string formatting
Call stack:
  File "/app/main.py", line 119, in <module>
    main()
  File "/app/main.py", line 115, in main
    loop.run_forever()
  File "/usr/local/lib/python3.11/asyncio/base_events.py", line 607, in run_forever
    self._run_once()
  File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1922, in _run_once
    handle._run()
  File "/usr/local/lib/python3.11/asyncio/events.py", line 80, in _run
    self._context.run(self._callback, *self._args)
  File "/app/main.py", line 54, in listen_tydom
    await message_handler.incoming_triage()
  File "/app/tydom/MessageHandler.py", line 250, in incoming_triage
    await self.parse_response(incoming)
  File "/app/tydom/MessageHandler.py", line 294, in parse_response
    logger.warning('Unknown message type received', data)
Message: 'Unknown message type received'
Arguments: ('{"status": "CLOSE", "lastAccess": "2021-10-05T19:38:00Z"}',)
2023-05-21 19:23:37,690 - tydom.MessageHandler - WARNING - Unknown device name (1674257513_1674257513)
2023-05-21 19:23:37,690 - tydom.MessageHandler - WARNING - Unknown device type (1674257513_1674257513)
2023-05-21 19:23:37,690 - tydom.MessageHandler - INFO    - Device update (id=1674257513, endpoint=1674257513, name=, type=)
2023-05-21 19:23:37,690 - tydom.MessageHandler - WARNING - Unknown device name (1674257625_1674257625)
2023-05-21 19:23:37,690 - tydom.MessageHandler - WARNING - Unknown device type (1674257625_1674257625)
2023-05-21 19:23:37,690 - tydom.MessageHandler - INFO    - Device update (id=1674257625, endpoint=1674257625, name=, type=)
2023-05-21 19:23:37,691 - tydom.MessageHandler - WARNING - Unknown device name (1674257690_1674257690)
2023-05-21 19:23:37,691 - tydom.MessageHandler - WARNING - Unknown device type (1674257690_1674257690)
2023-05-21 19:23:37,691 - tydom.MessageHandler - INFO    - Device update (id=1674257690, endpoint=1674257690, name=, type=)
2023-05-21 19:23:39,219 - tydom.MessageHandler - WARNING - Unknown device name (1674257513_1674257513)
2023-05-21 19:23:39,219 - tydom.MessageHandler - WARNING - Unknown device type (1674257513_1674257513)
2023-05-21 19:23:39,219 - tydom.MessageHandler - INFO    - Device update (id=1674257513, endpoint=1674257513, name=, type=)
2023-05-21 19:23:40,431 - tydom.MessageHandler - WARNING - Unknown device name (1674257625_1674257625)
2023-05-21 19:23:40,431 - tydom.MessageHandler - WARNING - Unknown device type (1674257625_1674257625)
2023-05-21 19:23:40,431 - tydom.MessageHandler - INFO    - Device update (id=1674257625, endpoint=1674257625, name=, type=)
2023-05-21 19:29:38,580 - tydom.MessageHandler - WARNING - Unknown device name (1674257212_1674257212)
2023-05-21 19:29:38,580 - tydom.MessageHandler - WARNING - Unknown device type (1674257212_1674257212)
2023-05-21 19:29:38,581 - tydom.MessageHandler - INFO    - Device update (id=1674257212, endpoint=1674257212, name=, type=)
2023-05-21 19:29:38,581 - tydom.MessageHandler - WARNING - Unknown device name (1674257690_1674257690)
2023-05-21 19:29:38,581 - tydom.MessageHandler - WARNING - Unknown device type (1674257690_1674257690)
2023-05-21 19:29:38,581 - tydom.MessageHandler - INFO    - Device update (id=1674257690, endpoint=1674257690, name=, type=)
2023-05-21 19:29:39,739 - tydom.MessageHandler - WARNING - Unknown device name (1674257212_1674257212)
2023-05-21 19:29:39,739 - tydom.MessageHandler - WARNING - Unknown device type (1674257212_1674257212)
2023-05-21 19:29:39,740 - tydom.MessageHandler - INFO    - Device update (id=1674257212, endpoint=1674257212, name=, type=)
2023-05-21 19:29:42,120 - tydom.MessageHandler - WARNING - Unknown device name (1674257690_1674257690)
2023-05-21 19:29:42,121 - tydom.MessageHandler - WARNING - Unknown device type (1674257690_1674257690)
2023-05-21 19:29:42,121 - tydom.MessageHandler - INFO    - Device update (id=1674257690, endpoint=1674257690, name=, type=)
2023-05-21 19:35:39,459 - tydom.MessageHandler - WARNING - Unknown device name (1674257690_1674257690)
2023-05-21 19:35:39,459 - tydom.MessageHandler - WARNING - Unknown device type (1674257690_1674257690)
2023-05-21 19:35:39,459 - tydom.MessageHandler - INFO    - Device update (id=1674257690, endpoint=1674257690, name=, type=)
2023-05-21 19:38:43,706 - tydom.MessageHandler - WARNING - Unknown device name (1674257690_1674257690)
2023-05-21 19:38:43,706 - tydom.MessageHandler - WARNING - Unknown device type (1674257690_1674257690)
2023-05-21 19:38:43,706 - tydom.MessageHandler - INFO    - Device update (id=1674257690, endpoint=1674257690, name=, type=)
2023-05-21 19:41:40,339 - tydom.MessageHandler - WARNING - Unknown device name (1674257690_1674257690)
2023-05-21 19:41:40,340 - tydom.MessageHandler - WARNING - Unknown device type (1674257690_1674257690)
2023-05-21 19:41:40,340 - tydom.MessageHandler - INFO    - Device update (id=1674257690, endpoint=1674257690, name=, type=)
2023-05-21 19:44:40,774 - tydom.MessageHandler - WARNING - Unknown device name (1674257212_1674257212)
2023-05-21 19:44:40,774 - tydom.MessageHandler - WARNING - Unknown device type (1674257212_1674257212)
2023-05-21 19:44:40,775 - tydom.MessageHandler - INFO    - Device update (id=1674257212, endpoint=1674257212, name=, type=)
2023-05-21 19:44:45,096 - tydom.MessageHandler - WARNING - Unknown device name (1674257690_1674257690)
2023-05-21 19:44:45,096 - tydom.MessageHandler - WARNING - Unknown device type (1674257690_1674257690)
2023-05-21 19:44:45,097 - tydom.MessageHandler - INFO    - Device update (id=1674257690, endpoint=1674257690, name=, type=)
maybe you can now close issue #63 Support for tydom username & password login · Issue #63 · fmartinou/tydom2mqtt · GitHub
I’ve created a new PR to fix the disconnection problem. I have it running successfully for a few days now
hello, i’m a newby with HA and Tydom, for some physicall constraint, the only solution i find is to install some deltadore devices, tyxia 5731 (+ telco tyxia 1705) + tydom Pro to manage venetian blinds (up/down/stop/slats)
before i will buy all the material (10 pack + tydom) i have to be sure i will be able to drive all the venetian blinds with HA (on RPI4, HAOS, 32bit)
so my questions are:
1 - is Tydom Pro compatible ?
2 - what is to do about the user / password of the tydom (do i need to do something ?)
3 - what release / addon do i have to install on HA (HACS / standard / …)
4 - may i have to create a new user on HA ?
5 - are the tyxia 5731 already integrated or do i need to add something manually somewhere?
before i asked, i took a time to read a great part of this topic, sorry if all theses questions are obvious and
thank you for anyone to take a time to answser and add comments before i spend a lot of money with this solution.
Same error, had it 3 times in the last week whereas I had no issue until now. I’m forced to restart the addon when that happens. I’m wondering what changed to have this issue only now. :thinking:
There’s a pending pull request for this. you can try to apply the patch on your installation :
the cause is probably a firmware update which causes the connection to be closed by the tydom after a delay
I’ve a installation of tydom2mqtt who works since many months.
I’ve added a new door sensor and rename the other one but I can’t see the new sensor and the old renamed.
However I can arm/unarm alarm.
But in logs I’ve an error who is perhaps linked to these problems :
Call stack:
  File "/app/main.py", line 125, in <module>
    main()
  File "/app/main.py", line 121, in main
    loop.run_forever()
    self._run_once()
    handle._run()
  File "/app/main.py", line 55, in listen_tydom
  File "/app/tydom/MessageHandler.py", line 309, in incoming_triage
  File "/app/tydom/MessageHandler.py", line 346, in parse_response
Arguments: ('[]\r\n',)
Any idea ?
La dernière version 3.4.1 semble résoudre le problème. Je vois bien les nouveaux appareils ajoutés sur le Tydom.
Par contre, j’ai maintenant un message qui ne semble pas bloquant.
2023-09-02 17:07:23,360 - tydom.MessageHandler - WARNING - Unknown message type received ([]
Et bien que je vois les nouveaux devices dans les logs de l’addon Tydom2Mqtt, ils n’apparaissent pas dans HA malgré des redémarrages…
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Add-on: Tydom2MQTT - Beta
 Link between a Delta Dore's Tydom 1.0 Hub and and a MQTT broker, unofficial of course, hassio addon version
 Add-on version: release_v1.2.4
 You are running the latest version of this add-on.
parse error: Expected string key before ':' at line 1, column 4
[21:46:27] ERROR: Unknown HTTP error occured
 System:   (aarch64 / raspberrypi3-64)
 Home Assistant Core: 2023.8.4
 Home Assistant Supervisor: 2023.08.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to DEBUG
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
Starting /opt/tydom2mqtt/main.py
I’m trying to install Tydom Beta, but it hangs for 10 seconds after installation. I’ve tried debugging, but the error remains the same.
My Discord : Shadorlo
[fix-attrs.d] done.
[23:38:07] ERROR: Unknown HTTP error occured
 Home Assistant Supervisor: 2023.08.3
Log level is set to INFO
[cont-init.d] done.
[services.d] done.
STARTING TYDOM2MQTT
Dectecting environnement......
/data/options.json detected ! Hassio Addons Environnement : parsing options.json....
{'TYDOM_MAC': '********', 'TYDOM_IP': '192.168.1.16', 'TYDOM_PASSWORD': '*******', 'TYDOM_ALARM_PIN': 123456, 'TYDOM_ALARM_HOME_ZONE': 1, 'TYDOM_ALARM_NIGHT_ZONE': 2, 'MQTT_HOST': 'localhost', 'MQTT_USER': 'userrrrr', 'MQTT_PASSWORD': 'userrrr', 'MQTT_PORT': 1883, 'MQTT_SSL': False, 'log_level': 'info'}
Initialising TydomClient Class
Setting local mode context.
Starting main loop_task
Attempting MQTT connection...
MQTT host :  localhost
MQTT user :  userrrrr
Subscribing to :  +/tydom/#
TYDOM WEBSOCKET CONNECTION INITIALISING....
Building headers, getting 1st handshake and authentication....
Upgrading http connection to websocket....
Attempting websocket connection with tydom hub.......................
Host Target :
192.168.1.16
Tydom Client is connected to websocket and ready !
Requesting 1st data...
>>>>>>>>>> Sending to tydom client..... GET /info
>>>>>>>>>> Sending to tydom client..... POST /refresh/all
>>>>>>>>>> Sending to tydom client..... GET /configs/file
>>>>>>>>>> Sending to tydom client..... GET /devices/data
<<<<<<<<<< Receiving from tydom_client...
receiveMessage error
RAW :
b'HTTP/1.1 200 OK\r\nServer: Tydom-*******\r\nUri-Origin: /info\r\nContent-Type: application/json\r\nTransfer-Encoding: chunked\r\nTransac-Id: 0\r\n\r\n1\r\n{\r\n18\r\n"productName": "TYDOM2",\r\n16\r\n"mac": "***********",\r\n11\r\n"config": "prod",\r\n12\r\n"bddEmpty": false,\r\nF\r\n"bddStatus": 0,\r\n10\r\n"apiMode": true,\r\n1C\r\n"mainVersionSW": "03.08.19",\r\n1C\r\n"mainVersionHW": "00.00.01",\r\n14\r\n"mainId": "6414118",\r\n1C\r\n"mainReference": "21260010",\r\n1B\r\n"keyVersionSW": "01.04.14",\r\n1B\r\n"keyVersionHW": "00.00.01",\r\n1E\r\n"keyVersionStack": "04.00.50",\r\n1B\r\n"keyReference": "21260011",\r\n31\r\n"bootReference": "", "bootVersion": "02.211.128",\r\n10\r\n"TYDOM.dat": 43,\r\n12\r\n"config.json": 43,\r\nE\r\n"mom.json": 0,\r\n13\r\n"gateway.dat": 176,\r\nF\r\n"bdd.json": 12,\r\n12\r\n"collect.json": 1,\r\n12\r\n"groups.json": 40,\r\n13\r\n"mom_api.json": 18,\r\n13\r\n"scenario.json": 2,\r\n11\r\n"site.json": 378,\r\n12\r\n"bdd_mig.json": 1,\r\n13\r\n"info_mig.json": 0,\r\n13\r\n"info_col.json": 0,\r\n12\r\n"absence.json": 9,\r\n13\r\n"anticip.json": 16,\r\n12\r\n"trigger.json": 0,\r\n12\r\n"bioclim.json": 0,\r\n16\r\n"data_config.json": 0,\r\n26\r\n"urlMediation": "mediation.tydom.com",\r\n15\r\n"pltRegistered":true,\r\n19\r\n"updateAvailable": false,\r\n17\r\n"passwordEmpty": false,\r\nF\r\n"maintenance":{\r\n28\r\n"id": "ffffffffffffffffffffffffffffffff"\r\n2\r\n},\r\nB\r\n"geoloc": {\r\n15\r\n"longitude": 1405123,\r\n14\r\n"latitude": 43996921\r\n2\r\n},\r\nA\r\n"clock": {\r\n25\r\n"clock": "2023-09-05T23:38:14+02:00",\r\n10\r\n"source": "ntp",\r\nF\r\n"timezone": 60,\r\n14\r\n"summerOffset": "ON"\r\n2\r\n},\r\nC\r\n"moments": {\r\nC\r\n"suspend": {\r\n7\r\n"to": 0\r\n3\r\n}},\r\nF\r\n"local_claim":{\r\n12\r\n"status": "CLOSE",\r\n24\r\n"lastAccess": "2014-01-01T00:00:00Z"\r\n2\r\n},\r\nC\r\n"weather": {\r\n28\r\n"outTempSrc":{"devId":null,"epId":null},\r\n27\r\n"weatherSrc":{"devId":null,"epId":null}\r\n2\r\n},\r\nE\r\n"protocols": [\r\n71\r\n{"protocol":"X3D", "available":true, "installed":true, "ready":true, "status":"running", "installStatus":"idle"},\r\n3B\r\n{"protocol":"ZIGBEE", "available":true, "installed":false},\r\n27\r\n{"protocol":"X3DV", "available":false},\r\n2C\r\n{"protocol":"PltService", "available":false}\r\n1\r\n]\r\n1\r\n}\r\n0\r\n\r\n'
Incoming payload :
None
Error :
type object 'HTTPResponse' has no attribute 'from_httplib'
Exiting to ensure systemd restart....
I have now managed to connect it:
“Tydom Client is connected to websocket and ready!”
But I’m getting lots of errors. What can I do?
I’m unable to see new devices on MQTT.
Especially « belmDoor » type devices.
However, I can enable/disable alarm.
sensors.Sensor       - INFO    - Binary sensor created / updated : kernelUpToDate ON
2023-10-01 17:58:05,648 - sensors.Alarm        - INFO    - Alarm created / updated : Tyxal Alarm 1520677197_1520677197 disarmed
2023-10-01 17:58:05,648 - tydom.MessageHandler - INFO    - Device update (id=1619877546, endpoint=1619877546, name=Porte balcon, type=belmDoor)
2023-10-01 17:58:05,649 - sensors.Sensor       - INFO    - Binary sensor created / updated : intrusionDetect OFF
2023-10-01 17:58:05,650 - tydom.MessageHandler - INFO    - Device update (id=1693389439, endpoint=1693389439, name=Porte salle bas, type=belmDoor)
2023-10-01 17:58:05,651 - sensors.Sensor       - INFO    - Binary sensor created / updated : intrusionDetect OFF
2023-10-01 17:58:05,659 - tydom.MessageHandler - WARNING - Unknown message type received ([]
Do you know why ?
Any solution to this problem?
