I couldn’t make it work on the esphome but now I made it work on a rpi using python script, in thonny. I made some changes to the code for A02 ultrasonic sensor from dfrobot
Library file
@file DFRobot_RaspberryPi_A02YYUW.py
@brief Ranging distance sensor。
@copyright Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
@license The MIT License (MIT)
@author Arya([email protected])
@version V1.0
@date 2021-08-30
@url https://github.com/DFRobot/DFRobot_RaspberryPi_A02YYUW
import serial
import time
class DFRobot_A02_Distance:
## Board status
STA_OK = 0x00
STA_ERR_CHECKSUM = 0x01
STA_ERR_SERIAL = 0x02
STA_ERR_CHECK_OUT_LIMIT = 0x03
STA_ERR_CHECK_LOW_LIMIT = 0x04
STA_ERR_DATA = 0x05
## last operate status, users can use this variable to determine the result of a function call.
last_operate_status = STA_OK
## variable
distance = 0
## Maximum range
distance_max = 4500
distance_min = 0
range_max = 4500
def __init__(self):
@brief Sensor initialization.
self._ser = serial.Serial("/dev/ttyUSB0", 9600)
if self._ser.isOpen() != True:
self.last_operate_status = self.STA_ERR_SERIAL
def set_dis_range(self, min, max):
self.distance_max = max
self.distance_min = min
def getDistance(self):
@brief Get measured distance
@return measured distance
self._ser.write(b'\xFF')
self._measure()
return self.distance
def _check_sum(self, l):
return (l[0] + l[1] + l[2])&0x00ff
def _measure(self):
data = [0]*4
i = 0
timenow = time.time()
while (self._ser.inWaiting() < 4):
time.sleep(0.01)
if ((time.time() - timenow) > 1):
break
rlt = self._ser.read(self._ser.inWaiting())
#print(rlt)
index = len(rlt)
if(len(rlt) >= 4):
index = len(rlt) - 4
while True:
try:
data[0] = ord(rlt[index])
except:
data[0] = rlt[index]
if(data[0] == 0xFF):
break
elif (index > 0):
index = index - 1
else:
break
#print(data)
if (data[0] == 0xFF):
try:
data[1] = ord(rlt[index + 1])
data[2] = ord(rlt[index + 2])
data[3] = ord(rlt[index + 3])
except:
data[1] = rlt[index + 1]
data[2] = rlt[index + 2]
data[3] = rlt[index + 3]
i = 4
#print(data)
if i == 4:
sum = self._check_sum(data)
if sum != data[3]:
self.last_operate_status = self.STA_ERR_CHECKSUM
else:
self.distance = data[1]*256 + data[2]
self.last_operate_status = self.STA_OK
if self.distance > self.distance_max:
self.last_operate_status = self.STA_ERR_CHECK_OUT_LIMIT
self.distance = self.distance_max
elif self.distance < self.distance_min:
self.last_operate_status = self.STA_ERR_CHECK_LOW_LIMIT
self.distance = self.distance_min
else:
self.last_operate_status = self.STA_ERR_DATA
Ultrasonic loop
# -*- coding:utf-8 -*-
@file demo_get_distance.py
@brief Get ranging data.
@n Connect board with raspberryPi with TTL to USB adapter
@n
@n
@Copyright Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
@author [Arya]([email protected])
@version V1.0
@date 2019-8-31
import sys
import os
import time
sys.path.append(os.path.dirname(os.path.dirname(os.path.realpath(__file__))))
from DFRobot_RaspberryPi_A02YYUW import DFRobot_A02_Distance as Board
board = Board()
file='/home/rpi/q.wav'
file_wav=wave.open(file)
frequency=file_wav.getframerate()
mixer.init(frequency=frequency)
mixer.music.load("q.wav")
mixer.music.set_volume(1)
def print_distance(dis):
if board.last_operate_status == board.STA_OK:
print("Distance %d cm" %dis)
elif board.last_operate_status == board.STA_ERR_CHECKSUM:
print("ERROR")
elif board.last_operate_status == board.STA_ERR_SERIAL:
print("Serial open failed!")
elif board.last_operate_status == board.STA_ERR_CHECK_OUT_LIMIT:
print("Above the upper limit: %d" %dis)
elif board.last_operate_status == board.STA_ERR_CHECK_LOW_LIMIT:
print("Below the lower limit: %d" %dis)
elif board.last_operate_status == board.STA_ERR_DATA:
print("No data!")
if __name__ == "__main__":
#Minimum ranging threshold: 0mm
dis_min = 260
#Highest ranging threshold: 4500mm
dis_max = 4500
board.set_dis_range(dis_min, dis_max)
while True:
distance = board.getDistance()
print_distance(distance/10)
#Delay time < 0.6s
time.sleep(0.3)
i´m a beginner in Home assistent.
I´ve tried to conifgure my AJ-SR04M with a esp8266 like you explained in this post.
Do not work. Can you explain for “dummies” =
