Ubiquiti AP always "away"
Since a couple releases back I´m having issues with my Ubiquiti AP.
They are always shown as “away”
Anyone else having this?
The AP:s are connected Router - switch (POE) - AP and I don´t know if the problem is with the device tracker ASUS WRT or the Ubiquiti tracker.
If I remove them from know_devices they are picked up again by HASS but never as “home”
I had a device that did this no matter what I did. I ended up using the Ping device tracker; may work for you.
Seems to be working, thanks!
What version controller are you using?
Ubuiquiti component hasnt worked since 0.36.
Starts OK but stops reporting after 15minutes and shows error.
I looked into this and I see it logging into the controller but it seems that something is not working with that
Ping is helpful, but not really a solution as the problem is not because devices stop reporting (like IOS disconnect from wifi).
Hi
Yes I know the Ping will probably only solve the away/home mode for the device and not the real Unifi component functionality.
I´m running 5.4.11 as controller.
