If you or someone with design skill wants to create a Home Assistant Banner black and white bitmap (128 pixels wide x 32 pixels tall), I can encode it and add it to the rotation.
Nice work @dcwalter. I have added a few images to the img directory. Also to note, that the Memory, and Disk screen seen to be pushed left, compared to CPU Screen.
One thing I forgot about was the CPU Usage, grep -bn1 | grep load | awk ‘{printf “%.2f”, $(NF-2)}’", “r” does not seem to work in HA Pi.
New Pull Request with the HA logo screen added and the CPU load grep command fixed. Thanks for creating the BMP and corresponding header file. I’ll work on the logo alignment and some general code cleanup next. Then I will move onto enabling for more user customization without having to modify the C code.
This is super cool, I love when I think to myself “I should figure out how to do this” and then it is already done. I am running into an issue though.
Log output:
[17:11:47] INFO: Disable Auto Start = false
/dev/i2c-1
[17:11:47] INFO: Got i2c access! WoHOo!
[17:11:47] INFO: Display Info to OLED
Screen output.
Any thoughts or tips?
Have you tested the OLED is not faulty? cable is seated properly? I never got an error like this.
Before enabling the addon, the display was properly displaying the ‘untronics’ logo with the triple dots.
Moved the SD card to the next RPI over, which is/was raspbian and [raspbian] was displaying system info, and the result was the same bunch of dots. Granted my raspbian/ubuntu pi’s are using the C code version.
I utilized this to configure the i2c: [add-on] HassOS I2C Configurator - Home Assistant OS - Home Assistant Community (home-assistant.io)
crw--w---- 1 root tty 4, 27 Oct 12 09:24 tty27
crw--w---- 1 root tty 4, 28 Oct 12 09:24 tty28
crw--w---- 1 root tty 4, 29 Oct 12 09:24 tty29
crw--w---- 1 root tty 4, 3 Oct 12 09:24 tty3
crw--w---- 1 root tty 4, 30 Oct 12 09:24 tty30
crw--w---- 1 root tty 4, 31 Oct 12 09:24 tty31
crw--w---- 1 root tty 4, 32 Oct 12 09:24 tty32
crw--w---- 1 root tty 4, 33 Oct 12 09:24 tty33
crw--w---- 1 root tty 4, 34 Oct 12 09:24 tty34
crw--w---- 1 root tty 4, 35 Oct 12 09:24 tty35
crw--w---- 1 root tty 4, 36 Oct 12 09:24 tty36
crw--w---- 1 root tty 4, 37 Oct 12 09:24 tty37
crw--w---- 1 root tty 4, 38 Oct 12 09:24 tty38
crw--w---- 1 root tty 4, 39 Oct 12 09:24 tty39
crw--w---- 1 root tty 4, 4 Oct 12 09:24 tty4
crw--w---- 1 root tty 4, 40 Oct 12 09:24 tty40
crw--w---- 1 root tty 4, 41 Oct 12 09:24 tty41
crw--w---- 1 root tty 4, 42 Oct 12 09:24 tty42
crw--w---- 1 root tty 4, 43 Oct 12 09:24 tty43
crw--w---- 1 root tty 4, 44 Oct 12 09:24 tty44
crw--w---- 1 root tty 4, 45 Oct 12 09:24 tty45
crw--w---- 1 root tty 4, 46 Oct 12 09:24 tty46
crw--w---- 1 root tty 4, 47 Oct 12 09:24 tty47
crw--w---- 1 root tty 4, 48 Oct 12 09:24 tty48
crw--w---- 1 root tty 4, 49 Oct 12 09:24 tty49
crw--w---- 1 root tty 4, 5 Oct 12 09:24 tty5
crw--w---- 1 root tty 4, 50 Oct 12 09:24 tty50
crw--w---- 1 root tty 4, 51 Oct 12 09:24 tty51
crw--w---- 1 root tty 4, 52 Oct 12 09:24 tty52
crw--w---- 1 root tty 4, 53 Oct 12 09:24 tty53
crw--w---- 1 root tty 4, 54 Oct 12 09:24 tty54
crw--w---- 1 root tty 4, 55 Oct 12 09:24 tty55
crw--w---- 1 root tty 4, 56 Oct 12 09:24 tty56
crw--w---- 1 root tty 4, 57 Oct 12 09:24 tty57
crw--w---- 1 root tty 4, 58 Oct 12 09:24 tty58
crw--w---- 1 root tty 4, 59 Oct 12 09:24 tty59
crw--w---- 1 root tty 4, 6 Oct 12 09:24 tty6
crw--w---- 1 root tty 4, 60 Oct 12 09:24 tty60
crw--w---- 1 root tty 4, 61 Oct 12 09:24 tty61
crw--w---- 1 root tty 4, 62 Oct 12 09:24 tty62
crw--w---- 1 root tty 4, 63 Oct 12 09:24 tty63
crw--w---- 1 root tty 4, 7 Oct 12 09:24 tty7
crw--w---- 1 root tty 4, 8 Oct 12 09:24 tty8
crw--w---- 1 root tty 4, 9 Oct 12 09:24 tty9
crw-rw---- 1 root audio 204, 64 Feb 9 18:25 ttyAMA0
crw------- 1 root root 5, 3 Oct 12 09:24 ttyprintk
crw------- 1 root root 10, 239 Oct 12 09:24 uhid
crw------- 1 root root 10, 223 Oct 12 09:24 uinput
crw-rw-rw- 1 root root 1, 9 Oct 12 09:24 urandom
drwxr-xr-x 3 root root 60 Oct 12 09:24 v4l
crw------- 1 root root 247, 0 Oct 12 09:24 vc-mem
crw------- 1 root root 242, 0 Oct 12 09:24 vchiq
crw------- 1 root root 10, 61 Oct 12 09:24 vcio
crw-rw---- 1 root tty 7, 0 Oct 12 09:24 vcs
crw-rw---- 1 root tty 7, 1 Oct 12 09:24 vcs1
crw-rw---- 1 root tty 7, 2 Feb 9 18:25 vcs2
crw-rw---- 1 root tty 7, 3 Feb 9 18:25 vcs3
crw-rw---- 1 root tty 7, 4 Feb 9 18:25 vcs4
crw-rw---- 1 root tty 7, 5 Feb 9 18:25 vcs5
crw-rw---- 1 root tty 7, 6 Feb 9 18:25 vcs6
crw-rw---- 1 root tty 7, 128 Oct 12 09:24 vcsa
crw-rw---- 1 root tty 7, 129 Oct 12 09:24 vcsa1
crw-rw---- 1 root tty 7, 130 Feb 9 18:25 vcsa2
crw-rw---- 1 root tty 7, 131 Feb 9 18:25 vcsa3
crw-rw---- 1 root tty 7, 132 Feb 9 18:25 vcsa4
crw-rw---- 1 root tty 7, 133 Feb 9 18:25 vcsa5
crw-rw---- 1 root tty 7, 134 Feb 9 18:25 vcsa6
crw-rw-rw- 1 root root 10, 58 Oct 12 09:24 vcsm-cma
crw-rw---- 1 root tty 7, 64 Oct 12 09:24 vcsu
crw-rw---- 1 root tty 7, 65 Oct 12 09:24 vcsu1
crw-rw---- 1 root tty 7, 66 Feb 9 18:25 vcsu2
crw-rw---- 1 root tty 7, 67 Feb 9 18:25 vcsu3
crw-rw---- 1 root tty 7, 68 Feb 9 18:25 vcsu4
crw-rw---- 1 root tty 7, 69 Feb 9 18:25 vcsu5
crw-rw---- 1 root tty 7, 70 Feb 9 18:25 vcsu6
crw------- 1 root root 10, 63 Oct 12 09:24 vga_arbiter
crw------- 1 root root 10, 137 Oct 12 09:24 vhci
crw-rw-rw- 1 root 1010 10, 238 Oct 12 09:24 vhost-net
crw-rw-rw- 1 root 1010 10, 241 Oct 12 09:24 vhost-vsock
crw-rw---- 1 root netdev 81, 8 Oct 12 09:24 video10
crw-rw---- 1 root netdev 81, 9 Oct 12 09:24 video11
crw-rw---- 1 root netdev 81, 10 Oct 12 09:24 video12
crw-rw---- 1 root netdev 81, 0 Oct 12 09:24 video13
crw-rw---- 1 root netdev 81, 1 Oct 12 09:24 video14
crw-rw---- 1 root netdev 81, 2 Oct 12 09:24 video15
crw-rw---- 1 root netdev 81, 3 Oct 12 09:24 video16
crw-rw---- 1 root netdev 81, 11 Oct 12 09:24 video18
crw-rw---- 1 root netdev 81, 4 Oct 12 09:24 video20
crw-rw---- 1 root netdev 81, 5 Oct 12 09:24 video21
crw-rw---- 1 root netdev 81, 6 Oct 12 09:24 video22
crw-rw---- 1 root netdev 81, 7 Oct 12 09:24 video23
crw------- 1 root root 10, 130 Oct 12 09:24 watchdog
crw------- 1 root root 249, 0 Oct 12 09:24 watchdog0
crw-rw-rw- 1 root root 1, 5 Oct 12 09:24 zero
brw-rw---- 1 root disk 254, 0 Oct 12 09:24 zram0
brw-rw---- 1 root disk 254, 1 Oct 12 09:24 zram1
brw-rw---- 1 root disk 254, 2 Oct 12 09:24 zram2
/dev/i2c-1
/dev/i2c-0 /dev/i2c-1 /dev/i2c-10 /dev/i2c-22
Found i2c access! Nothing to do! You can remove this add-on.
Morse code for “Home Assistant”?
HAHAH. UM, you did the bit first to enable I2C a?
Yup! So interestingly, i switched to the deprecated C
version and it’s displaying some info? Like almost as if the lines are cut off or something.
I’m gonna try the old uninstall/reinstall again, maybe something barfed during the python compilation.
Same thing. Tried with protected and unprotected mode as well.
22-02-09 19:10:09 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on b019ed12/aarch64-addon-uctronics_oled_display_python with version 2021.10.25.003
22-02-09 19:10:11 INFO (MainThread) [supervisor.api.middleware.security] /os/info access from b019ed12_uctronics_oled_display_python
22-02-09 19:10:11 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from b019ed12_uctronics_oled_display_python
22-02-09 19:10:27 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from b019ed12_uctronics_oled_display_python
22-02-09 19:10:27 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from b019ed12_uctronics_oled_display_python
22-02-09 19:10:37 INFO (MainThread) [supervisor.api.middleware.security] /os/info access from b019ed12_uctronics_oled_display_python
22-02-09 19:10:37 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from b019ed12_uctronics_oled_display_python
22-02-09 19:10:53 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from b019ed12_uctronics_oled_display_python
22-02-09 19:10:53 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from b019ed12_uctronics_oled_display_python
22-02-09 19:11:03 INFO (MainThread) [supervisor.api.middleware.security] /os/info access from b019ed12_uctronics_oled_display_python
22-02-09 19:11:03 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from b019ed12_uctronics_oled_display_python
22-02-09 19:11:17 INFO (SyncWorker_2) [supervisor.docker.interface] Stopping addon_b019ed12_uctronics_oled_display_python application
22-02-09 19:11:18 INFO (SyncWorker_2) [supervisor.docker.interface] Cleaning addon_b019ed12_uctronics_oled_display_python application
22-02-09 19:11:19 WARNING (MainThread) [supervisor.api.addons] Changing protected flag for b019ed12_uctronics_oled_display_python!
22-02-09 19:11:22 WARNING (SyncWorker_2) [supervisor.docker.addon] UCTRONICS OLED Display (Python) running with disabled protected mode!
22-02-09 19:11:24 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on b019ed12/aarch64-addon-uctronics_oled_display_python with version 2021.10.25.003
22-02-09 19:11:25 INFO (MainThread) [supervisor.api.middleware.security] /os/info access from b019ed12_uctronics_oled_display_python
22-02-09 19:11:25 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from b019ed12_uctronics_oled_display_python
22-02-09 19:11:41 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from b019ed12_uctronics_oled_display_python
22-02-09 19:11:41 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from b019ed12_uctronics_oled_display_python
Install the docker addon, then restart HA with the AutoStart function turned off on my project. Enter docked, and then the bash line, and try it manually.
There are some basic linux commands to check is i2c is available.
Is this integration still working? Is there a full list of steps to get this working on HA besides just installing the add-on?
HI Ryan, I have not used this in a while now as I have upgraded my HA hardware. How ever before I did my upgrade maybe 3 months ago it was working.
