Just to be clear, LightwaveRF definitely doesn’t require neutral.
The Energenie MIH024 also does not require a neutral. You can’t dim bulbs, it’s purely a switch but you really want to use dimmable LED bulbs, otherwise you may find the bulbs flicker/pulse when off.
These are readily available from Amazon UK (£18.99 at the moment) and have seen them in Screwfix.
I did have one that buzzed and smelled of burning which I sent back to Amazon and reported it directly to Energenie as well, which was replaced. This obviously knocked my confidence in them a bit.
The biggest 2 problems with the Energenie is it does not report its status (off/on) to Home Assistant and there can sometimes be a delay when turning off or on with Home Assistant.
While these work I am still searching for the perfect solution for UK lighting with NO neutral.
Any recommended tasmota-flashable UK wall switches similar to Sonoff T1 UK with some tactile feedback?
I already have various Sonoff T1 UK installed, not 100% reliable to be quite honest and the lack of “tactile” feedback on switching them off is unnatural.
did you find anything please? not a fan of the sonoff touch and I am doing out my garage, so I will have a neutral
what about aqara switch zigbee version ? about £25. It doesnt require neutral.
