Hi
First time posting here - but i have been very actively reading and learning from others.
I have a few esphome projects - from automatic door opening linear actuators (for hot cupboards with water coolers) to integrations with texecom alarms
I have a problem I have been scratching my head over for weeks!
I have a ultrasonic sensor attached to an ESP8266 suspended above a bin. My intention is that i can tell when the bin men collect this bin (from a period of 30 seconds or so). I would then (ideally) want to get an alert “bin collected”… or better if i haven’t seen this collection by a cut off time (lets say 1630 on bin collection day) i would be nofified.
I started with a straight forward approach, ultrasonic sensor triggering a binary sensor when a range is hit. I added smoothing and averaging for robustness - following other examples.
I have one main issue… the esp8266 is quite a way from the house. i have mounted an external access point and done the best i can. in good weather signal sits at -75db in bad it just popps over -80db - meaning the device loses connection.
i think i can work around this by: disabling the API and maybe logging the bin presence via MQTT. i need this to somehow be fault tolerant… so ideally even if it gets one message through an hour - if that message could say if the bin was collected that would be fine.
i was thinking i would mesasge a timestamp… maybe repeatedly and allow some to fail. the two issues with that are 1) i can’t use the time directive without the API enabled. 2) even with API disabled - it still seems to fail.
Any help much appreciated
code below doesn’t do MQTT publish (as time is broken) but i have tried this too and the thing still seems to change to unavailable -even on the MQTT derived sensor.
substitutions:
device_id: "bin-sensor-left"
device_name: "Bin Sensor Left"
distance_update_time: 2s
wifi_update_time: 30s
heartbeat_interval: 5s
esp8266:
board: d1_mini
logger:
level: INFO
#api:
ota:
safe_mode: true
num_attempts: 5
wifi:
reboot_timeout: 5h
use_address: 192.168.0.33
networks:
- ssid: !secret outdoor_wifi_ssid
password: !secret outdoor_wifi_password
priority: 0.8
manual_ip:
static_ip: 192.168.0.33
gateway: 192.168.0.1
subnet: 255.255.254.0
dns1: 192.168.0.1
dns2: 1.1.1.1
ap:
ssid: "Fallback ${device_id}"
password: "secret password"
captive_portal:
web_server:
port: 80
auth:
username: !secret esphome_web_username
password: !secret esphome_web_password
globals:
#distance from sensor to top of bin
- id: bin_height
type: float
initial_value: '0.8'
#doesn't work when API disabled
time:
- platform: homeassistant
- platform: wifi_signal
name: "${device_name} Wifi Signal"
update_interval: ${wifi_update_time}
internal: true
- platform: uptime
update_interval: ${heartbeat_interval}
internal: true
name: $device_name Last Collected
device_class: timestamp
icon: mdi:calendar-clock
- platform: ultrasonic
trigger_pin: D6
echo_pin: D5
name: "${device_name} Distance"
update_interval: ${distance_update_time}
timeout: 3m
pulse_time: 13us
accuracy_decimals: 1
unit_of_measurement: "m"
icon: "mdi:ruler"
state_class: measurement
filters:
- filter_out: nan
- median:
window_size: 7
send_every: 4
send_first_at: 3
- delta: 0.2
binary_sensor:
device_class: presence
icon: "mdi:trash-can"
name: "${device_name} Presence"
lambda: |-
if (id(distance).state < id(bin_height)) {
// Presence is detected
return true;
} else {
// No presence detected.
return false;
on_release:
then:
- sensor.template.publish:
state: !lambda 'return id(homeassistant_time).now().timestamp;'
- text_sensor.template.publish:
state: !lambda |-
char str[17];
time_t currTime = id(homeassistant_time).now().timestamp;
strftime(str, sizeof(str), "%Y-%m-%d %H:%M", localtime(&currTime));
return { str };
filters:
- delayed_on_off: 10s
status_led:
pin:
number: GPIO2
inverted: false
mqtt:
topic_prefix: homeassistant
discovery: true
broker: my ip
port: 1883
username: mqtt_bin_sensor
password: SOMEPASSWORD
