@Robban - Looks to be working very well now. I am convinced.
One problem I have noticed though - when a restart (or start) of HA occurs, all tracked devices which were marked as home before the restart are initially marked as away after the restart. Within a couple of seconds, they are then marked as home.
I found this one out the hard way - some of my automations triggered after a HA restart at 3am (part of a regular HA restart to work around some Broadlink switch issues). They turned a heap of lights on, and then about 3-5 seconds later turned them off again. There are corresponding entries in the logbook directly after the āHome Assistant startedā message that show the device trackers are marked away, and marked home.
Hate to jump onto this topic, but Iām having the same issue myself. I have the controller setup in integrations and it has no trouble connecting from there, but the connection string inside the configuration.yaml file doesnāt seem to want to work at allā¦
No information is being provided in the error message.
Iām on Controller 5.10.26.0 @ Docker and Hass.io 0.97.2 and still get occasionally
āUnable to reach controller [FQDN]ā
Also, the original device_tracker had options for
When I configure the integrations with Unifi it adds all my network devices, and this causes problems further down, for example with my database that logs state changes.
Just so I am sure I understand.
That PR with the backend implementation is in the current release, but the PR that will contain the frontend is in another release that wonāt be include until version 0.98?
