Unable to get a value in a RESTful sensor
Please do not use images for showing your code: this is making it harder to respond with some modified code. It is better to post your code in correctly formatted form, like is shown here: Format it properly
Since you want to fetch the data from the source, you need to use the GET method instead of the POST method.
And then you have to define a list of the required json attributes.
See this example:
Try this:
  - platform: rest
    name: Airzone Guestroom status
    resource: http://192.168.1.242:3000/api/v1/hvac
    method: GET
    json_attributes:
      - systemID
      - zoneID
      - name
      - on
      - maxTemp
      - minTemp
      - setpoint
      - roomTemp
      - mode
      - coldStages
      - coldStage
      - heatStages
      - heatStage
      - humidity
      - units
      - errors
      - air_demand
      - floor_demand
This should provide you with a sensor delivering all the required data as attributes.
You can get specific attributes from that sensor with template sensors like this:
    sensors:
      airzone_systemid:
        friendly_name: "Airzone Guestroom System ID"
        value_template: "{{ state_attr('sensor.airzone_guestroom_status', 'systemID') }}"
      airzone_zoneid:
        friendly_name: "Airzone Guestroom Zone ID"
        value_template: "{{ state_attr('sensor.airzone_guestroom_status', 'zoneID') }}"
