Out of the blue I could not get to the frontend. It now continuously shows ‘loading data’
In the logs whenever I try and load the frontend I get the error:-
ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.139961146590352] Unable to serialize to JSON: Out of range float values are not JSON compliant
It then lists all of my entities in the logs.
It was on version 0.103.6 when this happened. I have tried going back to various previous versions with no luck.
I am running the stock docker image.
I cannot list the full error and entity list because it exceeds the maximum character limit per post.
