Unable to set cooling set point (split from WTH)
I agree. I have a zwave Nortek GoControl GC-TBZ48. Everything works fine in for controlling from the lovelace dashboards I’ve created. The issue is with creating an automation via the gui portal.
I’m wanting to set the temp higher when I leave and lower when I get home.
When I select the thermostat I only get two pulldown menu options.
  • change HVAC mode
  • change preset
There is no object that allows me to set a simple cooling setpoint
Any ideas ??
Thanks in advance
This is a completely different issue.
All you have to do is select service for the Action Type (instead of Device) to make available the services you want.
Thank you. Your reply is leading me down the right road.
Thanks for the guidance
Brad
