Thanks for the update. We are all here for the community
@gmlupatelli ciao. can you add an option to run the check every X minutes instead of once per day?
Merged. Thanks for adding the feature.
Been using this for a while and itās very helpful, thank you!
I have this in an auto entities dropdown in an admin dashboard, but is there a way to just show devices which have any unavailable entities instead of the entities themselves? Some of these devices have like 10 entities and I donāt need to see them individually because when they go offline itās always all of them.
Hello I have a little problem, using your notificationās text now I donāt receive nothing. anyway blueprint continue to discover unavailable entities. How I can receive a notify with these entities?
thank you
Is it possible to add an option to repeat the notification and the control every few hours?
I have done that White a extra automation.
I like this automation very much, and when i read this form i think there are some improvements:
add include, add every hour (i have done that with a extra automation),
and add the possibility that when every thing is in order there wil not send a notification.
I am not a master in blueprints:-(
After investigation it appears that the original blueprint does not send a notification if there are no missing entities, it was my automation that triggered the blueprint and then sent a notification. The only question now is how can I trigger this blueprint every hour?
Thanks for this great template. I just have one additional question how can I get the room or the given name of the unavailable sensor? Currently I receive something like this ālumi.remoteb1acn01 ā¦ā
I tried this blueprint but it does not work.
Ot always stops in the traces asking for an entries in the data field but i have no idea or found any hint what needs to go into the data field
To trigger it evrey hour you need to change this block of the blueprint:
# Triggers
- platform: time
at: !input 'time'
Here is the link to the Blueprint creation wiki: Creating an automation blueprint - Home Assistant
The original blueprint in the first post returns the names, e.g. Office - Light Controler, not the ID.
If you want to change what is returned, the part of the blueprint below is where the magic happens
Unfortunately, I donāt know enough to include room data in the blueprint.
entities: >-
{% set result = namespace(entities=[]) %}
{% for state in states %}
{% if exclude.entity_id is defined %}
{% if state.state == 'unavailable' and not state.entity_id in exclude.entity_id %}
{% set result.entities = result.entities + [state.entity_id] %}
{% endif %}
{% else %}
{% if state.state == 'unavailable' %}
{% endif %}
{% endif %}
{% endfor %}
{{"ā¤µ \n- "}}{{result.entities|join('\n- ')}}
It only execute the actions block if there is at least one unavailable entity, otherwise it just stops.
