What I was thinking/assuming changing device_class: duration will add units of time to the sensor, I.e make it human readable, e.g 3 days 12 Hours 20 mins and 12 secs, instead of current template, which mention largest unit only. 3 days 12:20:12.
That’s not a timestamp. If you add device_class: timestamp
to that sensor it won’t do anything except maybe create an error. See the docs for sensor device class:
timestamp: Datetime object or timestamp string (ISO 8601)
Your template clearly does not output a datetime object or a date string in ISO-8601 format so that’s not the correct device class for that sensor.
Change your template to this and add that device class and it might do what you want:
{{ now() - timedelta(seconds=states('sensor.huawei_igd_uptime') | int) }}
I think I should know device-classes better as well
I’d like to know how much time I have to spend heating the hotwater-boiler untill it is 100% “charged”
Looking at this post I thought I could add as device-class and state-class in the template-sensor, but it is not working, how might I get it to work ??
when adding unit of measurement, device-class and state-class the sensor goes “unavailable”
Have not tried customizing, as I believe it should work directly in template-sensor?
template:
- sensor:
- name: "Hotwater SoC chargetime float"
unique_id: hotwater_soc_chargetime_float
icon: "mdi:lightning-bolt-outline"
unit_of_measurement: "t"
state: >
{% set p = states('input_number.hotwater_soc_elementsize') | float %}
{% set kwh = states('sensor.hotwater_soc_energy_chargable') | float %}
{{ (kwh / p) | round(2) }}
# attributes:
# <<: *solution_attribute
- name: "Hotwater SoC chargetime"
icon: "mdi:store-24-hour"
# unit_of_measurement: "h"
# device_class: duration
# state_class: measurement
state: >
{% set hours = states('sensor.hotwater_soc_chargetime_float') | float %}
{% set minutes = ((hours % 1) * 60) | int %}
{% set hours = (hours - (hours % 1)) | int %}
{{ '%02i:%02i'%(hours, minutes) }}
I guess the consensus in the post was to customize, but I’m trying to create a template sensor which should be able to add the correct attributes?
I think I am missing something obvious?
the entities are presenting data that is correct, but should it not be possible to add the right classes somehow?
duration sensors need to have a unit of measurement that match the given output. I.e. a UOM of minutes and you output just minutes.
In your case, you output hours… so simply add a unit of measurement to your first one…
template:
- sensor:
state: >
Keep in mind that on the states page you will see the hours as the state. But wherever you put it in the UI, you’ll see the H:M:S.MS
Not really a consensus, since it’s not about opinion.
You can always (AFAIK) add these to customize.yaml
. Some sensors and other entity types support this in the definition, but not all. The documentation is accurate in that regard. Just check the specific integration’s docs. If the option isn’t there, it isn’t supported. In this case, for the new-style template sensors, both device_class
and state_class
can be set, as you’ve noted.
Can you elaborate?
EDIT: I think Petro spotted the missing piece.
Just noting that on cards with charts the raw state gets used on the y-axis – it won’t be formatted.
THAT was the obvious part I missed,
device classes help the frontend know how to display the icon and the format of the state text. The backend state will always be a raw value that’s untranslated.
so just trying to get it in with the smallest of spoons;)
device clases and unit of measurement are linked to front-end and how to display ?
state class is linked to “back-end” and decides calculation of statistics (with a little help from last_reset?
(Sensor Entity | Home Assistant Developer Docs)
Would love some guidance (for a noob), but not sure if there is any documentation other than Data | Home Assistant Data Science Portal? (which for me is waaaaay over my competancy-level (so reverting to case by case nagging in communities and forums )
device_class, UOM, and state_class are used by the frontend and the backend to do various things.
I would say, don’t worry about the details too much until you hit a special case. Just describe your data and sensors as accurately as possible, and set your locale: things will be displayed just fine most of the time. You can since a few months ago also change the unit prefix and precision from the UI — for some.
I’ve just stumbled across this thread as I’m dealing with the same issue (I think). I’ve got two ‘duration’ sensors from an ESPHome device. In the “Device Info” tab in HA those sensors are displayed as hh:mm:ss, but if I add the same sensors on a dashboard using an Entity card the raw sensor values are displayed. Entering ‘h’ in the ‘Unit’ field in the entity card doesn’t change the number displayed, it just adds ‘h’ after it.
Show the sensors with their data/config as one would see it under the states tab of the dev tools.
Remove the unit of measurement.
Ahh! I’ll give that a try locally and if it solves the issue will send a PR to ESPHome.
Sorry, I realised I’m doubting myself so I checked again. If that floating point number is number of seconds, please keep the UoM. I think the issue instead is that you have decimals (I think). Can you make it an integer value instead?
That didn’t have the desired effect; now the raw value shows up in the ‘Device Info’ page in addition to the Entity Card. They match, but the display isn’t what people would want to see
Sure, let me give that a try.
No luck so far; I’ve tried setting accuracy_decimals
to zero, and also tried changing the state class from TOTAL_INCREASING to MEASUREMENT. In all cases the data is formatted properly in the Device Info tab, but not on the Entity card.
Also note that this same symptom applies to the standard ‘uptime’ sensor in ESPHome, so it’s not specific to the component/sensor I’m using.
Show the dev state again so that we can be sure we get what we think we should.
Red herring. Don’t fiddle with this for now.
