Taking @Phuturist’s script as base, I’ve extended and adapted it so it can be used now with the UniFiOS driven units (UniFi Dream Machine).
Took me some time to discover the X-CSRF-Token trick and I’m a layman in python.
import argparse
import json
import logging
import requests
import sys
import urllib3
urllib3.disable_warnings(urllib3.exceptions.InsecureRequestWarning)
parser = argparse.ArgumentParser(description='Change the PoE Mode of UniFi switches controlled by a UDM (Pro).')
parser.add_argument("controller", help="hostname or IP address of UniFi Controller")
parser.add_argument("username", help="username with admin rights on UniFi Controller")
parser.add_argument("password", help="corresponding password for admin user")
parser.add_argument("mac", help="MAC address (with or without colons) of switch")
parser.add_argument("ports", help="port numbers to acquire new state (list separated by comma, e.g., '5,6,7'")
parser.add_argument("state", help="desired state of PoE ports, e.g., 'auto' or 'off'")
parser.add_argument("-v", "--verbose", help="increase output verbosity", action="store_true")
args=parser.parse_args()
# parameters
base_url = 'https://%s' % args.controller
login_endpoint = base_url + '/api/auth/login'
logout_endpoint = base_url + '/api/auth/logout'
login_data = {
'username': args.username,
'password': args.password
get_device_settings_endpoint = base_url + '/proxy/network/api/s/default/stat/device/%s' % args.mac
set_device_settings_endpoint = base_url + '/proxy/network/api/s/default/rest/device/'
ports_array = args.ports.split(',')
desired_poe_state = args.state
if (args.verbose):
loglevel=logging.DEBUG
else:
loglevel=logging.INFO
logging.basicConfig(level=loglevel, format='%(asctime)s - %(levelname)s - %(message)s')
# Logout - this requires the X-CSRF-Token
def logout():
logging.info("Logging out via %s.", logout_endpoint)
logout = s.post(logout_endpoint, headers = {'x-csrf-token': login.headers['X-CSRF-Token']}, verify = False, timeout = 1)
if (logout.status_code == 200):
logging.debug("Success.")
sys.exit()
else:
logging.debug("Failed with return code %s", logout)
sys.exit()
# Login and get auth token from Cookies plus X-CSRF-Token from header
# working call with cURL: Login:
# curl -X POST --data 'username=user&password=pass' -c cookie.txt https://udm/api/auth/login
# Get status:
# curl -X GET -b cookie.txt https://udm/proxy/network/api/s/default/stat/device/abcdef012
logging.info("Trying to login to %s with data %s", login_endpoint, str(login_data))
s = requests.Session()
headers = {
"Accept": "application/json",
"Content-Type": "application/json; charset=utf-8"
login = s.post(login_endpoint, headers = headers, json = login_data , verify = False, timeout = 1)
if (login.status_code == 200):
cookies = login.cookies
logging.debug("Success. Cookies received:")
for c in cookies:
logging.debug("%s ==> %s", c.name, c.value)
logging.debug("X-CSRF-Token: %s", login.headers['X-CSRF-Token'])
else:
logging.debug("Login failed with return code %s", login.status_code)
sys.exit()
# Get current port_overrides config for device
logging.info ("Read current settings from %s", get_device_settings_endpoint)
r = s.get(get_device_settings_endpoint, headers = headers, verify = False, timeout = 1)
if (r.status_code == 200):
else:
logging.debug("Failed with return code %s", r)
logout()
device_json = r.json()
port_overrides = device_json['data'][0]['port_overrides']
device_id = device_json['data'][0]['device_id']
set_device_settings_endpoint = set_device_settings_endpoint + device_id
# Update the port_overrides config with new settings
for x in ports_array:
for value in port_overrides:
if value['port_idx'] == int(x):
if 'poe_mode' in value:
if (value['poe_mode'] != desired_poe_state):
logging.info("Updating port_idx %s from %s to %s", value['port_idx'], value['poe_mode'], desired_poe_state)
value['poe_mode'] = desired_poe_state
else:
logging.info("port_idx %s already set to %s", value['port_idx'], desired_poe_state)
# Set the updated port_overides config for device
new_port_overrides = { 'port_overrides': port_overrides }
logging.info("Trying to update port overrides on %s", set_device_settings_endpoint)
logging.debug("%s", json.dumps(new_port_overrides))
headers = {
"Content-Type": "application/json; charset=utf-8",
"x-csrf-token": login.headers['X-CSRF-Token']
update = s.put(set_device_settings_endpoint, headers = headers, data = json.dumps(new_port_overrides), verify = False, timeout = 1)
if (update.status_code == 200):
else:
logging.debug("Failed with return code %s", update.status_code)
logout()
