Your posted config was with unifi direct platform
Robban, you are right
But can you give me an exampel how the unifi device tracker should be configured?
Sure. Have you looked at the integrating documentation?
Robban, I have following configuration today.
device_tracker:
- platform: unifi
host: 192.168.1.4
username: !secret device_tracker_username
password: !secret device_tracker_password
site_id: !secret device_tracker_site_id
verify_ssl: false
interval_seconds: 10
detection_time: 120
consider_home: 180
new_device_defaults:
track_new_devices: true
But I can not see any of my devices in HA.
Does the configuration look okay?
I suspect that my firewall is blocking the info from Unifi, what port does the device tracker use?
Maybe I need to open up the firewall.
Because I have my HA computer in a DMZ.
You have a few things not supported by the integration: https://www.home-assistant.io/integrations/unifi/#configuration-variables
Does this look better?
unifi:
controllers:
- host: unifi
site: !secret unifi_site
device_tracker:
- platform: unifi
host: 192.168.1.4
username: !secret unifi_username
password: !secret unifi_password
interval_seconds: 12
consider_home: 180
hide_if_away: false
But it still not work!
Nothing should be under device tracker, it should all be under unifi, look at the documentation again
Robban, please help me I donāt get it!
This is deprecated
device_tracker:
- platform: unifi
This is how you should do it
unifi:
controllers:
- host: unifi
site: My site
ssid_filter:
- 'HomeSSID'
- 'IoTSSID'
Robban,
Okay, but should I set āHomeSSIDā to my network SSID?
And should I also add username and password?
I didnāt understand how it should be configured
You can only configure existing set up unifi integration. So no you canāt set credentials. The rest of supported parameters are listed in the link above. Most things can also be configured through gui
Sorry Robban, I must be stupied but I donāt understand how I should set it up to get a device tacker function. I have been reading the documentation but I donāt get it.
I have a Unifi controller (cloude key) on ip-address 192.168.1.4 and the router has ip-address 192.168.1.1.
According to the document I have following code in configuration.yaml
unifi:
controllers:
- host: unifi
ssid_filter:
- 'HomeSSID'
- 'IoTSSID'
What is āHomeSSIDā and āIoTSSIDā in the exemple?
Should I change them?
Should I add an add-on in Hassio for Unifi?
The only thing I want to do is to track devices.
I handle the network from the cloude key and the controller
So you havenāt set up Unifi integration?
Home Assistant offers UniFi integration through Configuration -> Integrations -> UniFi Controller .
Enter host address
, user name
and password
and then continue to select which site
you want to connect to Home Assistant. The user needs administrator privileges in order to control POE switches.
Robban, do you mean the Unifi add-on in ADD-ON STORE ?
Iām handling/running my network on a Unifi cloud key.
Will it be any problem to run the Unifi add-on?
I would still like to running the unifi contoller on the cloud key.
Isnāt that clear?
Okay now I understand what you mean, I will tryā¦
I get following error when I try to connect to the Unifi controller.
Could have samething to do with my firewall settings, I need to check that I have access from Hassio to Unifi controller.
Should the āController using proper certificateā be used ?
It where the firewall that blocked me from configure the Unifi in the Configuration -> Integrations -> UniFi Controller
When I open up the firewall and configure the Unifi Controller, I got this.
But it doesnāt work 100% because it will not show the actual status in the frontend.
The Galaxy tab S2 is connected, see Unifi Controller web interface.
Now I have following configuration in my configuration.yaml
unifi:
controllers:
- host: unifi
ssid_filter:
- 'HomeSSID'
- 'IoTSSID
Should I do something more to get this to work?
I got it to work, apparently I have several instance of galaxy_tab_s2 in HA!
How could it be like this?
Can I remove the different instance of galaxy_tab_s2?
