Any info regarding my question?
I have an anomaly which is making me twitch…
I’m using the following to get memory utilization:
unifi_gateway_wan_mem:
friendly_name: "Unifi Memory"
value_template: "{{ states.sensor.unifi_gateway_wan.attributes['gw_system-stats']['mem'] }}"
When I load my Template Entities the value populates…but then after a few minutes it disappears, and only comes back if I reload or if the value changes. Unfortunately I have pretty low usage which means a steady utilization - so I go hours with no reporting.
This is a problem because even tho HA is just happy to report the previous value, I’m actually dumping all my data into an InfluxDB to use in a Grafana dashboard, and it’s just blank.
What’s funny is if I pull the table in InfluxDB I can see the parent sensor.unifi_gateway_wan updates every minute - and includes the mem value, but parsing out the mem value comes up blank
The screenshot below is a 1hr period and the top mem measurement only has 7 entries from when I was reloading…but further down are 3.5 pages of the parent
Does anyone know a way to reload this integration automatically? My Unifi controller and Home Assistant are on the same Docker instance and sometimes Unifi takes a few minutes to startup and Home Assistant won’t retry the connection. Thanks.
go to settings–> Integrations → Find the Unifi Integration, click on the 3 dots and then click on reload
I cannot configure this integration. No mater what im doing it won’t work:
“Failed to connect to Unifi Security Gateway: Login failed - status code: 400”
my config:
- platform: unifigateway
host: 192.168.1.254
port: 443
username: xxxxx
password: xxxxxx
verify_ssl: false
monitored_conditions:
- www
- wlan
- alerts
- firmware
- wan
Hey everyone,
I have a problem with my templates. I used the here suggested methods to get the badwidth thats used at the moment. But i get an error in the logs (other data works):
TemplateError('UndefinedError: 'homeassistant.util.read_only_dict.ReadOnlyDict object' has no attribute 'tx_bytes'') while processing template 'Template("{{ states.sensor.unifi_gateway_www.attributes.tx_bytes-r }}")' for attribute '_attr_native_value' in entity 'sensor.unifi_gateway_www_upload'
TemplateError('UndefinedError: 'homeassistant.util.read_only_dict.ReadOnlyDict object' has no attribute 'rx_bytes'') while processing template 'Template("{{ states.sensor.unifi_gateway_www.attributes.rx_bytes-r }}")' for attribute '_attr_native_value' in entity 'sensor.unifi_gateway_www_download'
my templates in the ‘configuration.yaml’ look like this:
host: 10.1.0.1
username: X
password: X
- www
sensors:
unifi_gateway_www_upload:
unique_id: usg_up
friendly_name: 'UDM-Pro Upload'
unit_of_measurement: Mbps
value_template: "{{ states.sensor.unifi_gateway_www.attributes.tx_bytes-r }}"
icon_template: mdi:upload
unifi_gateway_www_download:
unique_id: usg_down
friendly_name: 'UDM-Pro Download'
value_template: "{{ states.sensor.unifi_gateway_www.attributes.rx_bytes-r }}"
icon_template: mdi:download
there is no difference when i try to use
states.sensor.unifi_gateway_www.attributes['rx_bytes-r']
or
maybe someone can help me#
best regards
Jonas
Could someone help me how I can access the Latency for the different services? Like Facebook, Google and so on:
The Attributetree looks like this:
WAN:
availability: 100
latency_average: 17
monitors:
- availability: 100
latency_average: 22
target: facebook.com
- availability: 100
latency_average: 15
target: google.com
- availability: 100
latency_average: 17
target: twitter.com
time_period: 86400
uptime: 701626
The value template should look like this… somehow:
{{ states.sensor.unifi_gateway_wan.attributes[‘WAN’][‘monitors’][’???’] }}
Is this integration still managed? Seems a real shame that it seems to have fallen the side (looking at github).
Is this still working for anyone? I’m currently trying to install it to connect to my UDM, however am getting the following error in the logs:
Logger: custom_components.unifigateway.sensor
Source: custom_components/unifigateway/sensor.py:91
Integration: unifigateway (documentation)
First occurred: 12:53:33 (1 occurrences)
Last logged: 12:53:33
Failed to connect to Unifi Security Gateway: Login failed - status code: 401
Below is my code:
host: 10.10.20.1
port: 443
verify_ssl: false
version: unifiOS
username: xxxx
password: xxxx
- www
- wlan
- alerts
- firmware
Does anyone have any suggestions?
It still works fine. Try port 8443
host: 192.161.1.1
port: 8443
verify_ssl: false
#site_id: default
username: !secret UnifiControllerUser
password: !secret UnifiControllerPW
- www
- wlan
- wan
- lan
#- alerts
- firmware
Thanks for the suggestion @Zoriontsu, unfortunately that isn’t working either.
Not sure what the issue is then
Many thanks to the developer and to all who helped take this forward and provided help here. I just got this to work on my UDM. I am running a basic setup with Home Assistant OS running on a RPi. Here is my config.
host: 192.168.70.1
username: user
password: pwd
port: 443
version: UDMP-unifiOS
- www
- wan
- lan
- wlan
- alerts
- firmware
Thanks for sharing @bestwhenunsupervised … that version seemed to do the trick for my UDM!
I could have sworn I tried doing that value before, but maybe not!
Hi friends I’m getting Unverified HTTPS request is being made to host Warning
This error originated from a custom integration.
Logger: py.warnings
Source: custom_components/unifigateway/sensor.py:171
First occurred: 9:16:16 PM (3 occurrences)
Last logged: 10:02:16 PM
/usr/local/lib/python3.11/site-packages/urllib3/connectionpool.py:1056: InsecureRequestWarning: Unverified HTTPS request is being made to host '192.168.10.1'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/1.26.x/advanced-usage.html#ssl-warnings warnings.warn(
configuration.yaml
host: 192.168.xxx.xx
port: 443
verify_ssl: false
username: !secret u_unifi
password: !secret p_unifi
- www
- wan
I tried reinstalling the component and also tried with and without verify_ssl. I don’t know what to do, I’m getting so many warning Log. Can anyone help me with this
I Have the same problem, I guess it’s time to remove this unsupported HACS intergration, shame as it was very handy while it worked.
The warnings are not in the custom_component, but in the pyunifi library instead. I don’t know enough about how the components pull in python packages, but if the code were modified there, it should stop the errors: Advanced Usage - urllib3 1.26.16 documentation (I might get my husband, who’s an actual developer in Python, to help me figure it out).
Did you had a fix by any chance?
Some news regarding that? Another thing, the integration stops after a couple of hours
I suggest using this SSH integration instead: GitHub - zhbjsh/homeassistant-ssh: Control and monitor devices in Home Assistant by executing commands via SSH
It can be used to add sensors and commands.
Note that you don’t need to add a Host key, you can just use password authentication.
Everything is configured in the HA interface once you’ve downloaded it through HACS and have added the integration in the integrations menu.
In case you installed HA as a container and want to access its host, just use host.containers.internal
for the Host (instead of the IP) for podman or host.docker.internal
for Docker.
Don’t forget to check “Automatically add key to host keys file”.
I’m moving on from this too but…
How do you remove the sensors created by this?
