Actually there is a “standard” for IR and RF kinda
For 433 you got a RTL_433 (github) binary that can decode a lot of messages recieved based on protocols and such, of course per company/product it will vary but seeing it work on my RTL-SDR stick it was nice to see that ppl opened there garage or recieving weather stations from neighbours. all using different protocols and such
IR generaly consists of “group/device” +“toggle” +“command” otherwise you could use your remote in a media shop to turn up the volume of every media device present … (tv/stereo for example) or have wierd effects when you change volume at home and your airco is set to -15 since that is not happening (in general)
however the protocol used between devices wil differ as well (the way IR is send)
same goes for other “protocols” that send “open” data over the air there is some way to filter if multiple device(s) are near each other… althoug results still vary depending on the type of remote/device
