Universal Solar Inverter over Modbus RS485 / TCP custom_component (Growatt, Sofar, SolaX, Solis)
Too late :wink:
Entities show up in “Unknown” state now, which is good.
Now I’ll go and fix my statistics.
Thanks for your effort @infradom & @wills106!
Check the release notes for 2022.12.1 & 2022.12.4 I broke one entity in 2022.12.1 but provided you a solution in 2022.12.4 if it’s easier than cleaning statistics?
Edit: If either yourself doesn’t need it or no one else does, I can always remove it in the future.
I have to fix the statistics for the total yield sensor, since it had a meter reset due to it dropping to 0.
But it’s not that hard to fix when the inverter is sleeping :wink:
UPDATE "statistics_short_term"
SET state = 3583.2, sum = 1613.2
WHERE metadata_id = 77
AND start > "2022-12-10 14:35:00.000000";
UPDATE "statistics"
AND start > "2022-12-10 14:00:00.000000";
The rename was a little inconvenient indeed, some automations, template sensors and dashboards broke. But I already changed those to the new name.
It’s always tricky trying to harmonise names, especially with the SolaX ones. As some of them are 3 years old now from when I started the “packaged” version before the Integration.
Some of the names aren’t ideal as they were before I fully understood what some of the sensors / entities actually are.
Hi there. I’ve been using the work from @wills106 for a long time now (ever since the manual yaml package).
After upgrading home assistant to 2022.12 (was using still 2022.05) I tried to update to the last version of the solax custom component (I was using a very old 0.3.3), but I can’t manage to put it to work.
I tried both the manual installation and via HACS (and did a lot of home assistant restarting just in case).
I always get the following:
unrecognized inverter type - serial number : unknown
13:01:42 – (ERROR) SolaX Inverter Modbus (custom integration)
SolaX: cannot find serial number, even not for MIC
SolaX: reading serial number from address 0x300 failed; other address may succeed
13:01:42 – (WARNING) SolaX Inverter Modbus (custom integration)
SolaX: reading serial number from address 0x0 failed; other address may succeed
I have a Gen3 Hybrid (including a battery). Version 0.3.3 keeps working fine in home assistant 2022.12.
Any hints?
EDIT: IP connection via ethernet
@smdx Did you completely remove the old integration before installing the new version ?
What I did:
Remove integration (old version) → reboot HA → remove files → reboot HA → add new files (either by HACS or manually) → reboot HA → add integration
When returned to the old version, HA was able to show me the history of the previous sensors, some data remained even after removing the integration.
As of 2022.12.8 and Home Assistant 2022.12.7 (maybe also an older version I’m not sure) most of the readings show “Unknown” and in the log there’s the following error after restarting Home Assistant:
SolaX error reading holding registers at device 1 position 0x206
It only shows up once, but after that there is also a longer entry that keeps occuring:
Something went wrong reading from modbus
  File "/config/custom_components/solax_modbus/__init__.py", line 320, in read_modbus_data
    res = self.read_modbus_registers_all()
  File "/config/custom_components/solax_modbus/__init__.py", line 397, in read_modbus_registers_all
    self.data[descr.key] = descr.value_function(0, descr, self.data )
  File "/config/custom_components/solax_modbus/const.py", line 182, in value_function_grid_import
    val = datadict["measured_power"]
KeyError: 'measured_power'
This is with a Gen3 X3-Hybrid (Serial: H3UE).
What version were you on previously?
I’m not sure, some other 2022.12.x version but I don’t remember if it was 2022.12.7 or 2022.12.6.
Is to do with extra BMS information. How many batteries do you have on your system?
I’m not sure why you are getting that. That’s you grid power. Unless you had a glitch from your Modbus Power Meter / CT clamp?
Just one battery and I’m getting readings from the grid on the inverter as usual (at least I guess so, there are values displayed that change and make sense so I think everything is normal).
The grid values are from a smartmeter that is connected via a cable to the inverter over RS485 by the way.
If you look as the second post there are a few more links to the same issue.
Thanks, went back to 2022.12.6 and now the values are showing up again.
Can I just confirm you are using the built in ethernet on your Gen3 and not trying to connect via Pocket WiFi
Yes I am using the built in ethernet :slight_smile:
I just updated from 2022.12.8 to 2022.12.12, and that broke my total_yield (and the voltage and frequency entities) again.
They are showing 0 again when the inverter is Waiting. So I downgraded and fixed my statistics database (again)…
Sorry, Side effect of another correction. I will fix it very soon…
Just released 2022.12.13
Thanks for your integration.
With a Solis hybrid everything works fine but someday I have incorrect values in energy dashboard.
I guess it is because I experience minor disconnection where Power Generation Total goes to 0 instead of unkown… so when value gets back energy dashboard sums it up. Any idea how to fix ?
I have also this error popping
Logger: custom_components.solax_modbus
Source: /config/custom_components/solax_modbus/__init__.py:417
Integration: SolaX Inverter Modbus
First occurred: 17:10:10 (1 occurrences)
Last logged: 17:10:10
RHI error reading holding registers at device 1 position 0xa86c
NoneType: None
