That’s an excellent idea Eric! Works perfectly. Hopefully it will solve this issue too:
The only addition I’ve made is to add the retained flag so that the sensor restores after a Home Assistant restart and to change the topic to match the structure I use:
init_commands:
while [ 1 = 1 ]; do docker exec addon_a0d7b954_influxdb du -s
/data/influxdb/data/homeassistant | mosquitto_pub -t
home-assistant/sensor/dbsize -r -u <user> -P <password> -l && sleep
300; done &
Mqtt sensor:
- name: InfluxDB DB Size
unit_of_measurement: 'MB'
icon: hass:chart-line
state_topic: "home-assistant/sensor/dbsize"
value_template: "{{ (value.split('\t')[0]|int(0)/1000)|round(3) }}"
