relying on the folder size instead of the _internal DBs shard series field “diskBytes” as it is hilarious small compared to the actual folder size (approx. 56 times smaller) and therefore
to use a more basic approach by using a simple command_line sensor. That one looks like
- platform: command_line
name: InfluxDB size (homeassistant)
scan_interval: 120 # Change to higher value after finishing tests
command_timeout: 30
command: "docker exec addon_XXXXXXXX_influxdb du -shm /data/influxdb/data/homeassistant | cut -f1"
unit_of_measurement: MB
value_template: "{{ value }}"
I reloaded command line entities (did not restart HA) and it has been created. BUT: it shows a size of zero (0 MB)
The command itself is working perfectly when fired on the SSH console. What did I miss?
Update 1:
I´m pretty sure I found the root cause thinking bout it for 10 seconds. The command is performed from homeassistant so from inside the homeassistant container (I´m running HASS OS too). And there even is no docker command inside “homeassistant”. So any way to run that command for the command line sensor with “root privileges” (how to break out of the HA docker container?)? I´m pretty sure that´s impossible.
Running it from root ssh, storing it in a text file and reading that one from homeassistant as sensor now sounds pretty cool to me (not that much overkill)… would still like to avoid this, hopefully there´s a smarter solution.
Man I liked to keep it simple so much… what is the next approach without pushing it as far as @tom_l ?
Update 2:
My last approach was a “hammer style” one: using SSH to login to the host and get the information. Unfortunately this comes with several detailled and overall security risks like
by either passing the SSH password for the HA host on the command line sensor or
the need to whitelist the HA container in the host known_hosts file (password-less SSH),
in the end the biggest security issue would be HA container being able to access the host - which is a nice “Welcome! Get in!” for every bad guy, especially when having HA publicly accessable on the internet…
In my opinition homeassistant container should not have the opportunity to get access to the host. So providing the information from the host for the homeassistant container is also complicated but quite good in terms of security.
i tried to make the sensor same way you described. but i got no sensor and a error msg.
Logger: homeassistant.components.file.sensor
Source: components/file/sensor.py:45
Integration: file (documentation, issues)
First occurred: October 27, 2021, 17:03:22 (1 occurrences)
Last logged: October 27, 2021, 17:03:22
'/config/file_sensors/ha_influx_db_size.txt' is not an allowed directory
That’s an excellent idea Eric! Works perfectly. Hopefully it will solve this issue too:
The only addition I’ve made is to add the retained flag so that the sensor restores after a Home Assistant restart and to change the topic to match the structure I use:
And in the addon docs:
Option: logins (optional)
A list of local users that will be created with username and password. You don’t need to do this because you can use Home Assistant users too, without any configuration. If a local user is specifically desired:
Hi!
I can’t make the Terminal&SSH work. I have tried the file creation mode and the mqtt, but it seems, that nothing happened.
I don’t have an option to turn off Protection mode
Previously in this thread I proposed to publish the InfluxDB size via MQTT. I just want to update how to publish it via a command line sensor, for those that don’t want to run a MQTT server. Please note this procedure is more advanced.
The SSH & Web Terminal is still needed (with protection mode off)
We now don’t create the init command in that add-on!
Each addon has a hostname which is shown on the info tab of the config panel for that addon which can be used to talk to it from HA and other addons. You don’t have to expose the ssh on the host and go out over your LAN to talk to it from HA. Just use this instead and talk to it directly without leaving the docker network:
ssh <user>@a0d7b954-ssh ...
Plus then your yaml can simply be copied and pasted by other users that want to do the same since the hostname of an addon is the same on all systems. Whereas everyone’s LAN subnet and chosen IP for HA is different.
