Up against a Z-wave wall help I am DROWNING
After four or five reinstalls without saving the logs, I’m not sure I could add much to an issue. I have no logs or any other traces since I used the same SD for all my installs.
My steps:
Downloaded HassOS 2021.3.3, used Balana Etcher to put it on SD, installed the SD in a RPi 4 B/4GB. Allowed the system to install and boot.
Created an account.
Shutdown HASS and powered off RPi.
Plugged in Aeotec Gen 5+ stick in USB 2.0 (also tried USB 3.0) port.
Booted, logged in.
Device listed under Supervisor -> System -> Hardware Info
Added the Zwave-JS integration, tried all devices of /dev/ttyACM0, /dev/ttyACM and /dev/serial/by-id/usb-0658_0200-if00 - nothing worked, no device detected. After a couple of tries the zwave integration stops responding completely.
Tried removing and adding integration again but no change.
Rinse and repeat 5 times before giving up.
Tried the deprecated Z-wave integration with device /dev/serial/by-id/usb-0658_0200-if00 and bang - all just works.
Now I have all my devices from Fibaro, Aeotec and Telldus working.
