Confirmed as solution to the Travis build problem. Thank You!
For some reason, my update script does not work.
This is the script I try to call via HASS to update the config and then reload HASS:
https://github.com/TribuneX/home_assistant/blob/master/bash/git_pull.sh
Extract from my HASS config:
git_pull: 'sudo bash /opt/home_assistant/bash/git_pull.sh'
get_latest_config:
alias: 'Get Latest Config'
sequence:
- service: shell_command.git_pull
I also added this script to my sudoers file, in order to let HASS use sudo:
homeassistant ALL = NOPASSWD: /opt/home_assistant/bash/git_pull.sh
The script works without any issue, if I execute it from the command line.
There is no error in the log. Any ideas?
Got if fixed. I had to clean some file and folder privileges, in order to pull the repository from within the env where HASS is installed.
Would you be so kind to tell me what you did to get to get the pull working? I’m really struggling with this one,
Nevermind! I fixed it, It turns out some files weren’t owned by the homeassistant user
@tmatheussen found this from yonks ago, are you still using it? - I couldn’t find any info in your repo.
I’m not using it anymore, we moved to a new house 2 years ago and I’ve completely re-done my setup, including remote access
I do still use github for my config, but more and more stuff is moving to UI which reduces my repo setup, HA also has build-in protection to prevent starting with a breaking config, which totally negates the need for Travis even further.
If you really want to see the old stuff, you can look at this page:
this is basically my repo before removing a lot of legacy stuff
