Update Philips Hue Devices with Home Assistant + Zigbee Native
You can not (yet) update Philips Hue devices using Zigbee OTA via the ZHA integration out-of-the-box, but as mentioned you can manually enable it via advanced zigpy configuration by editing YAML and point to Koenkk’s Zigbee OTA repository used in Zigbee2MQTT/Z2M, however note that is experimental and should really only be used by developers. ZHA developers have said they have a plan to add their own repository with only tested and verified Zigbee OTA files from official sources. So for now you can choose to use unofficial sources at your own risk, which could brick the devices since flash from unofficial sources. Also, keep in mind that it is generally recommend to not update Zigbee devices unless you are having specific issues with a device and then only update that device. Read about that and more here:
FYI ZHA docs for end users will not get info on that since should only be used by developers, see here:
