Are there any errors in the logs when you run the automation? What kind of ubiquiti controller do you have?
I donāt know where the logs are. Can you tell me how to view them? I have the dream machine pro.
Can you tell me where the logs are?
PR is up for HA core Add WLAN QR code support to UniFi Image platform by Kane610 Ā· Pull Request #97171 Ā· home-assistant/core Ā· GitHub
Hi @exx ,
Iām getting this error in the log
Logger: homeassistant.components.shell_command
Source: /usr/src/homeassistant/homeassistant/components/shell_command/__init__.py:131
Integration: Shell Command (documentation, issues)
First occurred: 6:48:23 PM (1 occurrences)
Last logged: 6:48:23 PM
Error running command: `/bin/bash /config/scripts/wifichange.sh change {{ username }} {{ password }} {{ baseurl }} {{ network_id }} {{ ssid }}`, return code: 2
NoneType: None
Any idea where to look?
iām confident the local user id and pw are correctly entered in the automation entry.
with the latest release of unifi integration in 2023.8, QR entity is available. I guess iām just more concerned on how to automate the guest wifi password in udmpro. is there any other way out there?
thanks in advance for your response.
Regards
hi @it-luisfsb ,
iām gettint return code: 2 as well.
i tried look at your solution but i donāt understand, please can you point what portion in the code you applied the fix, please?
thanks.
Thank you all for this great post. unfortunately, Iām getting an error too
stdout: ""
stderr: "/config/scripts/wifichange.sh: line 2: $'\\r': command not found\n/config/scripts/wifichange.sh: line 5: $'\\r': command not found\n/config/scripts/wifichange.sh: line 7: $'\\r': command not found\n/config/scripts/wifichange.sh: line 10: $'\\r': command not found\nConnecting to api.qrserver.com (95.216.163.127:80)\nwget: server returned error: HTTP/1.1 400 Bad Request\n/config/scripts/wifichange.sh: line 13: $'\\r': command not found\ncurl: option --insecure\r: is unknown\ncurl: try 'curl --help' or 'curl --manual' for more information\n/config/scripts/wifichange.sh: line 16: $'\\r': command not found\ncurl: option --insecure\r: is unknown\ncurl: try 'curl --help' or 'curl --manual' for more information"
returncode: 2
my wifichange.sh
#!/bin/sh
cookie=$(mktemp)
headers=$(mktemp)
curl_cmd="curl --silent --output /dev/null --cookie ${cookie} --cookie-jar ${cookie} --insecure"
# generate new password
NEW_PWD=$(cat /dev/urandom | tr -dc 'a-zA-Z0-9' | fold -w 32 | head -n 1)
# generate QR code
wget --output-document="/config/www/${5}.png" "http://api.qrserver.com/v1/create-qr-code/?data=WIFI:T:WPA;S:${5};P:${NEW_PWD};H:;&size=100x100"
# authenticate against unifi controller
${curl_cmd} -H 'Content-Type: application/json' -D ${headers} -d "{\"username\":\"${1}\", \"password\":\"${2}\"}" https://${3}8443/api/login
# change wifi password
${curl_cmd} -k -X PUT https://${3}:8443/api/s/default/rest/wlanconf/${4} -H "Content-Type: application/json" -d "{\"_id\":\"${4}\",\"x_passphrase\":\"${NEW_PWD}\"}"
I got the same error with every iteration of the script.
- unifi login requests should use the post method:
-X POST
. If omitted, curl defaults to-X GET
- put a colon between
${3}
and8443
I donāt know how I missed the colon. unfortunately, that didnāt fix it. I made sure that the user and password, and all other variables are correct.
new code
#!/bin/sh
cookie=$(mktemp)
headers=$(mktemp)
# generate QR code
${curl_cmd} -H 'Content-Type: application/json' -D ${headers} -d "{\"username\":\"${1}\", \"password\":\"${2}\"}" https://${3}:8443/api/login
error
stdout: ""
returncode: 2
in my troubleshooting, I hardcoded the variableās values and got the same error. then removed the unifi portion of the code and got this error
stdout: ""
stderr: |-
/config/scripts/wifichange.sh: line 2: $'\r': command not found
/config/scripts/wifichange.sh: line 5: $'\r': command not found
/config/scripts/wifichange.sh: line 7: $'\r': command not found
/config/scripts/wifichange.sh: line 10: $'\r': command not found
Connecting to api.qrserver.com (159.69.246.187:80)
/config/scripts/wifichange.sh: line 13: $'\r': command not found
/config/scripts/wifichange.sh: line 16: $'\r': command not found
returncode: 127
I donāt know but it seems to me that the problem is in the QR code part
Looks like you have an extra character on every line, specifically \r.
Youāll need to open the script file in some type of editor that you show you non-printable characters to see it and remove it.
Actually, based on the line numbers, it looks like itās complaining about every blank line. Just remove the blank lines and try that.
iām wanting to try to implement this on my system, but can i just check what the rationale is for using that online qr generator and the camera entity, rather than the new built in qr generator in the unifi integration? just want to make sure iām understanding this whole thing correctly.
Scroll up.
i actually have read the whole thread but i noted you didnāt adjust your original code to use the built in unifi qr display so am curious if thereās a reason for this? is it just because its not giving you a .png that you can manipulate?
after many days, Iām still not able to solve the return code 2 error.
i stumbled upon this GitHub - rootnegativ1/unifi-wifi: Home Assistant integration to change wireless passwords on UniFi Network controllers and seems to work really well. If anyone else wanna give it a try.
You read the whole thread?
So let me see if I have this straight - youāre asking me why I didnāt use the built-in integration that didnāt exist when I wrote this code, and was added because of the popularity of what I developed?
I donāt even know how to answer that.
yeah i did read the whole thread. before i posted. and again just in case after you replied.
and no, thatās not what iām asking. Iām asking you if thereās a reason you arenāt using that built-in integration now that it exists. Because, i noticed you had updated your code as various comments came in through the thread and as you found ways to make it better. This part you didnāt update so I was wondering if you had a specific reason you preferred this and wanted to understand why it might be advantageous. Thatās why i said i noticed you didnāt āupdateā your code to reflect it.
up to you if you want to answer the question, although i donāt get the passive aggression here. either way i appreciate your hard work on this it is great.
Ah. My apologies, I literally didnāt understand what you were asking. Not passive-aggressive, just extremely confused. LOL
Having said that, maybe you did read the entire thread, but Iām thinking you didnāt pay close enough attention to the dates.
My last update to the code was a full year before the integration was released, soā¦ I guess now I find myself wondering why I would update my code to include code that is already part of an integration that can just easily be added without going through all the manual shenanigans I went through to make it work originally?
So yeah, I guess Iām still a bit confused by the question. LOL
If you want to use the integration, by all means - please do. In fact, I encourage it at this point. My code worked, but it was a bit ādirtyā, since Iām not a full-time programmer like a lot of these guys are. I know enough to get by, but my formal education was a quarter century ago, and I ultimately went into the systems side of things, so Iāve only ever coded out of necessity, which is what this was.
The integration is much cleaner, and I presume will remain supported for some time to come. If it meets your needs, then I would absolutely go that route.
I continue to be humbled by the fact that my dirty old code written in my basement home office was the genesis for this feature addition to the official integration, but Iām a firm believer in āif it aināt broke, donāt fix itā. It still works just fine in my environment, soā¦
Thank you for the kind words about my hard work, BTW. I definitely appreciate it.
I should also add some password re-generation, I feel like that is the missing piece to offer a good guest experience
I have iterated many times over the code to where it is now, I am only a coder by night and itās been a long time since I worked as it. So donāt feel intimidated. It is really fun to work with home assistant.
Oh! I thought that had been added since it was a big part of what I wrote. Oh well, thatāll teach me to not test out the new stuff before recommending it as a full replacement! LOL
And yes, coding is fun, I agree - my issue is that once I get it working, I usually stop there. It could be ugly, inefficient, etc - but if it works, Iām happy. But thatās the difference between developing for yourself vs developing for someone else.
