Hi all!
I’m using HA-Core in a virtual environment (pip) ant want to upgrade HA from 2023.3.6 to any 2023.4.x version. It’s a Raspberry Pi 3 Model B+ with osmc (debian)
This fails because of the new cryptography version 40.0.1.
I get the following error.
I tried to upgrade a completely new venv to python 3.11 but when I install the requirements I get exactly the same error. I’m wondering, why the setup tries to unpack a win32 binary.
I also tried to upgrade the cryptography package alone to 40.0.2, but I get the same error.
Does someone have an idea?!
I can’t update HA anymore since 4 weeks.
Running `rustc --crate-name cryptography_rust --edition=2018 src/lib.rs --error-format=json --json=diagnostic-rendered-ansi,artifacts,future-incompat --crate-type cdylib --emit=dep-info,link -C opt-level=3 -C lto=thin -C overflow-checks=on --cfg 'feature="default"' --cfg 'feature="extension-module"' -C metadata=2407ebcc60d88c97 --out-dir /tmp/pip-install-02nqsyh0/cryptography_bbc0284838224a90956b38f30f074441/src/rust/target/release/deps -L dependency=/tmp/pip-install-02nqsyh0/cryptography_bbc0284838224a90956b38f30f074441/src/rust/target/release/deps --extern asn1=/tmp/pip-install-02nqsyh0/cryptography_bbc0284838224a90956b38f30f074441/src/rust/target/release/deps/libasn1-1f36e558835be1e9.rlib --extern chrono=/tmp/pip-install-02nqsyh0/cryptography_bbc0284838224a90956b38f30f074441/src/rust/target/release/deps/libchrono-72a4a023d729740a.rlib --extern foreign_types_shared=/tmp/pip-install-02nqsyh0/cryptography_bbc0284838224a90956b38f30f074441/src/rust/target/release/deps/libforeign_types_shared-0533b1da914edb9d.rlib --extern once_cell=/tmp/pip-install-02nqsyh0/cryptography_bbc0284838224a90956b38f30f074441/src/rust/target/release/deps/libonce_cell-864698dbd75185fb.rlib --extern openssl=/tmp/pip-install-02nqsyh0/cryptography_bbc0284838224a90956b38f30f074441/src/rust/target/release/deps/libopenssl-c24ee10219eb2711.rlib --extern openssl_sys=/tmp/pip-install-02nqsyh0/cryptography_bbc0284838224a90956b38f30f074441/src/rust/target/release/deps/libopenssl_sys-de6aa823abab0d4e.rlib --extern ouroboros=/tmp/pip-install-02nqsyh0/cryptography_bbc0284838224a90956b38f30f074441/src/rust/target/release/deps/libouroboros-8c011bf66c430803.rlib --extern pem=/tmp/pip-install-02nqsyh0/cryptography_bbc0284838224a90956b38f30f074441/src/rust/target/release/deps/libpem-32861522e56a774a.rlib --extern pyo3=/tmp/pip-install-02nqsyh0/cryptography_bbc0284838224a90956b38f30f074441/src/rust/target/release/deps/libpyo3-5ae737da2b299080.rlib -L native=/tmp/pip-install-02nqsyh0/cryptography_bbc0284838224a90956b38f30f074441/src/rust/target/release/build/cryptography-rust-75f68e965953ec33/out -l static=_openssl.a --cfg 'python_implementation="CPython"'`
Finished release [optimized] target(s) in 9m 26s
error: failed to download `windows v0.46.0`
Caused by:
unable to get packages from source
Caused by:
failed to unpack package `windows v0.46.0`
Caused by:
failed to unpack entry at `windows-0.46.0/src/Windows/Win32/Graphics/Dxgi/mod.rs`
Caused by:
failed to unpack `/home/homeassistant/.cargo/registry/src/github.com-1285ae84e5963aae/windows-0.46.0/src/Windows/Win32/Graphics/Dxgi/mod.rs`
Caused by:
failed to unpack `windows-0.46.0/src/Windows/Win32/Graphics/Dxgi/mod.rs` into `/home/homeassistant/.cargo/registry/src/github.com-1285ae84e5963aae/windows-0.46.0/src/Windows/Win32/Graphics/Dxgi/mod.rs`
Caused by:
unexpected end of file
=============================DEBUG ASSISTANCE=============================
If you are seeing a compilation error please try the following steps to
successfully install cryptography:
1) Upgrade to the latest pip and try again. This will fix errors for most
users. See: https://pip.pypa.io/en/stable/installing/#upgrading-pip
2) Read https://cryptography.io/en/latest/installation/ for specific
instructions for your platform.
3) Check our frequently asked questions for more information:
https://cryptography.io/en/latest/faq/
4) Ensure you have a recent Rust toolchain installed:
https://cryptography.io/en/latest/installation/#rust
Python: 3.10.9
platform: Linux-5.10.78-7-osmc-armv7l-with-glibc2.31
pip: n/a
setuptools: 67.7.2
setuptools_rust: 1.6.0
rustc: n/a
error: `cargo metadata --manifest-path src/rust/Cargo.toml --format-version 1` failed with code 101
-- Output captured from stdout:
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for cryptography
Failed to build cryptography
ERROR: Could not build wheels for cryptography, which is required to install pyproject.toml-based projects
