pi@media-pi:~ $ sudo su -s /bin/bash homeassistant
homeassistant@media-pi:/home/pi $ source /srv/homeassistant/bin/activate
(homeassistant) homeassistant@media-pi:/home/pi $ pip3 install --upgrade homeassistant
File "/srv/homeassistant/bin/pip3", line 7, in <module>
from pip import main
File "/srv/homeassistant/lib/python3.4/site-packages/pip/__init__.py", line 28, in <module>
from pip.vcs import git, mercurial, subversion, bazaar # noqa
File "/srv/homeassistant/lib/python3.4/site-packages/pip/vcs/mercurial.py", line 9, in <module>
from pip.download import path_to_url
File "/srv/homeassistant/lib/python3.4/site-packages/pip/download.py", line 36, in <module>
from pip.utils.glibc import libc_ver
File "/srv/homeassistant/lib/python3.4/site-packages/pip/utils/glibc.py", line 4, in <module>
import ctypes
File "/usr/lib/python3.4/ctypes/__init__.py", line 7, in <module>
from _ctypes import Union, Structure, Array
ImportError: /srv/homeassistant/lib/python3.4/lib-dynload/_ctypes.cpython-34m-arm-linux-gnueabihf.so: undefined symbol: _PyTraceback_Add
awesome thanks
I had to create the folder in /srv and chown it to homeassistant user and i have my HAS back…but…always a but…
i get an error in the log:
ERROR:homeassistant.components.http:Failed to create HTTP server at port 80: [Errno 13] error while attempting to bind on address ('192.168.0.50', 80): permission denied
Something in your configuration.yaml is trying to use port 80, but you have to have root privileges to do that. You need to use a port higher than 1024 (I think) for non-root users.
I also updated my hass(bian) to stretch and (almost) everything stopped working.
After rebuilding the virtual environment, reinstalling homeassistant and dropping mysql tables, it looks like it is all working again.
However, it seems that my ethernet port is no longer ‘/dev/eth0’, but changed to ‘/dev/enx[xxyyzzxyxz]’ due to predictable network interface names. So I had to hook up an old monitor and keyboard to login before I found out what was wrong.
yeah, I did read some people had problems after and even during upgrade.
during the upgrade all the changes were presented to me and I was given the option to keep my original config files, or install the ‘new’ one, for example dhcpcd.conf
also have the option to compare, which I did and kept everything I thought might have any breaking effect.
I copied my config files and started over with a new installation. Using the AIO, my configuration had issues with Mosquitto, FFMPEG, and Zwave. If you google Mosquitto and Stretch, there is a solution out there to have the necessary files to configure mosquitto properly. Same with FFMPEG.
Zwave was a little more tricky because my homeassistant install had created the config files in two places and they were not sourcing like it should. I think it has something to do with Python3.5 vs 3.4 which is what all the HA docs continue to reference. Once I realized it and copied the files in the /src/ location to the .homeassistant location, it has been working properly since.
